mys-8mmx GPIO pin line accessing
kundan
Hello everyone,
I am working on MYiR MYS-8MMX SBC board. now i am able to toggle the GPIO pin using command using export method from sys/class/gpio.
Now i want to toggle in a loop. So i am following https://github.com/starnight/libgpiod-example/blob/master/libgpiod-led/main.c method. here i am getting issue.
I don't know what i need to mention in *chipname and line_number
char *chipname =
unsigned int line_num =
unsigned int val;
struct gpiod_chip *chip;
struct gpiod_line *line;
