mini sas to LVDS adaptor board
mshanka1
I have a iMX8quadmax MEK board. i want to connect a capacitive touch 10.1 inch LVDS screen to the MEK board. But i am not able to find any convertor/adaptor for MIPI/DISI LVDS connector to LVDS 10 pin parallel connector.
Can you please advice on how to proceed ?
JorgeCas
Hello, I hope you are doing well.
For what I understood, there is no an specific adapter to convert Mini-SAS to 10 pin FPC connector. Could you please provide the exact part number to confirm it?
If that adapter is not available, you need to design it.
Best regards.
mshanka1
Hi @JorgeCas ,
I currently have a "capacitive Touch Display 10.1 LVDS with LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it. I have the iMX8QM MEK board. I am looking for a way to connect the MEK board with the Display.
Please help me.
JorgeCas
Unfortunately, we do not have an adapter for that specific connector. In that case you need to design an adapter to route Mini-SAS connector signals to 10 pin FFC connector.
Best regards.
And9686
Aren't there any pcb designs made by you (the NXP company)? Sell only those miniSAS ports? It's because I find it kind of akward that we buy a development board from you and you have wierd adapter ports that ain't compatible with anything outside your own ecossystem. And I wouldn't be so bothered if there were really more options for touchscreen displays on this website, having just a 7 inch one in 2024 is awful
