mfgtool burn imx8mq evk fails
chhsu0229
I am working on burning Linux OS on om8mq evk SD card and it is failed. My steps are following,
1. SW801 is '0010' and SW is '01
2. double click L4.9.88_2.0.0_mfg-tool_MX8MQ\mfgtools-with-rootfs-mx8\mfgtools\mfgtool2-yocto-mx8-evk-sd2.vbs
3. MfgTool shows
I confirmed that there are files in the Profiles/Linux/OS Firmware/files
How can I fix this issue?
nxf63675
Hi chhsu0229,
It appears that the tool did not found the u-boot file, could you check to the debug window and attach the result? Also attach the mfgtool.log to see if there is something more I am missing, In any case, verify that you have the u-boot and .sdcard files.
Israel.
