mfgtool2 damage two pico-imx7d SOM modules. Where it spoiled?
Search instead for
neuberfran
I have this issue: My other imx7d pico android things start kit died, again
I was following the steps of this link: iMX7D Pico won't boot
I used the <LIST name = "eMMC-Brillo-uboot" script from ucl2.xml file
I left the script running beyond time. After Done appeared on the screen it was still running for about 8 minutes.
I think I found out what burned my devices. And the answer is in the link/iIMAGE below (despite being another SOM)
https://developer.solid-run.com/knowledge-base/efuses-for-imx6-som/.
My questions is:  What component did it damage? How to make sure which component(s) burned? Why it spoiled?
Labels (6)
b45499
I’m afraid that the i.MX7D Pico board is manufactured and supported by TechNexion so I would recommend that you contact them especially if you are facing hardware issues.
