linux-imx-6.6.36+git-r0 do_fetch: Failed to fetch URL
11,090件の閲覧回数
subbuemdtest
I found following error and can't build. Need support
oly@BSP:~/Documents/BSP-Yocto/build-xwayland$ bitbake imx-image-core
NOTE: Your conf/bblayers.conf has been automatically updated.
Loading cache: 100% |############################################| Time: 0:00:18
Loaded 5717 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:04
Parsing of 3642 .bb files complete (3641 cached, 1 parsed). 5718 targets, 388 skipped, 17 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "2.8.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "aarch64-poky-linux"
MACHINE              = "imx8qxpc0mek"
DISTRO               = "fsl-imx-xwayland"
DISTRO_VERSION       = "6.6-scarthgap"
TUNE_FEATURES        = "aarch64 armv8a crc crypto"
TARGET_FPU           = ""
meta
meta-poky            = "HEAD:f43f393ef0246b7bee6eed8bcf8271cf2b8cdf40"
meta-oe
meta-multimedia
meta-python          = "HEAD:80e01188fa822d87d301ee71973c462d7a865493"
meta-freescale       = "HEAD:0f8091c63dd8805610c09b08409bc58492a3b16f"
meta-freescale-3rdparty = "HEAD:6c063450d464eb2f380443c7d9af1b94ce9b9d75"
meta-freescale-distro = "HEAD:b9d6a5d9931922558046d230c1f5f4ef6ee72345"
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-imx-v2x         = "HEAD:6bbf35e73f1b537b19be830462af87a3bd68e1ab"
meta-nxp-demo-experience = "HEAD:8fd7154c05b716e9635279047f65785399432d88"
meta-nxp-matter-baseline
meta-nxp-openthread  = "HEAD:783becb4b5716d989f50db95b7133d38eae5b47b"
meta-arm
meta-arm-toolchain   = "HEAD:1b85bbb4cab9658da3cd926c62038b8559c5c64e"
meta-clang           = "HEAD:fe561f41aef0cff9e6f96730ab59f28dca2eb682"
meta-gnome
meta-networking
meta-filesystems     = "HEAD:80e01188fa822d87d301ee71973c462d7a865493"
meta-qt6             = "HEAD:dc13e1bfda4a4757a08c2d6673bc4bac012c4a80"
meta-parsec
meta-tpm             = "HEAD:11ea91192d43d7c2b0b95a93aa63ca7e73e38034"
meta-virtualization  = "HEAD:6a80f140e387621f62964209a2e07d3bcfb125ce"
Sstate summary: Wanted 120 Local 0 Mirrors 0 Missed 120 Current 4817 (0% match, 97% complete)
Initialising tasks: 100% |#######################################| Time: 0:00:17
NOTE: Executing Tasks
WARNING: linux-imx-6.6.36+git-r0 do_fetch: Failed to fetch URL git://github.com/nxp-imx/linux-imx;protocol=https;branch=lf-6.6.y, attempting MIRRORS if available
WARNING: linux-imx-headers-6.6-r0 do_fetch: Failed to fetch URL git://github.com/nxp-imx/linux-imx.git;protocol=https;branch=lf-6.6.y, attempting MIRRORS if available
ERROR: linux-imx-6.6.36+git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/oly/Documents/BSP-Yocto/sources/poky/scripts:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot/usr/bin/crossscripts:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/sbin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/bin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/sbin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/bin:/home/oly/Documents/BSP-Yocto/sources/poky/bitbake/bin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/hosttools"; export HOME="/home/oly"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all fetch -f --progress https://github.com/nxp-imx/linux-imx refs/heads/*:refs/heads/* refs/tags/*:refs/tags/* failed with exit code 128, see logfile for output
ERROR: linux-imx-6.6.36+git-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/nxp-imx/linux-imx;protocol=https;branch=lf-6.6.y')
ERROR: Logfile of failure stored in: /home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/temp/log.do_fetch.8168
ERROR: Task (/home/oly/Documents/BSP-Yocto/sources/meta-imx/meta-imx-bsp/recipes-kernel/linux/linux-imx_6.6.bb:do_fetch) failed with exit code '1'
12 返答(返信)
11,065件の閲覧回数
Chavira
HI @subbuemdtest!
Thank you for contacting NXP Support!
Try the  next command:
bitbake -c fetch virtual/kernel
 To compile without errors we recommend 4GB of ram for each core of your computer.
You can limit the task to compile adding the next lines to your local.conf file
BB_NUMBER_THREADS = "4"
PARALLEL_MAKE = "-j 4"
Best Regards!
Chavira
11,061件の閲覧回数
subbuemdtest
Hi chavira,
i was followed your instructions still i am facing same issue. Need your support
oly@BSP:~/Documents/BSP-Yocto/build-xwayland$ bitbake -c fetch virtual/kernel
Loading cache: 100% |##########################################################################################################| Time: 0:00:05
Parsing recipes: 100% |########################################################################################################| Time: 0:00:01
Parsing of 3642 .bb files complete (3640 cached, 2 parsed). 5718 targets, 388 skipped, 17 masked, 0 errors.
