object detection using haarcascade
2,408 次查看
1990rahulreddy
I have to run object detection using haarcascade, How can I use haarcascade in Eclipse, I run basic c code on i.MX6 using cross compile in Eclipse. I am able to run object detection code, in ubuntu terminal...but, for eclipse, how to give path to it. I add this file "src" folder, but not work..please help....
标签 (3)
2,077 次查看
Bio_TICFSL
Hi Rahul,
Please check the document on Building OpenCV on ubuntu hardfloat rootfs for i.MX6Q
It includes an example of face detection using haarcascade.
Hope this helps
4 回复数
2,078 次查看
Bio_TICFSL
Hi Rahul,
Hope this helps
2,078 次查看
1990rahulreddy
It uses "linaro-alip",
I have to do it using yocto.
Can you please tell mi, how to install cmake in yocto
2,078 次查看
Bio_TICFSL
Please check this:
Yocto and OpenCV for I.MX
2,078 次查看
1990rahulreddy
Please, inspect the question sir,..
I have enable opencv in yocto, & I am using Eclipse for Application Development..my problem is only "how to add haarcascade" in my Eclipse... project..
