nor flash for imx6
nor flash for imx6
1,144 次查看
fangxu
i use 128M nor flash used CS0,but the kernel(3.0.35) note:
physmap platform flash device:02000000 at 08000000
physmap-flash.0: Found 1 x16 devices at 0x0 in16-bit bank.Manufacturer ID 0x000001 chip ID 0x002801
NOR chip too large to fit mapping.Attempting to cope...
Amd/Fujitsu Extended Query Table at 0x0040
     Amd/Fujitsu Extended Query version 1.3.
number of CFI chips :1
Reducing visibility of 131072KiB chip to 32768 KiB
I writed the IOMUXC_GPR1 = XXXXX005. Who know the problem.
944 次查看
tonyzheng
hello,
Can you describe your steps to reproduce your symptom?
