imx8plus dsp
imx8plus dsp
wtking
Hello, nxp developers
Can anyone confirm that hifi4 dap can be used as common dsp? I want use it for sensor data calculation.
By the way, can uart be sxtended?We need 5 uart, but 8mplus datasheet say there are only 4.
thanks!
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
DSPs are used through their firmware, please refer to https://www.nxp.com/docs/en/user-guide/IMX_DSP_USERS_GUIDE.pdf.
I found the chapter about NatureDSP Library Support, is the library that matches the common operations of a DSP.
Used signal processing functions: FFT, FIR, vector, matrix, and common mathematics.
For UART expansion, you could either look for multiplexer/bridges or simulate a UART from GPIO, that development would be up to you.
JosephAtNXP
wtking
Thank you very much for your reply. We will take a detailed look at the PDF.Sincere thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2054311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8plus%20dsp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2054311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20nxp%20developers%3C%2FP%3E%3CP%3ECan%20anyone%20confirm%20that%20hifi4%20dap%20can%20be%20used%20as%20common%20dsp%EF%BC%9F%20I%20want%20use%20it%20for%20sensor%20data%20calculation.%3C%2FP%3E%3CP%3EBy%20the%20way%2C%20can%20uart%20be%20sxtended%EF%BC%9FWe%20need%205%20uart%2C%20but%208mplus%20datasheet%20say%20there%20are%20only%204.%3C%2FP%3E%3CP%3Ethanks%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2054311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8plus%20dsp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20very%20much%20for%20your%20reply.%20We%20will%20take%20a%20detailed%20look%20at%20the%20PDF.Sincere%20thanks.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2055007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8plus%20dsp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20Semiconductor%20products%2C%3C%2FP%3E%0A%3CP%3EDSPs%20are%20used%20through%20their%20firmware%2C%20please%20refer%20to%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_DSP_USERS_GUIDE.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_DSP_USERS_GUIDE.pdf%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EI%20found%20the%20chapter%20about%20NatureDSP%20Library%20Support%2C%20is%20the%20library%20that%20matches%20the%20common%20operations%20of%20a%20DSP.%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3EUsed%20signal%20processing%20functions%3A%20FFT%2C%20FIR%2C%20vector%2C%20matrix%2C%20and%20common%20mathematics.%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3EFor%20UART%20expansion%2C%20you%20could%20either%20look%20for%20multiplexer%2Fbridges%20or%20simulate%20a%20UART%20from%20GPIO%2C%20that%20development%20would%20be%20up%20to%20you.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
