issue about i.MX6 MFGTool
887件の閲覧回数
宗標廖
Contributor V
Hello Community
My customer is now working with i.MX6DL(custom board) and wants to burn files to eMMC with MFGTool.
They found that on some boards it succeeded and on some other boards it failed.
By analyzing the logs, I found the failed reason is that when MFGTool is copying files to eMMC card, it goes to reset automatically.
So Could you tell me why the MFGTool goes to reset automatically?
I attached the logs of OK case and NG case.
Thank you!
ZongbiaoLiao
Original Attachment has been moved to: NGlog.7z.zip
Original Attachment has been moved to: OKlog.7z.zip
ラベル(2)
759件の閲覧回数
Hi ZongbiaoLiao
issue may be caused by ddr errors or power supplies noise.
One can run ddr test
https://community.freescale.com/docs/DOC-105652
and rebuild mfg tools firmware with updated calibration coefficients.
For power one can check i.MX6 System Development User’s Guide
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
