imx9352 npu not working
3,074件の閲覧回数
Ethane
I get a system error using npu on imx9352, I don't know how to go about using npu on imx9352.I would like to ask if there is a history of imx9352 using npu's.
My device tree configuration:
ethosu_mem: ethosu_region@C0000000 {
  compatible = "shared-dma-pool";
  reg = <0x0 0xC0000000 0x0 0x10000000>;
  no-map;
ethosu {
  compatible = "arm,ethosu";
  fsl,cm33-proc = <&cm33>;
  memory-region = <&ethosu_mem>;
  power-domains = <&mlmix>;
I use the process as follows:
root@ok-mx93:~# cd /usr/bin/ethosu/examples/
root@ok-mx93:/usr/bin/ethosu/examples# cp ../../tensorflow-lite-2.11.1/examples/labels.txt ./
root@ok-mx93:/usr/bin/ethosu/examples# cp ../../tensorflow-lite-2.11.1/examples/grace_hopper.bmp ./
root@ok-mx93:/usr/bin/ethosu/examples# vela ../../tensorflow-lite-2.11.1/examples/mobilenet_v1_1.0_224_quant.tflite
Network summary for mobilenet_v1_1.0_224_quant
Accelerator configuration Ethos_U65_256
System configuration internal-default
Memory mode internal-default
Accelerator clock 1000 MHz
Design peak SRAM bandwidth 16.00 GB/s
Design peak DRAM bandwidth 3.75 GB/s
Total SRAM used 370.91 KiB
Total DRAM used 3621.95 KiB
CPU operators = 0 (0.0%)
NPU operators = 60 (100.0%)
Average SRAM bandwidth 4.73 GB/s
Input SRAM bandwidth 11.96 MB/batch
Weight SRAM bandwidth 9.70 MB/batch
Output SRAM bandwidth 0.00 MB/batch
Total SRAM bandwidth 21.76 MB/batch
Total SRAM bandwidth per input 21.76 MB/inference (batch size 1)
Average DRAM bandwidth 2.13 GB/s
Input DRAM bandwidth 1.52 MB/batch
Weight DRAM bandwidth 3.23 MB/batch
Output DRAM bandwidth 5.06 MB/batch
Total DRAM bandwidth 9.82 MB/batch
Total DRAM bandwidth per input 9.82 MB/inference (batch size 1)
Neural network macs 572406226 MACs/batch
Network Tops/s 0.25 Tops/s
NPU cycles 3889054 cycles/batch
SRAM Access cycles 1019891 cycles/batch
DRAM Access cycles 1676662 cycles/batch
On-chip Flash Access cycles 0 cycles/batch
Off-chip Flash Access cycles 0 cycles/batch
Total cycles 4602254 cycles/batch
Batch Inference time 4.60 ms, 217.28 inferences/s (batch size 1)
root@ok-mx93:/usr/bin/ethosu/examples# ./inference_runner -n ./output/mobilenet_v1_1.0_224_quant_vela.tflite -i grace_hopper.bmp -l labels.txt -o output.txt
[ 301.631293] remoteproc remoteproc0: powering up imx-rproc
[ 301.638391] remoteproc remoteproc0: Booting fw image ethosu_firmware, size 242424
[ 302.179088] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vdevbuffer@a4020000
[ 302.188504] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 302.196141] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7)
[ 302.203734] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vdevbuffer@a4020000
[ 302.223392] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 302.225441] virtio_rpmsg_bus virtio1: creating channel rpmsg-ethosu-channel addr 0x1e
[ 302.229006] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7)
