I am attempting to run the netx_duo_iperf azure example. When I select the option to "run to main" the system hangs somewhere. When I deselect the option, the code starts at a label named Reset_Handler. I can step through the code until the instruction CPSIE I is executed. Then the CPU is out to lunch. Any suggestions?
