maaxboard has " INFO: rcu_preempt detected stalls on CPUs/tasks" , linux crashed!
gonewithwind-peter
Senior Contributor I
hi all,
I am play maaxboard ,yocto sumo, kernel 4.14, after running 1 days, it crashed! serail debugger can not login in , ssh can not login, after  power again, the syslog shows as the pictures:
someone said at here:
https://unix.stackexchange.com/questions/252045/rcu-preempt-detected-stalls-on-cpus-tasks-message-ap...
is it right?
more detail on how I can do to fix it?
thank you very much.
jimmychan
This is hard to determine what is the problem. kernel 4.14 is old. I would suggest you use newer version of kernel BSP.
gonewithwind-peter
@jimmychan
thanks. I am using yocto zeus too, we will test it