[ 302.246805] remoteproc remoteproc0: remote processor imx-rproc is now up
Send Ping
Send version request
Send cap[ 302.257522] SError Interrupt on CPU1, code 0x00000000be000011 -- SError
[ 302.257538] CPU: 1 PID: 807 Comm: inference_runne Tainted: G WC 6.1.36 #1
[ 302.257544] Hardware name: Forlinx OK-MX93-C board (DT)
[ 302.257547] pstate: 20400009 (nzCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 302.257552] pc : __memset+0x170/0x188
[ 302.257566] lr : dma_alloc_from_dev_coherent+0xc4/0x154
[ 302.257574] sp : ffff80000ad4bc60
[ 302.257576] x29: ffff80000ad4bc60 x28: ffff000005e51d80 x27: 0000000000000000
[ 302.257585] x26: ffff000004a87900 x25: 000000000000000a x24: 0000000000000000
[ 302.257591] x23: ffff000004a87928 x22: ffff00000908cec0 x21: ffff80000ad4bcf0
[ 302.257597] x20: 0000000000333fc0 x19: ffff800010000000 x18: 0000000000000000
[ 302.257603] x17: 0000000000000000 x16: 0000000000000000 x15: 0000ffffeb1ffee0
[ 302.257608] x14: 0000000000000000 x13: ffff0000043e2008 x12: 0000000000000010
[ 302.257614] x11: 0000000000000400 x10: ffffffffffffffff x9 : 0000000000000000
[ 302.257619] x8 : ffff8000100006c0 x7 : 0000000000000000 x6 : 000000000000003f
[ 302.257624] x5 : 0000000000000040 x4 : 0000000000000000 x3 : 0000000000000004
[ 302.257630] x2 : 00000000003338c0 x1 : 0000000000000000 x0 : ffff800010000000
[ 302.257638] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 302.257640] CPU: 1 PID: 807 Comm: inference_runne Tainted: G WC 6.1.36 #1
[ 302.257644] Hardware name: Forlinx OK-MX93-C board (DT)
[ 302.257646] Call trace:
[ 302.257649] dump_backtrace.part.0+0xe0/0xf0
[ 302.257658] show_stack+0x18/0x30
[ 302.257663] dump_stack_lvl+0x64/0x80
[ 302.257669] dump_stack+0x18/0x34
[ 302.257673] panic+0x180/0x338
[ 302.257677] nmi_panic+0xac/0xb0
[ 302.257682] arm64_serror_panic+0x6c/0x7c
[ 302.257686] do_serror+0x0/0x5c
[ 302.257689] do_serror+0x34/0x5c
[ 302.257693] el1h_64_error_handler+0x30/0x4c
[ 302.257698] el1h_64_error+0x64/0x68
[ 302.257702] __memset+0x170/0x188
[ 302.257707] dma_alloc_attrs+0x5c/0xe4
[ 302.257712] ethosu_buffer_create+0x74/0x2a0
[ 302.257719] ethosu_ioctl+0x1d0/0x280
[ 302.257723] __arm64_sys_ioctl+0xac/0xf0
[ 302.257729] invoke_syscall+0x48/0x114
[ 302.257735] el0_svc_common.constprop.0+0xcc/0xec
[ 302.257740] do_el0_svc+0x2c/0xd0
[ 302.257744] el0_svc+0x2c/0x84
[ 302.257749] el0t_64_sync_handler+0xf4/0x120
[ 302.257754] el0t_64_sync+0x18c/0x190
[ 302.257759] SMP: stopping secondary CPUs
[ 302.257770] Kernel Offset: disabled
[ 302.257771] CPU features: 0x30000,000400a4,6600721b
[ 302.257775] Memory Limit: none
3,037件の閲覧回数
Zhiming_Liu
Your dts node is same as EVK, but EVK has 2GB RAM, i don't know the DDR size on your board.
If your board has 1GB DDR, you can use smaller shared memory pool under NPU.
6 返答(返信)
3,047件の閲覧回数
Zhiming_Liu
Hi @Ethane
Can't reproduce this issue on NXP i.MX93 EVK.
