low performance with Clutter on yocto's fsl-image-clutter (Nitrogen6x)
已解决
跳至解决方案
1,427 次查看
roidimor
hey,
i am running yocto's fsl-image-clutter image on boundary devices Nitrogen6x.
i have written a simple Clutter application which draws a few rectanlges on the screen, and when i'm running it, it seems like the performance is extremely low. when running the application with the --clutter-show-fps flag it says the application is running on 1-3 fps.
lsmod mod doesn't list vivante's gpu drivers and 'modprobe galcore' doesn't seem to be doing anything. am i missing something? should i load the drivers or do something else in a different way?
any help would be appreciated!
thanks,
roi.
标记 (4)
1 解答
1,179 次查看
fabio_estevam
Please post this to meta-fsl-arm mailing list, so that someone familiar with Yocto/OpenGLES could try to assist you.
在原帖中查看解决方案
1 回复
1,180 次查看
fabio_estevam
