if I cat the iio file , I get a different sample every time. For example:
{noformat}
~ # cat /sys/bus/iio/devices/iio:device0/in_voltage0_raw
3471
3489
3385
{noformat}
however, if I have a user space program (in C) and I open that file for reading and read it multiple times, the sample stays the same, making me think the file open is triggering the sample, and not the read.
Is this expected? I will dig through the code a bit more but I expect so. Is there a way to configure this driver so I can get samples triggered on each read?
thanks!
-Tyler