root@imx93evk:/usr/bin/ethosu/examples# cp ../../tensorflow-lite-2.11.1/examples/labels.txt ./
root@imx93evk:/usr/bin/ethosu/examples#  cp ../../tensorflow-lite-2.11.1/examples/grace_hopper.bmp ./
root@imx93evk:/usr/bin/ethosu/examples#  vela ../../tensorflow-lite-2.11.1/examples/mobilenet_v1_1.0_224_quant.tflite
root@imx93evk:/usr/bin/ethosu/examples# uname -a
Linux imx93evk 6.1.36+g04b05c5527e9 #1 SMP PREEMPT Mon Sep  4 21:11:15 UTC 2023 aarch64 GNU/Linux
root@imx93evk:/usr/bin/ethosu/examples# ./inference_runner -n ./output/mobilenet_v1_1.0_224_quant_vela.tflite -i grace_hopper.bmp -l labels.txt -o output.txt
[   85.674752] remoteproc remoteproc0: powering up imx-rproc
[   85.681704] remoteproc remoteproc0: Booting fw image ethosu_firmware, size 242424
[   86.198711] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vdevbuffer@a4020000
[   86.208987] virtio_rpmsg_bus virtio0: rpmsg host is online
[   86.214955] rproc-virtio rproc-virtio.3.auto: registered virtio0 (type 7)
[   86.221865] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node vdevbuffer@a4020000
[   86.235500] virtio_rpmsg_bus virtio1: rpmsg host is online
[   86.241084] virtio_rpmsg_bus virtio1: creating channel rpmsg-ethosu-channel addr 0x1e
[   86.257988] rproc-virtio rproc-virtio.4.auto: registered virtio1 (type 7)
[   86.264856] remoteproc remoteproc0: remote processor imx-rproc is now up
Send Ping
Send capabilities request
Capabilities:
        version_status:1
        version:{ major=0, minor=0, patch=0 }
        product:{ major=6, minor=0, patch=0 }
        architecture:{ major=1, minor=0, patch=6 }
        driver:{ major=0, minor=16, patch=0 }
        macs_per_cc:8
        cmd_stream_version:0
        custom_dma:false
Create network
Create inference
Wait for inferences
Inference status: running
Wait for inference
Inference status: ok
OFM size: 1001
Detected: military uniform, confidence:70
3,042件の閲覧回数
Ethane
I would like to ask if there is something wrong with my device tree configuration?
3,038件の閲覧回数
Zhiming_Liu
2,915件の閲覧回数
Ethane
My board is a 1g ddr, after I set the shared memory pool for the npu to be smaller, it won't get stuck anymore, but it will report the following error, I think it's using evk's firmware, which is incompatible with my own 1g ddr board, what should I do about this?
root@ok-mx93:/usr/bin/ethosu/examples# ./inference_runner -n output/mobilenet_v1_1.0_224_quant_vela.tflite -i grace_hopper.bmp -l labels.txt -o output.txt
[ 58.063151] remoteproc remoteproc0: powering up imx-rproc
[ 58.070435] remoteproc remoteproc0: Booting fw image ethosu_firmware, size 242568
[ 58.080759] remoteproc remoteproc0: Registered carveout doesn't fit len request
[ 58.088171] rproc-virtio: probe of rproc-virtio.0.auto failed with error -12
[ 58.097200] remoteproc remoteproc0: Registered carveout doesn't fit len request
[ 58.105805] rproc-virtio: probe of rproc-virtio.1.auto failed with error -12
[ 58.630656] remoteproc remoteproc0: remote processor imx-rproc is now up
2,908件の閲覧回数
Zhiming_Liu
Hi @Ethane
You need download i.MX93 SDK from this page:
https://mcuxpresso.nxp.com/en/welcome
Then modify the vring base address refering your dts in boards/mcimx93evk/demo_apps/ethosu_apps_rpmsg/board.h. Below codes are from 2GB EVK board.
#define VDEV0_VRING_BASE (0xA4000000U)
#define VDEV1_VRING_BASE (0xA4010000U)
Compile new ethosu_firmware.
2,892件の閲覧回数
Ethane
Problem solved, thank you for your answer!
