login error..
login error..
3,380 次查看
MehmetAliIpin
Dear Sir/Madam,
We booted the yocto generated core-image-minimal rootfs with NFS, but got the following error message for login:
imx6dlsabresd login: root
login: can't set groups: Operatio
Freescale i.MX Release Distro 3.14.52-1.1.1 imx6dlsabresd /dev/ttymxc0
I would appreciate any help how to solve this problem..
Best regards.
Mehmet Ali Ipin.
3,164 次查看
Hi Mehmet
what bsp used in the case, please try with Demo Images described on below link
https://www.nxp.com/support/developer-resources/run-time-software/i.mx-developer-resources/i.mx-6ser...
linux sources
linux-imx - i.MX Linux kernel
4 回复数
3,164 次查看
MehmetAliIpin
Dear Igor,
Thank you for your helps, I downloaded image files and extracted fsl-image-validation-imx-xwayland-imxqpdlsolox.tar.bz2 files into my local directory and linked it to /tftpboot/root.
I got  "VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: error mounting -2
Freeing unused kernel memory: 424K (80ae0000 - 80b4a000)
Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance" message.
If you know the solution, could you please tell me what and how to do? where the documentation/init.txt is located?
Thanks and best regards.
Mehmet Ali
3,164 次查看
Hi Mehmet
one can try to use linux documentation (in particular Linux Guide) on
i.MX Software|NXP
Is it working without nfs, for example with sd.
3,164 次查看
MehmetAliIpin
Dear Igor,
I restarted nfs kernel server and everything worked. Now we have a linux working i.mx6 board.
Thank you so much.
with my best regards.
3,165 次查看
Hi Mehmet
linux sources
