iperf3: error - unable to send control message: Bad file descriptor
49,703 次查看
tanoue
Hi.
I would like to measure Wi-Fi throughput with i.MX8M Plus EVK.
I tried to measure it with iperf3 but the following message was shown.
My measurement environment here.
[client]
i.MX8M Plus EVK
iperf 3.9 (cJSON 1.7.13)
IP:192.168.128.125
command:# iperf3 -c 192.168.128.143 -p 5201
[server]
PC:ubuntu 20.04
iperf 3.7 (cJSON 1.5.2)
IP 192.168.128.143
command:# iperf3 -s
On server, I done tcp and udp port openning.
What should I do on client?
Anything else?
Best Regards.
Tanoue.
49,681 次查看
Zhiming_Liu
Please check your  firewall settings
49,682 次查看
Zhiming_Liu
49,653 次查看
tanoue
Hi, @Zhiming_Liu
Sorry, I don't have any information about firewall setting.
Please let me know how to open firewall on i.MX8M Plus EVK?
If possible, also on Ubuntu.
Best Regards.
Tanoue.
49,532 次查看
tanoue
I could run iperf3 after setting firewall.
It's procedure is written the following.
$ iptables -A INPUT -p tcp -i eth0 --dport 5201 -j ACCEPT
$ iptables-save > /etc/iptables/iptables.rules
Thank you, @Zhiming_Liu
Best Regards.
Tanoue
