@ranYang You ask if @pengyong_zhang is useful? @pengyong_zhang doesn't even know if its own BSP supports DVFS or not.
What's most disappointing is that @pengyong_zhang hasn't even tried the commands given.
@ranYang The iMX93 BSP only supports mode switching and does not support DVFS, so there is no /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor node.
You can use the cat /sys/kernel/debug/clk/clk_summary to check the arm clock.
