lack of cmakelist.text file while bitbake codes for imx8mn wiht QT
steven_zhang
the settiing is
DISTRO=fsl-imx-xwayland MACHINE=imx8mn-ddr4-evk source imx-setup-release.sh -b build-xwayland
bitbake imx-image-full
got:
| CMake Error at /home/steven/imx-yocto-bsp/build-xwayland/tmp/work/cortexa53-crypto-poky-linux/tensorflow-lite/2.6.0-r0/build/xnnpack/CMakeLists.txt:4156 (ADD_SUBDIRECTORY):
| The source directory
| /home/steven/imx-yocto-bsp/build-xwayland/tmp/work/cortexa53-crypto-poky-linux/tensorflow-lite/2.6.0-r0/build/FP16-source
| does not contain a CMakeLists.txt file.
jimmychan
I tried to build it on my side. There is no error occur. Please try to create a new folder to build it again.
jimmychan
Could you tell me which version of BSP are you using?
steven_zhang
it's L5.15.5
jimmychan
steven_zhang
i edit my hosts file by adding the below line,then restarted the netcard by ifconfig command ,
 the compiling of tenserflow is ok 。
i also enoughed  my  disk space to 300G 。