%3CLINGO-SUB%20id%3D%22lingo-sub-1846744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX9352%20NPU%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1846744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eimx9352%E3%81%A7npu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81imx9352%E3%81%A7npu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82imx9352%E3%81%8Cnpu%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%B1%A5%E6%AD%B4%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%A4%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%3C%2FP%3E%3CP%3Eethosu_mem%3A%20ethosu_region%40C0000000%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22shared-dma-pool%22%3B%3CBR%20%2F%3Ereg%20%3D%20%26lt%3B0x0%200xC0000000%200x0%200x10000000%26gt%3B%3B%3CBR%20%2F%3E%E3%83%9E%E3%83%83%E3%83%97%E3%81%AA%E3%81%97%3B%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A8%E3%83%BC%E3%83%88%E3%82%B9%20%7B%3CBR%20%2F%3Ecompatible%20%3D%20%22arm%2Cethosu%22%3B%3CBR%20%2F%3Efsl%2Ccm33-proc%20%3D%20%26lt%3B%26amp%3Bcm33%26gt%3B%3B%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%20%3D%20%26lt%3B%26amp%3Bethosu_mem%26gt%3B%3B%3CBR%20%2F%3E%E9%9B%BB%E5%8A%9B%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%3D%20%26lt%3B%26amp%3Bmlmix%26gt%3B%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eroot%40ok-MX93%3A~%23%20cd%20%2Fusr%2Fbin%2Fethosu%2Fexamples%2F%3CBR%20%2F%3Eroot%40ok-MX93%3A%2Fusr%2Fbin%2Fethosu%2Fexamples%23%20cp%20..%2F..%2Ftensorflow-lite-2.11.1%2Fexamples%2Flabels.txt%20.%2F%3CBR%20%2F%3Eroot%40ok-MX93%3A%2Fusr%2Fbin%2Fethosu%2Fexamples%23%20cp%20..%2F..%2Ftensorflow-lite-2.11.1%2Fexamples%2Fgrace_hopper.bmp%20.%2F%3CBR%20%2F%3Eroot%40ok-MX93%3A%2Fusr%2Fbin%2Fethosu%2Fexamples%23%20vela%20..%2F..%2Ftensorflow-lite-2.11.1%2Fexamples%2Fmobilenet_v1_1.0_224_quant.tflite%3C%2FP%3E%3CP%3Emobilenet_v1_1.0_224_quant%20%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%A6%82%E8%A6%81%3CBR%20%2F%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%BF%E6%A7%8B%E6%88%90Ethos_U65_256%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E6%88%90%20internal-default%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%A2%E3%83%BC%E3%83%89%20internal-default%3CBR%20%2F%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%201000%20MHz%3CBR%20%2F%3E%E8%A8%AD%E8%A8%88%E3%83%94%E3%83%BC%E3%82%AF%20SRAM%20%E5%B8%AF%E5%9F%9F%E5%B9%85%2016.00%20GB%2Fs%3CBR%20%2F%3E%E8%A8%AD%E8%A8%88%E3%83%94%E3%83%BC%E3%82%AF%20DRAM%20%E5%B8%AF%E5%9F%9F%E5%B9%85%203.75%20GB%2Fs%3C%2FP%3E%3CP%3ESRAM%E4%BD%BF%E7%94%A8%E7%B7%8F%E6%95%B0%20370.91KiB%3CBR%20%2F%3EDRAM%E4%BD%BF%E7%94%A8%E7%B7%8F%E6%95%B0%203621.95KiB%3C%2FP%3E%3CP%3ECPU%20%E6%BC%94%E7%AE%97%E5%AD%90%20%3D%200%20(0.0%25)%3CBR%20%2F%3ENPU%20%E6%BC%94%E7%AE%97%E5%AD%90%20%3D%2060%20(100.0%25)%3C%2FP%3E%3CP%3E%E5%B9%B3%E5%9D%87SRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%204.73%20GB%2Fs%3CBR%20%2F%3E%E5%85%A5%E5%8A%9BSRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%2011.96%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E9%87%8D%E9%87%8F%20SRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%209.70%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E5%87%BA%E5%8A%9BSRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%3A0.00MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3ESRAM%E3%81%AE%E5%90%88%E8%A8%88%E5%B8%AF%E5%9F%9F%E5%B9%85%2021.76%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E3%81%82%E3%81%9F%E3%82%8A%E3%81%AE%E5%90%88%E8%A8%88SRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%3A21.76%20MB%2F%E6%8E%A8%E8%AB%96(%E3%83%90%E3%83%83%E3%83%81%E3%82%B5%E3%82%A4%E3%82%BA1)%3C%2FP%3E%3CP%3E%E5%B9%B3%E5%9D%87DRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%202.13%20GB%2F%E7%A7%92%3CBR%20%2F%3E%E5%85%A5%E5%8A%9BDRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%201.52%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