-lSDL library not found for cross compillation
sanjeevmore
-lSDL library not fond while cross compiling dos box. how to add this library to existing toolchain to cross compile dos box.
Procedure followed:
export PATH=$PATH:/home/sanjeev/Downloads/Toolchains/gcc-linaro-7.3.1-2018.05-i686_arm-linux-gnueabi/bin
CC=arm-linux-gnueabi-gcc CXX=arm-linux-gnueabi-g++ LD=arm-linux-gnueabi-ld ./configure -disable-shared --build=i386-linux --host=arm-linux --target=arm --prefix=/home/sanjeev/dosbox
make
gusarambula
Hello Sanjeev More,
You would need to manually download the SDL libraries and make them available to the compiler.
There is some information on how to do this on the SDL website:
http://wiki.libsdl.org/FrontPage
I hope this helps!
