missing spl/u-boot-spl-ddr.bin when building Uboot for Coral
2,507 次查看
DurianDennis
Hi I am trying to build Uboot for the Google Coral board which is based on imx8.
I did the following on my Ubuntu 20.04 laptop:
sudo apt install g++-aarch64-linux-gnu
sudo apt install device-tree-compiler
git clone https://coral.googlesource.com/uboot-imx
make ARCH=arm64 mx8mq_phanbell_defconfig
make CROSS_COMPILE=aarch64-linux-gnu- u-boot.imx
I am getting an error message at the end of the build and it says something like Can't open spl/u-boot-spl-ddr.bin.
Anyone has a clue what is going on? Thank you so much.
2,430 次查看
JunpapaCS
Hello
I'm using the imx8mm evk board and in the same situation.
Did you find a solution through Yuri's answer?
Thanks in advance.
2,494 次查看
Yuri
