mfgtool for i.MX RT vs UUU tool for i.MX 6&8
Search instead for
kanimozhi_t
Contributor V
Hi, is the MFGTool referred in i.MX RT manuals same as the opensource UUU tool (https://github.com/NXPmicro/mfgtools) for i.MX 6  & 8 processors.
We know that MFGTool is predecessor of UUU and UUU has the support for i.MX RT 106x devices. But are these two exactly the same?
Tags (2)
joanxie
they are different,
for difference between uuu script and mfgtools, you also can refer to the chapter 6 Migration from mfgtool ucl2.xml of enclosed file
kanimozhi_t
Contributor V
Thank you @joanxie
Yet we want to confirm the following once.
  1. UUU tool is supposed to replace MFGTool, correct?
  2. Can we flash/program i.MX RT (particularly RT 1160) with UUU tool?
joanxie
yes, uuu tool replace the mfgtools in i.mx8, it seems that i.mxRT doesn't support uuu tool
