I get the problem that the kernel/ltib does not find imx6s_defconfig.
It seems to me that the /opt/freescale/pkgs/linux* patches with imx6s_defconfig is not done,
but I am unable to figure out why.
I am using L3.0.35_12.09.01
+ make ARCH=arm CROSS_COMPILE= HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ imx6s_defconfig
drivers/staging/ath6kl/Kconfig:18:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:23:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:28:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:33:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:52:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:57:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:70:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:75:warning: choice value used outside its choice group
drivers/staging/ath6kl/Kconfig:80:warning: choice value used outside its choice group
*** Can't find default configuration "arch/arm/configs/imx6s_defconfig"!
make[1]: *** [imx6s_defconfig] Error 1
make: *** [imx6s_defconfig] Error 2
error: Bad exit status from /home/bjornars/imx6/source/ltib-mx6/tmp/rpm-tmp.25122 (%build)
RPM build errors:
Build time for kernel-3.0.35: 1 seconds
Failed building kernel-3.0.35
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Jan 18 09:36:48 2013
Ended: Fri Jan 18 09:36:49 2013
Elapsed: 1 seconds
These packages failed to build:
kernel-3.0.35
Build Failed
Exiting on error or interrupt
Solved! Go to Solution.
Hello,preb & Vishvapathi,
I am using the same ubuntu version(ubuntu 12.04 64 bit), I tested your questions:
(1)Using ltib to compile it .
# cd ~/ltib
# ./ltib -c
Save and Exit, Then ltib begin to compile .
Processing deployment operations
making filesystem image file
staging directory is /home/weidong/L3.0.35_4.0.0_130424/ltib/rootfs.tmp
removing the boot directory and files
removing man files and directories
removing info files
removing /usr/share/locale directory
removing static libraries
removing target rpm database
stripping binaries and libraries
Filesystem stats, including padding:
Total size = 44552k
Total number of files = 1613
Started: Mon Jun 17 21:33:13 2013
Ended: Mon Jun 17 21:35:52 2013
Elapsed: 159 seconds
Build Succeeded
(2)Enter into linux source directory and compile it
# cd ~/ltib
# ./ltib -m prep -p kernel
# ./ltib -m prep -p u-boot
# cd ~/ltib/rpm/BUILD/u-boot-2009.08
# export ARCH=arm
# export CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-
# make mx6solo_sabresd_config
# make
# export PATH=~/ltib/rpm/BUILD/u-boot-2009.08/tools:$PATH
# cd ~/ltib/rpm/BUILD/linux
# make clean
# make imx6s_defconfig
# make uImage
<note: at first, we compile u-boot, because we will use mkimage command to make uImage. then begin to compile linux kernel for imx6s>
Weidong
The path goes wrong.
Same problem for uboot:
Applying ENGR00081147 Support i.MX35 3stack board
* You have some suspicious patch lines:
* In board/freescale/mx35_3stack/lowlevel_init.S
* indent SP followed by a TAB (line 381)
board/freescale/mx35_3stack/lowlevel_init.S:381: mov r3, #0xDA
* indent SP followed by a TAB (line 400)
board/freescale/mx35_3stack/lowlevel_init.S:400: str r3, [r1, #0x100]
+ exit 0
Linux patch error:
Applying ENGR00125411 eMMC: Boot Partition switch func used in MFG tool
Applying ENGR00126228 eMMC: Configure boot_partition_enable
Applying ENGR00133884 eMMC: improve boot_info message output
Applying ENGR00068619 JFFS2 community fix with not use OOB
Applying ENGR00069937 Community patch for Fix mount error in case of MLC flash
Applying Enable partial low interrupt latency mode for ARM1136
Applying tsc2007: fail registration on i2c error
Applying ENGR00112200 Add cryptodev device
Applying ENGR00114911 make video buffer cacheable to improve video performance
Applying cache-l2x0: add enable/disable functions
Applying nand: export symbols needed for stmp3xxx nand nand: increase max nand page and oob sizes
Applying nand: add more nand devices
Applying gadget: gadgetfs changes for MTP support
Applying usb: add ehci otg support
Applying usb: imx usb buffers in iram work-around
Applying usb: Add arc ehci driver to ehci core driver
Applying gadget: add stmp uut support to file storage
Applying ENGR00122206 MX53-EVK pwm-backlight: PWM backlight enhancement
Applying ENGR00122691-1 Add atheros driver ath6kl
* In drivers/net/wireless/ath6kl/bmi/src/bmi.c
* trailing whitespace (line 38)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:38:
* trailing whitespace (line 48)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:48:static A_BOOL pendingEventsFuncCheck = FALSE;
* trailing whitespace (line 56)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:56:
* trailing whitespace (line 82)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:82:
* indent SP followed by a TAB (line 170)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:170: targ_info->target_info_byte_count));
* indent SP followed by a TAB (line 184)
drivers/net/wireless/ath6kl/bmi/src/bmi.c:184: targ_info->target_ver, targ_info->target_type));
Hi Preb,
Did u find out solution for the above mentioned issue??
I am also facing the same....
# cd ~/ltib
# ./ltib -c
removing info files
Total size = 44552k
Build Succeeded
# cd ~/ltib
# export ARCH=arm
# make
# make clean
# make uImage
Weidong
Hi Weidong,
Thanks for your support. finally finished compiling LTIB on Ubuntu 12.04. Copied bootloader, uImage and rootfs files in sdcard as per the LTIB document. When i power ON the EVB connecting via serial port getting below problem.
U-Boot 2009.08 (Jun 19 2013 - 15:09:12) | |
CPU: Freescale i.MX6 family TO1.2 at 792 MHz | |
Thermal sensor with ratio = 189 |
Temperature: 33 C, calibration data 0x5ac4de7d
mx6q pll1: 792MHz | |
mx6q pll2: 528MHz | |
mx6q pll3: 480MHz | |
mx6q pll8: 50MHz | |
ipg clock | : 66000000Hz |
ipg per clock : 66000000Hz
uart clock | : 80000000Hz | |
cspi clock | : 60000000Hz | |
ahb clock | : 132000000Hz | |
axi clock : 264000000Hz | ||
emi_slow clock: 132000000Hz | ||
ddr clock | : 528000000Hz | |
usdhc1 clock : 198000000Hz | ||
usdhc2 clock : 198000000Hz | ||
usdhc3 clock : 198000000Hz | ||
usdhc4 clock : 198000000Hz | ||
nfc clock | : 24000000Hz | |
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ] | ||
Boot Device: SD | ||
I2C: ready | ||
DRAM: 1 GB | ||
MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 | ||
*** Warning - bad CRC or MMC, using default environment | ||
In: | serial | |
Out: serial | ||
Err: serial | ||
Found PFUZE100! deviceid=10,revid=11 | ||
Net: got MAC address from IIM: 00:04:9f:02:6c:a6 | ||
FEC0 [PRIME] | ||
Hit any key to stop autoboot: 0 | ||
PHY indentify @ 0x1 = 0x004dd074 | ||
FEC: Link is down 7949 | ||
Using FEC0 device | ||
TFTP from server 192.168.1.101; our IP address is 192.168.1.103 | ||
Filename 'uImage'. | ||
Load address: 0x10800000 | ||
Loading: FEC: Link is down 7949 | ||
FEC: Link is down 7949 Did i do any mistake while compiling or copying it to SD card?? | ||
Is that the only log you get? ‘Link is Down’ indicates some problem with the Ethernet connection.
Leo
Hello,Vishvapathi,
This is a new question, would you please create a new topic for your question ? It can help other people to find answers easily.
Thanks !
Weidog
