location of dtsi files in imx8mplus evk
srinivas_123
what is the path( location ) of dtsi files in yocto, I have searched all folders , I have not seen any dtsi files . is there anyone know where is the actual path of dtsi files in yocto .
i am using
machine :imx8mplus evk
distro :fsl-imx-xwayland
version :LF6.6.3_1.0.0
Thanks &Regards
srinivas
JorgeCas
You can find the device tree source files on the next paths:
- 64 bits.
~/imx-yocto-bsp/<build directory>/tmp/work-shared/<machine>/kernel-source/arch/arm64/boot/dts/freescale
- 32 bits.
~/imx-yocto-bsp/<build directory>/tmp/work-shared/<machine>/kernel-source/arch/arm/boot/dts
Best regards.
