- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
U-boot : U-Boot 2020.04-5.4.47-2.2.0
Kernel : 5.4.47 (NXP i.MX Release Distro 5.4-zeus)
I am using i.MX8M Mini with the above kernel and u-boot versions with Yocto. My LCD(with ST7701S controller) is working as expectation in kernel.
Now, I want to use it from u-boot. For this i had follow the steps as below :
- Modify "raydium-rm67191.c" file in u-boot (Change command sequence, display timings according to my display)
- Add splash logo add to Env file
- Enable display in dts file
My driver probed successfully. but, I am not able to see anything on display from u-boot. The logs are as follows.
[*]-Video Link 0DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_probe, 534
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_probe, success, 587
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_get_display_timing, Entry, 511
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_get_display_timing, Exit, 525
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_enable_backlight, 499
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_enable_backlight, 504
DEBUG : drivers/video/raydium-rm67191.c, rm67191_enable, 404
DEBUG : drivers/video/raydium-rm67191.c, rad_panel_push_cmd_list, 371
DEBUG : drivers/video/raydium-rm67191.c, rad_panel_push_cmd_list, 390
DEBUG : drivers/video/raydium-rm67191.c, rm67191_enable, 489
(480 x 480)
[0] lcdif@32e00000, video
[1] mipi_dsi@32e10000, video_bridge
[2] rm67191_panel, panel
DEBUG : common/splash.c, splash_display, 168
DEBUG : common/splash.c, splash_display, 173, Screen add : 0x50000000
DEBUG : common/splash.c, splash_screen_prepare, 88
DEBUG : common/splash.c, splash_screen_prepare, 93
DEBUG : common/splash.c, splash_video_logo_load, 64
DEBUG : common/splash.c, splash_video_logo_load, 69, Splashimage : 0x50000000
DEBUG : common/splash.c, splash_video_logo_load, 76
DEBUG : common/splash.c, splash_display, 181
DEBUG : cmd/bmp.c, bmp_display, 245
DEBUG : cmd/bmp.c, bmp_display, 285, Ret : 0
DEBUG : common/splash.c, splash_display, 189
DEBUG : common/splash.c, splash_display_banner, 135
DEBUG : common/splash.c, splash_display_banner, 148
DEBUG : lib/display_options.c, display_options_get_banner_priv, 19
DEBUG : lib/display_options.c, display_options_get_banner_priv, 25, len : 70
DEBUG : lib/display_options.c, display_options_get_banner_priv, 32
In: serial
Any help will be appreciated.
Thanks.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am able to bring up LCD in u-boot by developing my own custom support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm Also trying to use the st7701 with imx8mm-mini, using the standard panel-sitronix-st7701.c from linux-imx with:
but get error:
[ 9.141072] st7701 32e10000.mipi_dsi.0: supply VCC not found, using dummy regulator
[ 9.149611] st7701 32e10000.mipi_dsi.0: supply IOVCC not found, using dummy regulator
[ 9.157606] imx_sec_dsim_drv 32e10000.mipi_dsi: unsupported dsi mode
[ 9.164225] st7701: probe of 32e10000.mipi_dsi.0 failed with error -22
[ 9.170816] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 9.179300] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
anyone has any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello, I had same problem when I worked at my last job. I ended up creating new driver for st7701s. Unfortunately it didn't get accepted into Linux kernel, but we ended up using it anyways. Look here for more:
https://lore.kernel.org/lkml/CA+VMnFyaCWFPWszxen92qKBMX6N9g34+aMA4UCnai9KQzzuf9Q@mail.gmail.com/T/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Hardevsinh_Palaniya
Can you share dts file? What did you enable in kernel config?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you give me some help?
