Hi Vincent,
just add two lines, mii commands do not work because these functions are called without initializing
drivers/net/mxc_fec.c:
static int mxc_fec_mii_read(char *devname, unsigned char addr,
unsigned char reg, unsigned short *value)
struct eth_device *dev = eth_get_dev_by_name(devname);
struct fec_info_s *info;
volatile fec_t *fecp;
if (!dev)
return -1;
info = dev->priv;
fecp = (fec_t *) (info->iobase);
fec_reset(dev);
mxc_fec_mii_init(fecp);
return __fec_mii_read(fecp, addr, reg, value);
static int mxc_fec_mii_write(char *devname, unsigned char addr,
unsigned char reg, unsigned short value)
if (!dev)
return -1;
info = dev->priv;
fec_reset(dev);
return __fec_mii_write(fecp, addr, reg, value);