E9%87%8D%E9%87%8F%20DRAM%E5%B8%AF%E5%9F%9F%E5%B9%85%203.23%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E5%87%BA%E5%8A%9B%20DRAM%20%E5%B8%AF%E5%9F%9F%E5%B9%85%205.06%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3EDRAM%E3%81%AE%E5%90%88%E8%A8%88%E5%B8%AF%E5%9F%9F%E5%B9%85%209.82%20MB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E3%81%82%E3%81%9F%E3%82%8A%E3%81%AE%E5%90%88%E8%A8%88%20DRAM%20%E5%B8%AF%E5%9F%9F%E5%B9%85%209.82%20MB%2F%E6%8E%A8%E8%AB%96%20(%E3%83%90%E3%83%83%E3%83%81%20%E3%82%B5%E3%82%A4%E3%82%BA%201)%3C%2FP%3E%3CP%3E%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AFmac%20572406226%20MAC%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%2F%E7%A7%92%200.25%20%E3%83%88%E3%83%83%E3%83%97%2F%E7%A7%92%3C%2FP%3E%3CP%3ENPU%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB3889054%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3ESRAM%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB1019891%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3EDRAM%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB1676662%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E3%82%AA%E3%83%B3%E3%83%81%E3%83%83%E3%83%97%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A0%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E3%82%AA%E3%83%95%E3%83%81%E3%83%83%E3%83%97%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3A%200%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3CBR%20%2F%3E%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB4602254%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%2F%E3%83%90%E3%83%83%E3%83%81%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%81%E6%8E%A8%E8%AB%96%E6%99%82%E9%96%93%204.60%20ms%E3%80%81217.28%20%E6%8E%A8%E8%AB%96%2F%E7%A7%92%20(%E3%83%90%E3%83%83%E3%83%81%20%E3%82%B5%E3%82%A4%E3%82%BA%201)%3CBR%20%2F%3Eroot%40ok-MX93%3A%2Fusr%2Fbin%2Fethosu%2Fexamples%23%20.%2Finference_runner-n%20.%2Foutput%2Fmobilenet_v1_1.0_224_quant_vela.tflite%20-i%20grace_hopper.bmp%20-l%20labels.txt%20-o%20output.txt%3CBR%20%2F%3E%5B%20301.631293%5D%20remoteproc%20remoteproc0%3A%20imx-rproc%20%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%3CBR%20%2F%3E%5B%20301.638391%5D%20remoteproc%20remoteproc0%3A%20fw%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20ethosu_firmware%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%20242424%20%E3%81%AE%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E%5B%20302.179088%5D%20rproc-virtio%20rproc-virtio.0.auto%3A%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%8E%E3%83%BC%E3%83%89%20ID%20%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8Cvdevbuffer%40a4020000%3CBR%20%2F%3E%5B%20302.188504%5D%20virtio0%20virtio_rpmsg_bus%3A%20rpmsg%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8C%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%20302.196141%5D%20rproc-virtio%20rproc-virtio.0.auto%3A%20virtio0%20%E3%82%92%E7%99%BB%E9%8C%B2%20(%E3%82%BF%E3%82%A4%E3%83%97%207)%3CBR%20%2F%3E%5B%20302.203734%5D%20rproc-virtio%20rproc-virtio.1.auto%3A%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%8E%E3%83%BC%E3%83%89%20vdevbuffer%40a4020000%3CBR%20%2F%3E%5B%20302.223392%5D%20virtio_rpmsg_bus%20virtio1%3A%20rpmsg%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%8C%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%20302.225441%5D%20virtio_rpmsg_bus%20virtio1%3A%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20rpmsg-ethosu-channel%20addr%200x1e%E3%81%AE%E4%BD%9C%E6%88%90%3CBR%20%2F%3E%5B%20302.229006%5D%20rproc-virtio%20rproc-virtio.1.auto%3Avirtio1%20(%E3%82%BF%E3%82%A4%E3%83%97%207)%20%E3%81%AB%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%20302.246805%5D%20remoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20imx-rproc%20%E3%81%8C%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EPing%E3%81%AE%E9%80%81%E4%BF%A1%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