mix two video sources into one (side-by-side)
Showing results forย
Search instead forย
Did you mean:ย
vishvapathi
Hi All,
I am working on Displaying/streaming 2 UVC CAM's simultaneously. Below Command
gst-launch v4l2src device=/dev/video1 ! videoscale ! ffmpegcolorspace ! video/x-raw-yuv, width=320, height=240 ! videobox border-alpha=0 left=-320 ! videomixer name=mix ! ffmpegcolorspace ! autovideosink v4l2src device=/dev/video2 ! videoscale ! ffmpegcolorspace ! video/x-raw-yuv, width=320, height=240 ! videobox right=-320 ! mix.
Out of 2, /dev/video1 streams data but the second CAM /dev/video2 is ON after the command, but in my Display its pitch black.
Is this the correct way to stream multiple cams??
Kindly advice
DaianeAngolini
YuriMuhin_ng
shanmugamsundar
Labels (3)
vishvapathi
For the Below Mixer command i am able to view only one video stream, the other CAM streams but in display its completely black.
$ gst-launch v4l2src device=/dev/video1 ! videoscale ! ffmpegcolorspace ! video/x-raw-yuv, framerate=5/1, width=320, height=240 ! videobox border-alpha=0 left=-320 ! videomixer name=mix ! ffmpegcolorspace ! autovideosink sync=false v4l2src device=/dev/video2 ! videoscale ! ffmpegcolorspace ! video/x-raw-yuv,framerate=5/1,width=320, height=240 ! videobox right=-320 ! mix.
MFW_GST_V4LSINK_PLUGIN 3.0.7 build on Feb 14 2014 12:47:14.
[--->FINALIZE v4l_sink
set color key
MFW_GST_ISINK_PLUGIN 3.0.7 build on Feb 14 2014 12:47:47.
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src1: Got unexpecte.
Additional debug info:
gstv4l2src.c(914): gst_v4l2src_get_mmap (): /GstPipeline:pipeline0/GstV4l2Src:v1
hwbuf allocator zone(307200) created
can not create threadmfw_gst_isink_setcaps:1489
VS0 created. in fmt[YUYV] win(0,0-640,240:640x240) out win(0,0-1024,768:1024x76)
set deinterlace mode 0
hwbuf allocator zone(614400) created
hwbuf allocator zone(614400) destroied.
Any pointers how to solve this?
LeonardoSandovalGonzalez
Tarek
vishvapathi
The Position of Displaying was wrong i guess.. after correcting it i am able to view both Camera streaming.
Tarek
Senior Contributor I
If you are using i.MX6 you should try the mfw_isink element. This element will do the scaling and positioning in hardware and save you a lot of CPU power. You can run 2 separate gstreamer pipelines each playing in a different position on the screen. Please see this post for how to use it.
Hope that helps.
daiane_angolini
I have never worked with videomixer before.
I think this kind of question is better replied in gstreamer community. Did you subscribe to gstreamer mailing list?
vishvapathi
No, I haven't...