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Sstate summary: Wanted 0 Local 0 Mirrors 0 Missed 0 Current 1 (0% match, 100% complete)############################# | ETA: 0:00:00
Initialising tasks: 100% |#####################################################################################################| Time: 0:00:00
WARNING: linux-imx-6.6.36+git-r0 do_fetch: Failed to fetch URL git://github.com/nxp-imx/linux-imx.git;protocol=https;branch=lf-6.6.y, attempting MIRRORS if available
ERROR: linux-imx-6.6.36+git-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/oly/Documents/BSP-Yocto/sources/poky/scripts:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot/usr/bin/crossscripts:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/sbin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/usr/bin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/sbin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/recipe-sysroot-native/bin:/home/oly/Documents/BSP-Yocto/sources/poky/bitbake/bin:/home/oly/Documents/BSP-Yocto/build-xwayland/tmp/hosttools"; export HOME="/home/oly"; LANG=C git -c gc.autoDetach=false -c core.pager=cat -c safe.bareRepository=all clone --bare --mirror https://github.com/nxp-imx/linux-imx.git /home/oly/Documents/BSP-Yocto/downloads//git2/github.com.nxp-imx.linux-imx.git --progress failed with exit code 128, see logfile for output
ERROR: linux-imx-6.6.36+git-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/nxp-imx/linux-imx.git;protocol=https;branch=lf-6.6.y')
ERROR: Logfile of failure stored in: /home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/imx8qxpc0mek-poky-linux/linux-imx/6.6.36+git/temp/log.do_fetch.43985
NOTE: Tasks Summary: Attempted 2 tasks of which 1 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
10,999件の閲覧回数
subbuemdtest
Hi @Chavira, Wating for your Valuable Information to Fix issue. Kindly Please Support for the above.
Note: As per my observation problem with the url: https://github.com/nxp-imx/linux-imx/lf-6.6y. Suggest instead of this url can use another?
Subbu
10,990件の閲覧回数
Chavira
HI @subbuemdtest!
The link and the recipe are good.
Try deleting your Yocto project and try with a new one.
10,594件の閲覧回数
subbuemdtest
Hi @Chavira,
I need your support to fix an issue. Previously, I used the command bitbake imx-image-core to build the image, which was for a core image with basic graphics and no multimedia. Now, I want to include multimedia, machine learning, and Qt in the image, so I used a different command. However, I am encountering the following error. Could you please assist in fixing it?
oly@BSP:~/Documents/BSP-Yocto/build-xwayland$ bitbake imx-image-full
Loading cache: 100% |##########################################################################################################| Time: 0:00:04
TARGET_FPU = ""
meta
meta-oe
meta-multimedia
meta-imx-bsp
meta-imx-sdk
meta-imx-ml
meta-arm
meta-gnome
meta-networking
meta-parsec
Sstate summary: Wanted 2547 Local 0 Mirrors 0 Missed 2547 Current 4979 (0% match, 66% complete)##################### | ETA: 0:00:02
Initialising tasks: 100% |#####################################################################################################| Time: 0:00:54
ERROR: abseil-cpp-native-20240116.2-r0 do_unpack: Bitbake Fetcher Error: UnpackError('No up to date source found: clone directory not available or not up to date: /home/oly/Documents/BSP-Yocto/downloads//git2/github.com.abseil.abseil-cpp; shallow clone not enabled', 'git://github.com/abseil/abseil-cpp;branch=lts_2024_01_16;protocol=https')
ERROR: Logfile of failure stored in: /home/oly/Documents/BSP-Yocto/build-xwayland/tmp/work/x86_64-linux/abseil-cpp-native/20240116.2/temp/log.do_unpack.3868
ERROR: Task (virtual:native:/home/oly/Documents/BSP-Yocto/sources/meta-openembedded/meta-oe/recipes-devtools/abseil-cpp/abseil-cpp_20240116.2.bb:do_unpack) failed with exit code '1'
10,553件の閲覧回数
Chavira
HI @subbuemdtest!
Try to use  NEW yocto project for that !
Best Regards!
10,948件の閲覧回数
subbuemdtest
Hi @Chavira,
I am separately trying to clone the link. I am getting below output. could you please provide the steps to fix it.
oly@BSP:~/Documents/BSP-Yocto/build-xwayland$ git clone --depth 1 https://github.com/nxp-imx/linux-imx.git
Cloning into 'linux-imx'...
remote: Enumerating objects: 89165, done.
remote: Counting objects: 100% (89165/89165), done.
remote: Compressing objects: 100% (83810/83810), done.
error: RPC failed; curl 18 transfer closed with outstanding read data remaining
error: 3557 bytes of body are still expected
fetch-pack: unexpected disconnect while reading sideband packet
fatal: early EOF
fatal: fetch-pack: invalid index-pack output
Subbu
10,928件の閲覧回数
Chavira
HI @subbuemdtest!
Try with the command:
$ git clone https://github.com/nxp-imx/linux-imx.git -b lf-6.6.36-2.1.0
If the problem persists try to check your internet connection.
Best Regards!
Chavira
10,899件の閲覧回数
subbuemdtest
Hi @Chavira,
Yes, the issue is with my network. I have downloaded the files separately using the following command:
git clone --branch lf-6.6.y --single-branch https://github.com/nxp-imx/linux-imx.git.
Could you please provide the steps to manually update the files and complete my Yocto build?
Subbu.
10,760件の閲覧回数
Chavira
Hi @subbuemdtest!
The Yocto project is working good.
I recommend to fix your Ethernet connection to compile without errors.
Best Regards!
Chavira
10,702件の閲覧回数
subbuemdtest
Hi @Chavira,
As you Mentioned above I have changed my network connection and now, I have build the image successfully.
Now i want to know whether my Yocto project support PCIe drivers for "imx8qxpc0mek" board? If yes, how to enable the PCIe in Yocto image?
Subbu
10,776件の閲覧回数
subbuemdtest
Hi @Chavira,
Please for the above. Waiting for your response.
Subbu