E8%A6%81%E6%B1%82%E3%81%AE%E9%80%81%E4%BF%A1%3CBR%20%2F%3E%E3%82%BB%E3%83%B3%E3%83%89%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%5B%20302.257522%20%5DCPU1%20%E3%81%AE%20SError%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%200x00000000be000011%20--%20SError%3CBR%20%2F%3E%5B%20302.257538%5D%20CPU%3A1%20PID%3A807%20%E9%80%9A%E4%BF%A1%3Ainference_runne%20%E6%B1%9A%E6%9F%93%3AG%20WC%206.1.36%231%3CBR%20%2F%3E%5B%20302.257544%20%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3AForlinx%20OK-MX93-C%E3%83%9C%E3%83%BC%E3%83%89(DT)%3CBR%20%2F%3E%5B%20302.257547%5D%20pstate%3A%2020400009%20(nzCv%20daif%20%2BPAN%20-UAO%20-TCO%20-DIT%20-SSBS%20BTYPE%3D--)%3CBR%20%2F%3E%5B%20302.257552%5D%20%E3%83%91%E3%82%BD%E3%82%B3%E3%83%B3%3A__memset%2B0x170%2F0x188%3CBR%20%2F%3E%5B%20302.257566%5D%20LR%E7%95%AA%E5%8F%B7%3Adma_alloc_from_dev_coherent%2B0xc4%2F0x154%3CBR%20%2F%3E%5B%20302.257574%5D%20SP%20%3A%20ffff80000AD4BC60%3CBR%20%2F%3E%5B%20302.257576%5D%20x29%3A%20ffff80000ad4bc60%20x28%3A%20ffff000005e51d80%20x27%3A%200000000000000000000%3CBR%20%2F%3E%5B%20302.257585%5D%20x26%3A%20ffff000004a87900%20x25%3A%20000000000000000a%20x24%3A%2000000000000000000000000000%3CBR%20%2F%3E%5B%20302.257591%5D%20x23%3A%20ffff000004a87928%20x22%3A%20ffff00000908cec0%20x21%3A%20ffff80000ad4bcf0%3CBR%20%2F%3E%5B%20302.257597%20%5D%20x20%3A%200000000000333fc0%20x19%3A%20ffff800010000000%20x18%3A%20000000000000000000%3CBR%20%2F%3E%5B%20302.257603%20%5D%20x17%3A%200000000000000000000%20x16%3A%200000000000000000000000%20x15%3A%200000ffffeb1ffee0%3CBR%20%2F%3E%5B%20302.257608%5D%20x14%3A%200000000000000000000%20x13%3A%20ffff0000043e2008%20x12%3A%200000000000000010%3CBR%20%2F%3E%5B%20302.257614%5D%20x11%3A%200000000000000400%20x10%3A%20ffffffff%20x9%20%3A%20000000000000000000000000%3CBR%20%2F%3E%5B%20302.257619%5D%20x8%20%3A%20ffff8000100006c0%20x7%20%3A%2000000000000000000%20x6%20%3A%20000000000000003f%3CBR%20%2F%3E%5B%20302.257624%5D%20x5%20%3A%200000000000000040%20x%204%20%3A%2000000000000000000%20x3%20%3A%200000000000000004%3CBR%20%2F%3E%5B%20302.257630%5D%20x2%20%3A%2000000000003338c0%20x1%20%3A%2000000000000000000%20x0%20%3A%20ffff800010000000%3CBR%20%2F%3E%5B%20302.257638%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%20-%20%E5%90%8C%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%3A%20%E9%9D%9E%E5%90%8C%E6%9C%9FSError%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%20302.257640%5D%20CPU%3A1%20PID%3A807%20%E9%80%9A%E4%BF%A1%3Ainference_runne%20%E6%B1%9A%E6%9F%93%3AG%20WC%206.1.36%231%3CBR%20%2F%3E%5B%20302.257644%20%5D%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%90%8D%3AForlinx%20OK-MX93-C%E3%83%9C%E3%83%BC%E3%83%89(DT)%3CBR%20%2F%3E%5B%20302.257646%5D%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%3A%3CBR%20%2F%3E%5B%20302.257649%5D%20dump_backtrace.part.0%2B0xe0%2F0xf0%3CBR%20%2F%3E%5B%20302.257658%5D%20show_stack%2B0x18%2F0x30%3CBR%20%2F%3E%5B%20302.257663%5D%20dump_stack_lvl%2B0x64%2F0x80%3CBR%20%2F%3E%5B%20302.257669%5D%20dump_stack%2B0x18%2F0x34%3CBR%20%2F%3E%5B%20302.257673%5D%20%E3%83%91%E3%83%8B%E3%83%83%E3%82%AF%2B0x180%2F0x338%3CBR%20%2F%3E%5B%20302.257677%5D%20nmi_panic%2B0xac%2F0xb0%3CBR%20%2F%3E%5B%20302.257682%5D%20arm64_serror_panic%2B0x6c%2F0x7c%3CBR%20%2F%3E%5B%20302.257686%5D%20do_serror%2B0x0%2F0x5c%3CBR%20%2F%3E%5B%20302.257689%5D%20do_serror%2B0x34%2F0x5c%3CBR%20%2F%3E%5B%20302.257693%5D%20el1h_64_error_handler%2B0x30%2F0x4c%3CBR%20%2F%3E%5B%20302.257698%5D%20el1h_64_error%2B0x64%2F0x68%3CBR%20%2F%3E%5B%20302.257702%5D%20__memset%2B0x170%2F0x188%3CBR%20%2F%3E%5B%20302.257707%5D%20dma_alloc_attrs%2B0x5c%2F0xe4%3CBR%20%2F%3E%5B%20302.257712%5D%20ethosu_buffer_create%2B0x74%2F0x2a0%3CBR%20%2F%3E%5B%20302.257719%5D%20ethosu_ioctl%2B0x1d0%2F0x280%3CBR%20%2F%3E%5B%20302.257723%5D%20__arm64_sys_ioctl%2B0xac%2F0xf0%3CBR%20%2F%3E%5B%20302.257729%5D%20invoke_syscall%2B0x