is it possible to display UI both on LCD & HDMI by imx8mq?
2,029 次查看
kame_li
I know imx8mq support dual display, UI display on LCD, and video display over HDMI. But is it possible to display UI both on LCD & HDMI? Thanks in advance.
标记 (2)
5 回复数
2,011 次查看
Zhiming_Liu
You can see imx8mq-evk-lcdif-adv7535.dts  and imx8mq-evk-dual-display.dts
Zhiming
2,004 次查看
kame_li
Hi Zhiming,
Thanks. I remember that imx8mq-evk-dual-display.dts display UI on LCD and video over HDMI. But what I would like to do is that how to display UI both on LCD& HDMI? Do you have any idea? Many thanks.
1,999 次查看
Zhiming_Liu
Same Dual display  can support in android system i.mxmq A. Linux do not support show same UI.
1,971 次查看
kame_li
Thanks for your reply. And may I ask some more questions? Thanks a lot.
1. Is it possible that weston shows UI on LCD and displays video over HDMI at the same time? And how to do it?
2. Does kmssink (gstreamer plugin) support hotplug? And how to do it? The gstreamer can decode and output video stream over HDMI, but when I unplug HDMI and plug in again, there's nothing output anymore from HDMI.
2,014 次查看
Zhiming_Liu
Yes,it can be.
Zhiming
