imx8mqevk:Accessing GPT1 memory hangs the system
RobinP
Hi, I am having a issue with a kernel module that accesses GPT. When configured to use GPT2 the module loads and unloads without issue, but when configured to use GPT1 the system hangs when trying to readl the control register at the base address (0x302D0000).
Do you have any ideas or suggestions as to what is causing this?
Robin