I also use this controller st7701s, but it just doesn't work properly during the uboot phase.
my lcd
480*800 pixel clock:27MHZ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you share what you did to get this to work? Just saying you solved it without any details doesn't help anybody else.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Igor @jamesbone ,
I added new logs for debugging and logs for display are as under :
OF: parent translation for: 00000000 00000000
OF: one level translation: 00000000 0880e232
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_probe, 536
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_probe, 589
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_get_display_timing, 513
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_get_display_timing, 527
OF: translating address: 0000e132
OF: parent translation for: 0000c032
OF: one level translation: 0000e132
OF: one level translation: 00000000 0000e132
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_enable_backlight, 501
lanes 2, channel 0, format 0x0, mode_flags 0x415
sec_mipi_dsim_bridge_clk_set: bitclk 199066 pixclk 16589
hfp_wc 1 hbp_wc 69 hsa_wc 1
DSIM config 0x4a807027
DSIM clkctrl 0x91380002
DEBUG : drivers/video/raydium-rm67191.c, rm67191_panel_enable_backlight, 506
sec_mipi_dsi_host_transfer
0x11
0xff 0x77 0x01 0x00 0x00 0x13
0xef 0x08
0xff 0x77 0x01 0x00 0x00 0x10
0xc0 0xe9 0x03
0xc1 0x10 0x0c
0xc2 0x01 0x0a
0xc3 0x02
0xcc 0x10
0xcd 0x08
0xb0 0x0d 0x14 0x9c 0x0b 0x10 0x06 0x08 0x09 0x08 0x22 0x02 0x4f 0x0e 0x66 0x2d 0x1f
0xb1 0x00 0x17 0x9e 0x0f 0x11 0x06 0x0c 0x08 0x08 0x26 0x04 0x51 0x10 0x6a 0x33 0x1b
0xff 0x77 0x01 0x00 0x00 0x11
0xb0 0x30
0xb1 0x67
0xb2 0x84
0xb3 0x80
0xb5 0x4e
0xb7 0x85
0xb8 0x20
0xc1 0x78
0xc2 0x78
0xd0 0x88
0xe0 0x00 0x00 0x02
0xe1 0x06 0xa0 0x08 0xa0 0x05 0xa0 0x07 0xa0 0x00 0x44 0x44
0xe2 0x30 0x30 0x44 0x44 0x6e 0xa0 0x00 0x00 0x6e 0xa0 0x00 0x00
0xe3 0x00 0x00 0x33 0x33
0xe4 0x44 0x44
0xe5 0x0d 0x69 0x0a 0xa0 0x0f 0x6b 0x0a 0xa0 0x09 0x65 0x0a 0xa0 0x0b 0x67 0x0a 0xa0
0xe6 0x00 0x00 0x33 0x33
0xe7 0x44 0x44
0xe8 0x0c 0x68 0x0a 0xa0 0x0e 0x6a 0x0a 0xa0 0x08 0x64 0x0a 0xa0 0x0a 0x66 0x0a 0xa0
0xe9 0x36 0x00
0xeb 0x00 0x01 0xe4 0xe4 0x44 0x88 0x40
0xed 0xff 0x45 0x67 0xfa 0x01 0x2b 0xcf 0xff 0xff 0xfc 0xb2 0x10 0xaf 0x76 0x54 0xff
0xef 0x10 0x0d 0x04 0x08 0x3f 0x1f
0x3a 0x66
0x11 0x00
0x29 0x00
0x35 0x00
DEBUG : drivers/video/raydium-rm67191.c, rm67191_enable, 491
(480 x 480)
DEBUG : cmd/bmp.c, bmp_display, 258, Ret : 0
DEBUG : cmd/bmp.c, bmp_display, 276, Ret : 0
hdr_size=40, bmp_bpix=8
Display-bmp: 364 x 128 with 256 colours, display 1
video_set_cmap: colours=256
compressed 0 1
DEBUG : cmd/bmp.c, bmp_display, 288, Ret : 0
In: serial
Out: serial
Err: serialBuildInfo:
- ATF c949a88
- U-Boot 2020.04-5.4.47-2.2.0+g66480d52ac
The same commands sequence worked in kernel. But, I am not able to see anything on display from u-boot.
I am stuck here and can not find any solution from community.
Can you please help me to debug the issue or give me any solution to try?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @Igor
Can you please have look on my query?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can somebody help me please? Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
please guide what is getting wrong.
Need urgent help on this.
Thanks in advance.