48%2F0x114%3CBR%20%2F%3E%5B%20302.257735%5D%20el0_svc_common.constprop.0%2B0xcc%2F0xec%3CBR%20%2F%3E%5B%20302.257740%5D%20do_el0_svc%2B0x2c%2F0xd0%3CBR%20%2F%3E%5B%20302.257744%5D%20el0_svc%2B0x2c%2F0x84%3CBR%20%2F%3E%5B%20302.257749%5D%20el0t_64_sync_handler%2B0xf4%2F0x120%3CBR%20%2F%3E%5B%20302.257754%5D%20el0t_64_sync%2B0x18c%2F0x190%3CBR%20%2F%3E%5B%20302.257759%5D%20SMP%3A%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AACPU%E3%81%AE%E5%81%9C%E6%AD%A2%3CBR%20%2F%3E%5B%20302.257770%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E%5B%20302.257771%5D%20CPU%E6%A9%9F%E8%83%BD%3A0x30000%2C000400a4%2C6600721b%3CBR%20%2F%3E%5B%20302.257775%5D%20%E3%83%A1%E3%83%A2%E3%83%AA%E5%88%B6%E9%99%90%3A%E3%81%AA%E3%81%97%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx9352%20npu%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%AD%94%E3%81%88%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx9352%20npu%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF1g%20ddr%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81npu%E3%81%AE%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%B0%8F%E3%81%95%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%81evk%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AE1g%20DDR%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eroot%40ok-MX93%3A%2Fusr%2Fbin%2Fethosu%2Fexamples%23%20.%2Finference_runner-n%20%E5%87%BA%E5%8A%9B%2Fmobilenet_v1_1.0_224_quant_vela.tflite%20-i%20grace_hopper.bmp%20-l%20labels.txt%20-o%20output.txt%3CBR%20%2F%3E%5B%2058.063151%5D%20remoteproc%20remoteproc0%3A%20imx-rproc%20%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%3CBR%20%2F%3E%5B%2058.070435%5D%20remoteproc%20remoteproc0%3A%20fw%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20ethosu_firmware%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%20242568%20%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2058.080759%5D%20remoteproc%20remoteproc0%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%96%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%20len%20%E8%A6%81%E6%B1%82%E3%81%AB%E9%81%A9%E5%90%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2058.088171%5D%20rproc-virtio%3A%20rproc-virtio.0.auto%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-12%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2058.097200%5D%20remoteproc%20remoteproc0%3A%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%96%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%20len%20%E8%A6%81%E6%B1%82%E3%81%AB%E9%81%A9%E5%90%88%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B%2058.105805%5D%20rproc-virtio%3Arproc-virtio.1.auto%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%82%A8%E3%83%A9%E3%83%BC%20-12%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2058.630656%5D%20remoteproc%20remoteproc0%3A%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20imx-rproc%20%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1847601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx9352%20npu%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1847601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEdts%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AFEVK%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81EVK%E3%81%AB%E3%81%AF2GB%E3%81%AERAM%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEDDR%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%201GB%20%E3%81%AE%20DDR%20%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81NPU%20%E3%81%A7%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%AA%E5%85%B1%E6%9C%89%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1847599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx9352%20npu%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1847599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%8A%E8%81%9E%E3%81%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%3F%3C%2FLINGO-BODY%3E
