HI;
I am using version L4.14.98,and now I have this problem。But I am using the latest version L5.4.47 and there is no problem。and now,I must now use version L4.14.98。
SD card(mmc1) and EMMC (mmc0)are both unusable
[ 13.171698] mmc0: Timeout waiting for hardware interrupt.
[ 13.177108] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 13.183557] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 13.190003] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
[ 13.196447] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 13.202893] mmc0: sdhci: Present: 0x01fd8a0a | Host ctl: 0x00000011
[ 13.209340] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 13.215785] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x000020ff
[ 13.222232] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 13.228678] mmc0: sdhci: Int enab: 0x107f100b | Sig enab: 0x107f100b
[ 13.235125] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000502
[ 13.241571] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 13.248018] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00ffffff
[ 13.254464] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 13.260908] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d02701
[ 13.267355] mmc0: sdhci: Host ctl2: 0x00000000
[ 13.271804] mmc0: sdhci: ADMA Err: 0x00000009 | ADMA Ptr: 0xfffff200
[ 13.278246] mmc0: sdhci: ============================================
[ 13.284817] mmc0: error -110 whilst initialising MMC card
[ 13.427686] mmc1: Timeout waiting for hardware interrupt.
[ 13.433091] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 13.439539] mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00000002
[ 13.445985] mmc1: sdhci: Blk size: 0x00000008 | Blk cnt: 0x00000001
[ 13.452429] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 13.458877] mmc1: sdhci: Present: 0x01f88a0a | Host ctl: 0x00000011
[ 13.465323] mmc1: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 13.471769] mmc1: sdhci: Wake-up: 0x00000008 | Clock: 0x000010ff
[ 13.478215] mmc1: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 13.484659] mmc1: sdhci: Int enab: 0x107f100b | Sig enab: 0x107f100b
[ 13.491108] mmc1: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000502
[ 13.497552] mmc1: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 13.503998] mmc1: sdhci: Cmd: 0x0000333a | Max curr: 0x00ffffff
[ 13.510446] mmc1: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x00e7177f
[ 13.516892] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[ 13.523335] mmc1: sdhci: Host ctl2: 0x00000008
[ 13.527777] mmc1: sdhci: ADMA Err: 0x00000009 | ADMA Ptr: 0xffffe200
[ 13.534220] mmc1: sdhci: ============================================
[ 13.540737] mmc1: error -110 whilst initialising SD card
Hello songhongliang,
You can move you dtb from 5.4.47 to your BSP or try the solution provided:
