Hi : I just face the problem. When i using the mfgtool to download image to flash image. But occur error. Have any suggestion to me ?
I have capture error msg below:
U-Boot 2017.03-svn157 (Jul 24 2018 - 17:56:13 +0800)
CPU: Freescale i.MX8MQ rev2.0 1500 MHz (running at 1000 MHz)
CPU: Commercial temperature grade (0C to 95C) at 46C
Reset cause: POR
Model: InnoComm i.MX8MQ Wibo board
I2C: ready
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
MMC: no card present
mmc_init: -123, time 2
*** Warning - MMC init failed, using default environment
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF 6a83ae0
- U-Boot 2017.03-svn157
mmc_init: -123, time 1
Net:
Warning: ethernet@30be0000 using MAC address from ROM
eth0: ethernet@30be0000
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: run mfgtool_args;booti ${loadaddr} ${initrd_addr} ${fdt_addr};
Hit any key to stop autoboot: 0
## Loading init Ramdisk from Legacy Image at 43800000 ...
Image Name: fsl-image-mfgtool-initramfs-imx8
Image Type: AArch64 Linux RAMDisk Image (uncompressed)
Data Size: 8944215 Bytes = 8.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Using Device Tree in place at 0000000043000000, end 000000004300e173
Found /hdmi@32c00000 node
Modify /hdmi@32c00000:status disabled
Found /display-subsystem node
Modify /display-subsystem:status disabled
Found /sound-hdmi node
Modify /sound-hdmi:status disabled
Found /usb@38100000/dwc3 node
Modify /usb@38100000/dwc3:maximum-speed = high-speed
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.78-svn163 (ipc173@ipc173-D830MT) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT8
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '115200,115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000046000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffff80007ff66000 s48640 r8192 d29184 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515840
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200,115200 rdinit=/linuxrc g_mass_stord
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14376(87%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1964572K/2096128K available (12540K kernel code, 1370K rwdata, 5184K rodata, 1152K init, 374K bss, 66020K )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008cc0000 ( 12544 KB)
[ 0.000000] .rodata : 0xffff000008cc0000 - 0xffff0000091e0000 ( 5248 KB)
[ 0.000000] .init : 0xffff0000091e0000 - 0xffff000009300000 ( 1152 KB)
[ 0.000000] .data : 0xffff000009300000 - 0xffff000009456a00 ( 1371 KB)
[ 0.000000] .bss : 0xffff000009456a00 - 0xffff0000094b43a0 ( 375 KB)
[ 0.000000] fixed : 0xffff7dfffe7fb000 - 0xffff7dfffec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0002000000 ( 32 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff800080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MQ clock driver init done
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.000003] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.008234] system counter timer init
[ 0.011723] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.019709] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.030355] Console: colour dummy device 80x25
[ 0.034464] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044734] pid_max: default: 32768 minimum: 301
[ 0.049409] Security Framework initialized
[ 0.053491] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.060175] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.068072] sched-energy: CPU device node has no sched-energy-costs
[ 0.073612] Invalid sched_group_energy for CPU0
[ 0.078137] CPU0: update cpu_capacity 1024
[ 0.082239] ASID allocator initialised with 32768 entries
[ 0.120496] Cannot find MU entry in device tree
[ 0.122283] CPU identified as i.MX8MQ, silicon rev 2.0
[ 0.127431] EFI services will not be available.
[ 0.180065] Detected VIPT I-cache on CPU1
[ 0.180093] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.180126] Invalid sched_group_energy for CPU1
[ 0.180129] CPU1: update cpu_capacity 1024
[ 0.180132] CPU1: Booted secondary processor [410fd034]
[ 0.212129] Detected VIPT I-cache on CPU2
[ 0.212152] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.212182] Invalid sched_group_energy for CPU2
[ 0.212185] CPU2: update cpu_capacity 1024
[ 0.212188] CPU2: Booted secondary processor [410fd034]
[ 0.244208] Detected VIPT I-cache on CPU3
[ 0.244229] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.244261] Invalid sched_group_energy for CPU3
[ 0.244266] CPU3: update cpu_capacity 1024
[ 0.244268] CPU3: Booted secondary processor [410fd034]
[ 0.244479] Brought up 4 CPUs
[ 0.318878] SMP: Total of 4 processors activated.
[ 0.323595] CPU features: detected feature: GIC system register CPU interface
[ 0.330747] CPU features: detected feature: 32-bit EL0 Support
[ 0.336921] CPU: All CPU(s) started at EL2
[ 0.340848] alternatives: patching kernel code
[ 0.345299] Invalid sched_group_energy for CPU3
[ 0.349668] Invalid sched_group_energy for Cluster3
[ 0.354548] Invalid sched_group_energy for CPU2
[ 0.359082] Invalid sched_group_energy for Cluster2
[ 0.363965] Invalid sched_group_energy for CPU1
[ 0.368500] Invalid sched_group_energy for Cluster1
[ 0.373385] Invalid sched_group_energy for CPU0
[ 0.377917] Invalid sched_group_energy for Cluster0
[ 0.383368] devtmpfs: initialized
[ 0.393614] DMI not present or invalid.
[ 0.395031] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.404377] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.412684] pinctrl core: initialized pinctrl subsystem
[ 0.417537] NET: Registered protocol family 16
[ 0.440388] cpuidle: using governor menu
[ 0.442185] vdso: 2 pages (1 code @ ffff000008cc7000, 1 data @ ffff000009304000)
[ 0.448886] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.459820] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.464623] Serial: AMBA PL011 UART driver
[ 0.473745] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.531433] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.544202] ACPI: Interpreter disabled.
[ 0.547947] mxs-dma 33000000.dma-apbh: initialized
[ 0.552091] vgaarb: loaded
[ 0.553247] SCSI subsystem initialized
[ 0.557672] usbcore: registered new interface driver usbfs
[ 0.562030] usbcore: registered new interface driver hub
[ 0.567733] usbcore: registered new device driver usb
[ 0.576557] bd71837 0-004b: Device ID=0xA2
[ 0.577796] bd71837 0-004b: gpio_intr = 7
[ 0.581977] bd71837 0-004b: chip_irq=47
[ 0.594061] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.622350] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.654450] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.678527] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.702605] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.726680] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.750756] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.774850] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.798922] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.818924] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.826922] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.847050] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.867051] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.882846] random: fast init done
[ 0.887154] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.907167] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.967327] i2c i2c-0: IMX I2C adapter registered
[ 0.969181] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.974970] media: Linux media interface: v0.10
[ 0.979125] Linux video capture interface: v2.00
[ 0.983969] pps_core: LinuxPPS API ver. 1 registered
[ 0.988689] BD71837:bd71837_pmic_interrupt() in.
[ 0.993250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.002704] PTP clock support registered
[ 1.006385] BD71837:IRQ_WDOG
[ 1.006657] dmi: Firmware registration failed.
[ 1.006723] Linux cec interface: v0.10
[ 1.007074] MU is ready for cross core communication!
[ 1.010058] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1.010119] imx rpmsg driver is registered.
[ 1.010247] Advanced Linux Sound Architecture Driver Initialized.
[ 1.010739] Bluetooth: Core ver 2.22
[ 1.010761] NET: Registered protocol family 31
[ 1.010764] Bluetooth: HCI device and connection manager initialized
[ 1.010771] Bluetooth: HCI socket layer initialized
[ 1.010776] Bluetooth: L2CAP socket layer initialized
[ 1.010793] Bluetooth: SCO socket layer initialized
[ 1.013678] clocksource: Switched to clocksource arch_sys_counter
[ 1.013891] VFS: Disk quotas dquot_6.6.0
[ 1.013932] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.084482] BD71837:IRQ_ON_REQ
[ 1.087689] pnp: PnP ACPI: disabled
[ 1.111254] NET: Registered protocol family 2
[ 1.113302] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.120217] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.126996] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.133268] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.139235] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.145856] NET: Registered protocol family 1
[ 1.150938] RPC: Registered named UNIX socket transport module.
[ 1.155989] RPC: Registered udp transport module.
[ 1.160641] RPC: Registered tcp transport module.
[ 1.165403] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.171951] Unpacking initramfs...
[ 1.632636] Freeing initrd memory: 8728K
[ 1.634353] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.641925] kvm [1]: 8-bit VMID
[ 1.644607] kvm [1]: IDMAP page: 40cb2000
[ 1.648642] kvm [1]: HYP VA range: 800000000000:ffffffffffff
[ 1.655170] kvm [1]: Hyp mode initialized successfully
[ 1.659500] kvm [1]: GICv3: no GICV resource entry
[ 1.664291] kvm [1]: disabling GICv2 emulation
[ 1.668801] kvm [1]: GIC system register CPU interface enabled
[ 1.674889] kvm [1]: vgic interrupt IRQ1
[ 1.678465] kvm [1]: virtual timer IRQ4
[ 1.689034] audit: initializing netlink subsys (disabled)
[ 1.691691] audit: type=2000 audit(1.571:1): initialized
[ 1.698230] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 1.715810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.720008] NFS: Registering the id_resolver key type
[ 1.723933] Key type id_resolver registered
[ 1.728407] Key type id_legacy registered
[ 1.732105] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.738846] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 1.745526] 9p: Installing v9fs 9p2000 file system support
[ 1.766704] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.771269] io scheduler noop registered
[ 1.775410] io scheduler cfq registered (default)
[ 1.781724] libphy: mdio_driver_register: phy-bcm-ns2-pci
[ 1.794162] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 1.799819] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 1.805522] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.811134] imx-sdma 302c0000.sdma: loaded firmware 4.2
[ 1.821505] Bus freq driver module loaded
[ 1.824784] xenfs: not registering filesystem on non-xen platform
[ 1.838259] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
%�F) driver initializedH)
[ 1.849315] console [ttymxc0] enabled
[ 1.853065] bootconsole [ec_imx6q0] disabled
[ 1.858105] msm_serial: driver initialized
[ 1.864504] [drm] Initialized
[ 1.879950] loop: module loaded
[ 1.884816] hisi_sas: driver version v1.6
[ 1.891487] slram: not enough parameters.
[ 1.898147] libphy: Fixed MDIO Bus: probed
[ 1.902597] tun: Universal TUN/TAP device driver, 1.6
[ 1.907663] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.914225] CAN device driver interface
[ 1.919750] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.925600] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.931688] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.938665] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.944402] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.952247] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.958333] sky2: driver version 1.30
[ 1.971568] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.978183] ehci-pci: EHCI PCI platform driver
[ 1.982742] ehci-platform: EHCI generic platform driver
[ 1.988207] ehci-exynos: EHCI EXYNOS driver
[ 1.992553] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 1.998328] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.004533] ohci-pci: OHCI PCI platform driver
[ 2.009137] ohci-platform: OHCI generic platform driver
[ 2.014521] ohci-exynos: OHCI EXYNOS driver
[ 2.019496] usbcore: registered new interface driver usb-storage
[ 2.025602] usbcore: registered new interface driver usb_ehset_test
[ 2.034073] mousedev: PS/2 mouse device common for all mice
[ 2.039998] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.053743] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc0
[ 2.063068] i2c /dev entries driver
[ 2.072239] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 2.078789] Bluetooth: HCI UART driver ver 2.3
[ 2.083310] Bluetooth: HCI UART protocol H4 registered
[ 2.088464] Bluetooth: HCI UART protocol BCSP registered
[ 2.093844] Bluetooth: HCI UART protocol ATH3K registered
[ 2.099257] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.105652] Bluetooth: HCI UART protocol Broadcom registered
[ 2.111326] Bluetooth: HCI UART protocol QCA registered
[ 2.118085] sdhci: Secure Digital Host Controller Interface driver
[ 2.124339] sdhci: Copyright(c) Pierre Ossman
[ 2.129125] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.181707] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 2.194793] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 2.251999] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 2.262543] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.269061] caam 30900000.caam: ERA source: CCBVID.
[ 2.274109] Can't support > 32 bit dma.
[ 2.281319] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.281319] job rings = 3, qi = 0
[ 2.291568] Can't support > 32 bit dma.
[ 2.299017] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.305372] Failed to run desc RNG4 SH0 status (0xfffffff5)
[ 2.311227] Failed to run desc RNG4 SH1 status (0xfffffff5)
[ 2.316913] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.351640] mmc0: new HS400 MMC card at address 0001
[ 2.358012] mmcblk0: mmc0:0001 M32508 7.13 GiB
[ 2.364027] mmcblk0boot0: mmc0:0001 M32508 partition 1 4.00 MiB
[ 2.374564] mmcblk0boot1: mmc0:0001 M32508 partition 2 4.00 MiB
[ 2.385035] mmcblk0rpmb: mmc0:0001 M32508 partition 3 4.00 MiB
[ 2.390892] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.399854] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 2.457463] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.463402] Can't support > 32 bit dma.
[ 2.468750] Can't support > 32 bit dma.
[ 2.488643] caam algorithms registered in /proc/crypto
[ 2.498924] caam_jr 30901000.jr0: registering rng-caam
[ 2.504477] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.512925] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.520482] platform caam_sm: 64-bit clear key:
[ 2.525042] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.530715] platform caam_sm: 64-bit black key:
[ 2.535318] platform caam_sm: [0000] df f4 a7 6a 37 60 e0 c9
[ 2.540992] platform caam_sm: [0008] 61 1c 6a 0d 2d 49 50 3b
[ 2.546719] platform caam_sm: 128-bit clear key:
[ 2.551353] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.557082] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.562753] platform caam_sm: 128-bit black key:
[ 2.567443] platform caam_sm: [0000] 34 93 99 3e 26 32 3d 30
[ 2.573119] platform caam_sm: [0008] e2 d1 c4 ea aa 07 d2 0a
[ 2.578796] platform caam_sm: 192-bit clear key:
[ 2.583429] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.589104] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.594783] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.600454] platform caam_sm: 192-bit black key:
[ 2.605088] platform caam_sm: [0000] 22 ee c7 06 57 68 e4 7f
[ 2.610766] platform caam_sm: [0008] 60 76 bc c4 25 77 04 c8
[ 2.616440] platform caam_sm: [0016] 18 c9 3d 48 b7 fa c4 f9
[ 2.622116] platform caam_sm: [0024] b6 fa 50 81 16 46 04 31
[ 2.627789] platform caam_sm: 256-bit clear key:
[ 2.632421] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.638096] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.643773] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.649448] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.655123] platform caam_sm: 256-bit black key:
[ 2.659755] platform caam_sm: [0000] de 76 a1 99 83 fc 2f 1c
[ 2.665431] platform caam_sm: [0008] 96 35 1e 3d 18 f7 af 59
[ 2.671106] platform caam_sm: [0016] 9f 78 80 d6 f0 72 a5 36
[ 2.676781] platform caam_sm: [0024] 3f c7 15 02 22 fd bd 30
[ 2.682454] platform caam_sm: 64-bit unwritten blob:
[ 2.687439] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.693113] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.698789] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.704464] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.710140] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.715815] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.721490] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.727168] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.732844] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.738519] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.744197] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.749871] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.755550] platform caam_sm: 128-bit unwritten blob:
[ 2.760619] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.766294] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.771969] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.777647] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.783321] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.788995] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.794672] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.800346] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.806023] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.811700] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.817373] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.823049] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.828724] platform caam_sm: 196-bit unwritten blob:
[ 2.833791] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.839466] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.845144] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.850818] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.856493] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.862169] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.867844] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.873520] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.879197] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.884874] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.890548] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.896223] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.901900] platform caam_sm: 256-bit unwritten blob:
[ 2.906966] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.912641] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.918319] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.923993] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.929668] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.935353] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.941026] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.946701] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.952381] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.958055] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.963730] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.969408] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.979358] platform caam_sm: 64-bit black key in blob:
[ 2.984611] platform caam_sm: [0000] fa c1 48 6f 58 ae 81 95
[ 2.990291] platform caam_sm: [0008] e7 0a 60 7c 1f 0d a5 ab
[ 2.995966] platform caam_sm: [0016] 34 f5 30 92 44 e6 b9 48
[ 3.001641] platform caam_sm: [0024] d7 33 0c 56 d1 44 f9 66
[ 3.007317] platform caam_sm: [0032] 39 0a 22 6d 70 f6 b2 bd
[ 3.012997] platform caam_sm: [0040] 33 6c 14 42 7b 92 11 f6
[ 3.018674] platform caam_sm: [0048] 02 54 88 96 8c 62 6c e7
[ 3.024349] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.030027] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.035701] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.041377] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.047055] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.052728] platform caam_sm: 128-bit black key in blob:
[ 3.058058] platform caam_sm: [0000] c1 06 41 9a 16 bc 8a 91
[ 3.063736] platform caam_sm: [0008] 51 2b 35 51 b7 60 74 9a
[ 3.069410] platform caam_sm: [0016] 61 82 90 af 4d 1e 6f 56
[ 3.075086] platform caam_sm: [0024] 1e bc a7 5f ff 7c bc 98
[ 3.080764] platform caam_sm: [0032] b4 07 5f 19 45 5e a6 00
[ 3.086438] platform caam_sm: [0040] 8e 05 06 e2 2e 5d cb eb
[ 3.092114] platform caam_sm: [0048] 58 74 43 bd e5 5e 64 46
[ 3.097791] platform caam_sm: [0056] 27 7e b1 cf 2b 1b aa fc
[ 3.103466] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.109141] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.114816] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.120492] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.126168] platform caam_sm: 192-bit black key in blob:
[ 3.131499] platform caam_sm: [0000] 82 6c 6b 36 82 d6 b6 58
[ 3.137176] platform caam_sm: [0008] 9d 9f 03 6a 2f 02 2b 31
[ 3.142853] platform caam_sm: [0016] b0 01 50 a1 1e 69 78 35
[ 3.148529] platform caam_sm: [0024] ae c6 24 6e 4c 29 53 ef
[ 3.154208] platform caam_sm: [0032] 5d 97 3d c3 ab 2d e3 a0
[ 3.159885] platform caam_sm: [0040] d2 cd 4c db cb 4f 05 3d
[ 3.165561] platform caam_sm: [0048] 13 e3 d1 15 7b 73 e1 98
[ 3.171238] platform caam_sm: [0056] 5c 85 e1 64 a8 ed d8 af
[ 3.176917] platform caam_sm: [0064] cb ad ae 99 5f 22 1f 35
[ 3.182593] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.188269] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.193945] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.199619] platform caam_sm: 256-bit black key in blob:
[ 3.204951] platform caam_sm: [0000] a1 c9 f4 b6 c1 7a 1b c6
[ 3.210625] platform caam_sm: [0008] 57 45 d8 05 b1 dc 8d 62
[ 3.216302] platform caam_sm: [0016] 53 dc df e2 30 a7 61 7c
[ 3.221979] platform caam_sm: [0024] aa de 62 a3 c3 f5 68 64
[ 3.227655] platform caam_sm: [0032] f8 01 f5 00 f3 b1 88 f6
[ 3.233331] platform caam_sm: [0040] 82 48 7f 7a 50 f8 32 99
[ 3.239008] platform caam_sm: [0048] 8b b9 0d a4 3c 71 e2 93
[ 3.244685] platform caam_sm: [0056] 2a d6 13 cf e4 d1 7c 54
[ 3.250364] platform caam_sm: [0064] 15 b9 c7 65 8a 7f ff 0f
[ 3.256038] platform caam_sm: [0072] 90 45 4f 97 6e d3 86 3c
[ 3.261716] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.267396] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.277348] platform caam_sm: restored 64-bit black key:
[ 3.282686] platform caam_sm: [0000] b7 b1 3d e6 8b 7c e2 58
[ 3.288363] platform caam_sm: [0008] ad a0 46 f9 78 2d 00 75
[ 3.294038] platform caam_sm: restored 128-bit black key:
[ 3.299455] platform caam_sm: [0000] 34 93 99 3e 26 32 3d 30
[ 3.305132] platform caam_sm: [0008] e2 d1 c4 ea aa 07 d2 0a
[ 3.310806] platform caam_sm: restored 192-bit black key:
[ 3.316221] platform caam_sm: [0000] 22 ee c7 06 57 68 e4 7f
[ 3.321898] platform caam_sm: [0008] 60 76 bc c4 25 77 04 c8
[ 3.327575] platform caam_sm: [0016] 51 92 a7 ec 29 20 0d ba
[ 3.333251] platform caam_sm: [0024] 62 a8 3d 74 2a b9 93 74
[ 3.338923] platform caam_sm: restored 256-bit black key:
[ 3.344339] platform caam_sm: [0000] de 76 a1 99 83 fc 2f 1c
[ 3.350016] platform caam_sm: [0008] 96 35 1e 3d 18 f7 af 59
[ 3.355693] platform caam_sm: [0016] 9f 78 80 d6 f0 72 a5 36
[ 3.361369] platform caam_sm: [0024] 3f c7 15 02 22 fd bd 30
[ 3.367316] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 3.373213] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 3.382470] usbcore: registered new interface driver usbhid
[ 3.388063] usbhid: USB HID core driver
[ 3.400698] NET: Registered protocol family 26
[ 3.405267] NET: Registered protocol family 17
[ 3.409789] can: controller area network core (rev 20120528 abi 9)
[ 3.416033] NET: Registered protocol family 29
[ 3.420549] can: raw protocol (rev 20120528)
[ 3.424832] can: broadcast manager protocol (rev 20161123 t)
[ 3.430562] can: netlink gateway (rev 20130117) max_hops=1
[ 3.437322] Bluetooth: RFCOMM TTY layer initialized
[ 3.442282] Bluetooth: RFCOMM socket layer initialized
[ 3.447444] Bluetooth: RFCOMM ver 1.11
[ 3.451267] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.456591] Bluetooth: BNEP filters: protocol multicast
[ 3.461889] Bluetooth: BNEP socket layer initialized
[ 3.466867] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.472803] Bluetooth: HIDP socket layer initialized
[ 3.478080] 9pnet: Installing 9P2000 support
[ 3.482549] Key type dns_resolver registered
[ 3.489327] registered taskstats version 1
[ 3.520774] cpu cpu0: registered imx8mq-cpufreq
[ 3.528567] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[ 3.536212] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
[ 3.545579] clk: Not disabling unused clocks
[ 3.549982] VSD_3V3: disabling
[ 3.553073] reg_bt_wake: disabling
[ 3.556542] dhd_module_init in
[ 3.560038] bcmdhd_wlan@0 supply wlreg_on not found, using dummy regulator
[ 3.567253] No Broadcom PCI device enumerated!
[ 3.571904] dhd_wifi_platform_load_pcie: pcie_register_driver failed
[ 3.578407] bcmdhd_wlan: probe of bcmdhd_wlan@0 failed with error -1
[ 3.585045] dhd_module_init out
[ 3.588229] ALSA device list:
[ 3.591301] No soundcards found.
[ 3.596214] Freeing unused kernel memory: 1152K
The available udc:
/sys/class/udc/38100000.dwc3
[ 3.683001] Mass Storage Function, version: 2009/09/11
[ 3.688296] LUN: removable file: (no medium)
MFG tool will use 1st udc:38100000.dwc3
Starting UTP
uuc 0.5 [built Mar 12 2018 12:14:52]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
[ 3.942986] configfs-gadget gadget: high-speed config #1: c
UTP: received command '$ while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done '
UTP: executing "while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done "
UTP: sending Success to kernel for command $ while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done .
[ 4.275383] utp_poll: pass returned.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168"
7168+0 records in
7168+0 records out
7340032 bytes (7.3 MB, 7.0 MiB) copied, 0.77733 s, 9.4 MB/[ 5.072271] utp_poll: pass returned.
s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168.
UTP: received command '$ echo 0 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 0 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk0boot0/force_ro.
[ 5.338023] utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33'
UTP: executing "dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33"
[ 5.660785] random: crng init done
988+1 records in
988+1 records out
1012676 bytes (1.0 MB, 989 KiB) copied, 0.260027 s, 3.9 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33.
[ 5.929512] utp_poll: pass returned.
UTP: received command '$ echo 1 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 1 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk0boot0/force_ro.
[ 6.195701] utp_poll: pass returned.
UTP: received command '$ mmc bootpart enable 1 1 /dev/mmcblk0'
UTP: executing "mmc bootpart enable 1 1 /dev/mmcblk0"
UTP: sending Success to kernel for command $ mmc bootpart enable 1 1 /dev/mmcblk0.
[ 6.461747] utp_poll: pass returned.
UTP: received command '$ ls -l /dev/mmc* '
UTP: executing "ls -l /dev/mmc* "
brw------- 1 root root 179, 0 Jan 1 00:00 /dev/mmcblk0
brw------- 1 root root 179, 32 Jan 1 00:00 /dev/mmcblk0boot0
brw------- 1 root root 179, 64 Jan 1 00:00 /dev/mmcblk0boot1
brw------- 1 root root 179, 1 Jan 1 00:00 /dev/mmcblk0p1
brw------- 1 root root 179, 10 Jan 1 00:00 /dev/mmcblk0p10
brw------- 1 root root 179, 11 Jan 1 00:00 /dev/mmcblk0p11
brw------- 1 root root 179, 12 Jan 1 00:00 /dev/mmcblk0p12
brw------- 1 root root 179, 13 Jan 1 00:00 /dev/mmcblk0p13
brw------- 1 root root 179, 2 Jan 1 00:00 /dev/mmcblk0p2
brw------- 1 root root 179, 3 Jan 1 00:00 /dev/mmcblk0p3
brw------- 1 root root 179, 4 Jan 1 00:00 /dev/mmcblk0p4
brw------- 1 root root 179, 5 Jan 1 00:00 /dev/mmcblk0p5
brw------- 1 root root 179, 6 Jan 1 00:00 /dev/mmcblk0p6
brw------- 1 root root 179, 7 Jan 1 00:00 /dev/mmcblk0p7
brw------- 1 root root 179, 8 Jan 1 00:00 /dev/mmcblk0p8
brw------- 1 root root 179, 9 Jan 1 00:00 /dev/mmcblk0p9
brw------- 1 root root 179, 96 Jan 1 00:00 /dev/mmcblk0rpmb
UTP: sending Success to kernel for command $ ls -l /dev/mmc* .
[ 6.726830] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 conv=fsync"
67+0 records in
67+0 records out
34304 bytes (34 kB, 34 KiB) copied, 0.0161089 s, 2.1 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 conv=fsync.
[ 7.005824] utp_poll: pass returned.
[ 7.287403] utp_poll: pass returned.
UTP: received command '$ hdparm -z /dev/mmcblk0'
UTP: executing "hdparm -z /dev/mmcblk0"
/dev/mmcblk0:
re-reading partition table
[ 7.312745] Alternate GPT is invalid, using primary GPT.
[ 7.318177] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
UTP: sending Success to kernel for command $ hdparm -z /dev/mmcblk0.
[ 7.555093] utp_poll: pass returned.
UTP: received command '$ gdisk -l /dev/mmcblk0 '
UTP: executing "gdisk -l /dev/mmcblk0 "
GPT fdisk (gdisk) version 1.0.1
Caution: invalid backup GPT header, but valid main header; regenerating
backup header from main header.
Warning! Main and backup partition tables differ! Use the 'c' and 'e' options
on the recovery & transformation menu to examine the two tables.
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/mmcblk0: 14942208 sectors, 7.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 3F7BACF6-D26C-4E05-B1FF-2140A571438A
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 14680030
Partitions will be aligned on 2048-sector boundaries
Total free space is 28605 sectors (14.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 16384 81919 32.0 MiB FFFF boot_a
2 81920 147455 32.0 MiB FFFF boot_b
3 147456 2605055 1.2 GiB FFFF system_a
4 2605056 5062655 1.2 GiB FFFF system_b
5 5062656 5070847 4.0 MiB FFFF misc
6 5070848 5074943 2.0 MiB FFFF metadata
7 5074944 5076991 1024.0 KiB FFFF presistdata
8 5079040 5308415 112.0 MiB FFFF vendor_a
9 5308416 5537791 112.0 MiB FFFF vendor_b
10 5537792 14663679 4.4 GiB FFFF userdata
11 14663680 14665727 1024.0 KiB 0700 fbmisc
12 14667776 14669823 1024.0 KiB FFFF vbmeta_a
13 14671872 14673919 1024.0 KiB FFFF vbmeta_b
UTP: sending Success to kernel for command $ gdisk -l /dev/mmcblk0 .
[ 7.835389] utp_poll: pass returned.
UTP: received command '$ echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0'
UTP: executing "echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0"
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Command (? for help):
Recovery/transformation command (? for help): Warning! This will probably do weird things if you've converted an MBR to
GPT form and haven't yet saved the GPT! Proceed? (Y/N):
Recovery/transformation command (? for help): Warning! Secondary header is placed too early on the disk! Do you want to
correct this problem? (Y/N): Have moved second header and partition table to correct location.
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): OK; writing new GUID partition table (GPT) to /dev/mmcblk0.
[ 8.915510] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
The operation has completed successfully.
UTP: sending Success to kernel for command $ echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0.
[ 9.144662] utp_poll: pass returned.
UTP: received command '$ echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx'
UTP: executing "echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx"
UTP: sending Success to kernel for command $ echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx.
[ 10.707664] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`'
UTP: executing "dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`"
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 3.129 s, 10.7 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`.
[ 14.101202] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`'
UTP: executing "dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`"
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 3.64563 s, 9.2 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`.
[ 17.961090] utp_poll: pass returned.
UTP: received command '$ mount -o remount,size=1536M rootfs /'
UTP: executing "mount -o remount,size=1536M rootfs /"
UTP: sending Success to kernel for command $ mount -o remount,size=1536M rootfs /.
[ 18.226729] utp_poll: pass returned.
UTP: received command '$ cat /proc/meminfo'
UTP: executing "cat /proc/meminfo"
MemTotal: 2039988 kB
MemFree: 1961180 kB
MemAvailable: 1929704 kB
Buffers: 0 kB
Cached: 56824 kB
SwapCached: 0 kB
Active: 40972 kB
Inactive: 16504 kB
Active(anon): 40972 kB
Inactive(anon): 16392 kB
Active(file): 0 kB
Inactive(file): 112 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 512 kB
Mapped: 2356 kB
Shmem: 56792 kB
Slab: 14692 kB
SReclaimable: 4516 kB
SUnreclaim: 10176 kB
KernelStack: 1504 kB
PageTables: 68 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1019992 kB
Committed_AS: 55580 kB
VmallocTotal: 135290290112 kB
VmallocUsed: 0 kB
VmallocChunk: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
CmaTotal: 65536 kB
CmaFree: 64896 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
UTP: sending Success to kernel for command $ cat /proc/meminfo.
[ 18.492547] utp_poll: pass returned.
UTP: received command '$ echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx'
UTP: executing "echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx"
UTP: sending Success to kernel for command $ echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx.
[ 56.506224] utp_poll: pass returned.
UTP: received command '$ simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`'
UTP: executing "simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`"
Invalid sparse file format at unknown block 294A at 38887461
Invalid sparse file format at unknown block A12E at 38887462
Invalid sparse file format at unknown block B6B4 at 38887464
Invalid sparse file format at unknown block C27A at 38887465
Invalid sparse file format at unknown block 726F at 38887466
Invalid sparse file format at unknown block 6ED4 at 38887467
Invalid sparse file format at unknown block 529D at 38887468
Invalid sparse file format at unknown block C75A at 38887470
Invalid sparse file format at unknown block 333F at 38887471
Invalid sparse file format at unknown block 2F89 at 38887472
Invalid sparse file format at unknown block D6BD at 38887473
Invalid sparse file format at unknown block B192 at 38887474
Invalid sparse file format at unknown block E970 at 38887476
Invalid sparse file format at unknown block 42F9 at 38887477
Invalid sparse file format at unknown block CB2D at 38887478
Invalid sparse file format at unknown block 27BC at 38887479
Invalid sparse file format at unknown block AD35 at 38887480
Invalid sparse file format at unknown block C571 at 38887482
Invalid sparse file format at unknown block 2E91 at 38887483
Invalid sparse file format at unknown block 357C at 38887484
Invalid sparse file format at unknown block 1631 at 38887485
Invalid sparse file format at unknown block 815F at 38887486
Invalid sparse file format at unknown block 4445 at 38887488
Invalid sparse file format at unknown block 72B8 at 38887489
Invalid sparse file format at unknown block 49DE at 38887490
Invalid sparse file format at unknown block 3034 at 38887491
Invalid sparse file format at unknown block 25F6 at 38887492
Invalid sparse file format at unknown block CCB2 at 38887494
Invalid sparse file format at unknown block 323C at 38887495
Invalid sparse file format at unknown block 9CC7 at 38887496
Invalid sparse file format at unknown block D5D5 at 38887497
Invalid sparse file format at unknown block E344 at 38887498
Invalid sparse file format at unknown block 94AB at 38887500
Invalid sparse file format at unknown block 7233 at 38887501
Invalid sparse file format at unknown block 4816 at 38887502
Invalid sparse file format at unknown block 74A9 at 38887503
Invalid sparse file format at unknown block A13B at 38887504
Invalid sparse file format at unknown block FA11 at 38887506
Invalid sparse file format at unknown block 3DAD at 38887507
Invalid sparse file format at unknown block 96F9 at 38887508
Invalid sparse file format at unknown block 2538 at 38887509
Invalid sparse file format at unknown block 605D at 38887510
Invalid sparse file format at unknown block BF05 at 38887512
Invalid sparse file format at unknown block E1E1 at 38887513
Invalid sparse file format at unknown block BA17 at 38887514
Invalid sparse file format at unknown block 878C at 38887515
Invalid sparse file format at unknown block 8B23 at 38887516
Invalid sparse file format at unknown block 7592 at 38887518
Invalid sparse file format at unknown block CC62 at 38887519
Invalid sparse file format at unknown block 6304 at 38887520
Invalid sparse file format at unknown block 542A at 38887521
Invalid sparse file format at unknown block E75B at 38887522
Invalid sparse file format at unknown block 5F24 at 38887524
Invalid sparse file format at unknown block 6F1F at 38887525
Invalid sparse file format at unknown block BE12 at 38887526
Invalid sparse file format at unknown block 881A at 38887527
Invalid sparse file format at unknown block 20D8 at 38887528
Invalid sparse file format at unknown block 740B at 38887530
Invalid sparse file format at unknown block 63B8 at 38887531
Invalid sparse file format at unknown block 46C7 at 38887532
Invalid sparse file format at unknown block 779A at 38887533
Invalid sparse file format at unknown block F2B8 at 38887534
Invalid sparse file format at unknown block C011 at 38887536
Invalid sparse file format at unknown block 9FDB at 38887537
Invalid sparse file format at unknown block 938E at 38887538
Invalid sparse file format at unknown block 9671 at 38887539
Invalid sparse file format at unknown block 181C at 38887540
Invalid sparse file format at unknown block 8A27 at 38887542
Invalid sparse file format at unknown block 1D8B at 38887543
Invalid sparse file format at unknown block D5F8 at 38887544
Invalid sparse file format at unknown block 12F7 at 38887545
Invalid sparse file format at unknown block 20D1 at 38887546
Invalid sparse file format at unknown block 4411 at 38887548
Invalid sparse file format at unknown block 44B5 at 38887549
Invalid sparse file format at unknown block F523 at 38887550
Invalid sparse file format at unknown block 5BA8 at 38887551
Invalid sparse file format at unknown block 791B at 38887552
Invalid sparse file format at unknown block 7748 at 38887554
Invalid sparse file format at unknown block 4AF8 at 38887555
Invalid sparse file format at unknown block A294 at 38887556
Invalid sparse file format at unknown block BCDC at 38887557
Invalid sparse file format at unknown block 1423 at 38887558
Invalid sparse file format at unknown block 7737 at 38887560
Invalid sparse file format at unknown block D159 at 38887561
Invalid sparse file format at unknown block B4EC at 38887562
Invalid sparse file format at unknown block CFCF at 38887563
Invalid sparse file format at unknown block 9CB8 at 38887564
Invalid sparse file format at unknown block 6CC9 at 38887566
Invalid sparse file format at unknown block 68C3 at 38887567
Invalid sparse file format at unknown block 619B at 38887568
Invalid sparse file format at unknown block C68E at 38887569
Invalid sparse file format at unknown block 9124 at 38887570
Invalid sparse file format at unknown block AD9E at 38887572
Invalid sparse file format at unknown block EDDC at 38887573
Invalid sparse file format at unknown block 2281 at 38887574
Invalid sparse file format at unknown block 6625 at 38887575
Invalid sparse file format at unknown block E296 at 38887576
Invalid sparse file format at unknown block 5C21 at 38887578
Invalid sparse file format at unknown block A776 at 38887579
Invalid sparse file format at unknown block E3A8 at 38887580
Invalid sparse file format at unknown block C23C at 38887581
Invalid sparse file format at unknown block 83EC at 38887582
Invalid sparse file format at unknown block B686 at 38887584
Invalid sparse file format at unknown block A2B3 at 38887585
Invalid sparse file format at unknown block AF60 at 38887586
Invalid sparse file format at unknown block 6BE5 at 38887587
Invalid sparse file format at unknown block EA7F at 38887588
Invalid sparse file format at unknown block C189 at 38887590
Invalid sparse file format at unknown block 8DB2 at 38887591
Invalid sparse file format at unknown block 42CC at 38887592
Invalid sparse file format at unknown block AA47 at 38887593
Invalid sparse file format at unknown block 107B at 38887594
Invalid sparse file format at unknown block 0CBA at 38887596
Invalid sparse file format at unknown block 475B at 38887597
Invalid sparse file format at unknown block 7BCB at 38887598
Invalid sparse file format at unknown block 1DDC at 38887599
Invalid sparse file format at unknown block C9B1 at 38887600
Invalid sparse file format at unknown block 4852 at 38887602
Invalid sparse file format at unknown block F732 at 38887603
Invalid sparse file format at unknown block 23BB at 38887604
Invalid sparse file format at unknown block C248 at 38887605
Invalid sparse file format at unknown block DD7E at 38887606
Invalid sparse file format at unknown block 4B76 at 38887608
Invalid sparse file format at unknown block 370B at 38887609
Invalid sparse file format at unknown block 7BC2 at 38887610
Invalid sparse file format at unknown block C637 at 38887611
Invalid sparse file format at unknown block 309A at 38887612
Invalid sparse file format at unknown block 3AA3 at 38887614
Invalid sparse file format at unknown block 4911 at 38887615
Invalid sparse file format at unknown block 865E at 38887616
Invalid sparse file format at unknown block 016D at 38887617
Invalid sparse file format at unknown block 3310 at 38887618
Invalid sparse file format at unknown block 8E09 at 38887620
Invalid sparse file format at unknown block A2C3 at 38887621
Invalid sparse file format at unknown block E420 at 38887622
Invalid sparse file format at unknown block C209 at 38887623
Invalid sparse file format at unknown block 22F7 at 38887624
Invalid sparse file format at unknown block 78B3 at 38887626
Invalid sparse file format at unknown block 725B at 38887627
Invalid sparse file format at unknown block 1F3C at 38887628
Invalid sparse file format at unknown block 81F4 at 38887629
Invalid sparse file format at unknown block F701 at 38887630
Invalid sparse file format at unknown block B5B4 at 38887632
Invalid sparse file format at unknown block EB76 at 38887633
Invalid sparse file format at unknown block B201 at 38887634
Invalid sparse file format at unknown block 1F23 at 38887635
Invalid sparse file format at unknown block 7CFB at 38887636
Invalid sparse file format at unknown block DE27 at 38887638
Invalid sparse file format at unknown block F96E at 38887639
Invalid sparse file format at unknown block 4B3B at 38887640
Invalid sparse file format at unknown block F187 at 38887641
Invalid sparse file format at unknown block DAA9 at 38887642
Invalid sparse file format at unknown block 79A8 at 38887644
Invalid sparse file format at unknown block 8CD9 at 38887645
Invalid sparse file format at unknown block 41F2 at 38887646
Invalid sparse file format at unknown block BA20 at 38887647
Invalid sparse file format at unknown block 193B at 38887648
Invalid sparse file format at unknown block 7C74 at 38887650
Invalid sparse file format at unknown block DD98 at 38887651
Invalid sparse file format at unknown block 3436 at 38887652
Invalid sparse file format at unknown block 14C0 at 38887653
Invalid sparse file format at unknown block D613 at 38887654
Invalid sparse file format at unknown block CF44 at 38887656
Invalid sparse file format at unknown block AB93 at 38887657
Invalid sparse file format at unknown block 4DCD at 38887658
Invalid sparse file format at unknown block 7D5B at 38887659
Invalid sparse file format at unknown block 38CF at 38887660
Invalid sparse file format at unknown block 4DD8 at 38887662
Invalid sparse file format at unknown block 29EE at 38887663
Invalid sparse file format at unknown block 9E06 at 38887664
Invalid sparse file format at unknown block 0EFF at 38887665
Invalid sparse file format at unknown block 649D at 38887666
Invalid sparse file format at unknown block D6DD at 38887668
Invalid sparse file format at unknown block F314 at 38887669
Invalid sparse file format at unknown block 1AC2 at 38887670
Invalid sparse file format at unknown block 1542 at 38887671
Invalid sparse file format at unknown block BC52 at 38887672
Invalid sparse file format at unknown block 716D at 38887674
Invalid sparse file format at unknown block F665 at 38887675
Invalid sparse file format at unknown block A64B at 38887676
Invalid sparse file format at unknown block CD71 at 38887677
Invalid sparse file format at unknown block AE00 at 38887678
Invalid sparse file format at unknown block 0748 at 38887680
Invalid sparse file format at unknown block A884 at 38887681
Invalid sparse file format at unknown block E94E at 38887682
Invalid sparse file format at unknown block 5C42 at 38887683
Invalid sparse file format at unknown block 1988 at 38887684
Invalid sparse file format at unknown block 9BB8 at 38887686
Invalid sparse file format at unknown block 75D0 at 38887687
Invalid sparse file format at unknown block 14CE at 38887688
Invalid sparse file format at unknown block 06BA at 38887689
Invalid sparse file format at unknown block 2F68 at 38887690
Invalid sparse file format at unknown block 9132 at 38887692
Invalid sparse file format at unknown block 7A9D at 38887693
Invalid sparse file format at unknown block A15E at 38887694
Invalid sparse file format at unknown block 7C2A at 38887695
Invalid sparse file format at unknown block EE5A at 38887696
Invalid sparse file format at unknown block 6D9B at 38887698
Invalid sparse file format at unknown block 89F5 at 38887699
Invalid sparse file format at unknown block 01C8 at 38887700
Invalid sparse file format at unknown block D5D5 at 38887701
Invalid sparse file format at unknown block 143E at 38887702
Invalid sparse file format at unknown block CDF3 at 38887704
Invalid sparse file format at unknown block 1F60 at 38887705
Invalid sparse file format at unknown block 4A51 at 38887706
Invalid sparse file format at unknown block E125 at 38887707
Invalid sparse file format at unknown block 5CF1 at 38887708
Invalid sparse file format at unknown block BC8C at 38887710
Invalid sparse file format at unknown block 42B1 at 38887711
Invalid sparse file format at unknown block 03B8 at 38887712
Invalid sparse file format at unknown block AE82 at 38887713
Invalid sparse file format at unknown block 0F77 at 38887714
Invalid sparse file format at unknown block B7D6 at 38887716
Invalid sparse file format at unknown block 6146 at 38887717
Invalid sparse file format at unknown block 0E14 at 38887718
Invalid sparse file format at unknown block DE77 at 38887719
Invalid sparse file format at unknown block 1475 at 38887720
Invalid sparse file format at unknown block FF76 at 38887722
Invalid sparse file format at unknown block 4DA1 at 38887723
Invalid sparse file format at unknown block 78EC at 38887724
Invalid sparse file format at unknown block A4BE at 38887725
Invalid sparse file format at unknown block 387B at 38887726
Invalid sparse file format at unknown block 6E23 at 38887728
Invalid sparse file format at unknown block F25F at 38887729
Invalid sparse file format at unknown block F3B6 at 38887730
Invalid sparse file format at unknown block AECB at 38887731
Invalid sparse file format at unknown block 362D at 38887732
Invalid sparse file format at unknown block 46BD at 38887734
Invalid sparse file format at unknown block 969C at 38887735
Invalid sparse file format at unknown block F15C at 38887736
Invalid sparse file format at unknown block 66B5 at 38887737
Invalid sparse file format at unknown block 332A at 38887738
Invalid sparse file format at unknown block C37F at 38887740
Invalid sparse file format at unknown block B3D3 at 38887741
Invalid sparse file format at unknown block 0B2B at 38887742
Invalid sparse file format at unknown block 46BF at 38887743
Invalid sparse file format at unknown block 21DB at 38887744
Invalid sparse file format at unknown block DF80 at 38887746
Invalid sparse file format at unknown block A468 at 38887747
Invalid sparse file format at unknown block E0AE at 38887748
Invalid sparse file format at unknown block AB41 at 38887749
Invalid sparse file format at unknown block A28D at 38887750
Invalid sparse file format at unknown block 68DE at 38887752
Invalid sparse file format at unknown block BBA3 at 38887753
Invalid sparse file format at unknown block AD8A at 38887754
Invalid sparse file format at unknown block C4BD at 38887755
Invalid sparse file format at unknown block 22BA at 38887756
Invalid sparse file format at unknown block 7310 at 38887758
Invalid sparse file format at unknown block FEF7 at 38887759
Invalid sparse file format at unknown block EAFC at 38887760
Invalid sparse file format at unknown block A5DA at 38887761
Invalid sparse file format at unknown block E602 at 38887762
Invalid sparse file format at unknown block C3A4 at 38887764
Invalid sparse file format at unknown block FD96 at 38887765
Invalid sparse file format at unknown block E9D0 at 38887766
Invalid sparse file format at unknown block 2C0A at 38887767
Invalid sparse file format at unknown block B3E5 at 38887768
Invalid sparse file format at unknown block A76A at 38887770
Invalid sparse file format at unknown block 820A at 38887771
Invalid sparse file format at unknown block 00D4 at 38887772
Invalid sparse file format at unknown block AB55 at 38887773
Invalid sparse file format at unknown block E68C at 38887774
Invalid sparse file format at unknown block EAF5 at 38887776
Invalid sparse file format at unknown block 59E9 at 38887777
Invalid sparse file format at unknown block A2A7 at 38887778
Invalid sparse file format at unknown block 87EC at 38887779
Invalid sparse file format at unknown block 7E8E at 38887780
Invalid sparse file format at unknown block 553E at 38887782
Invalid sparse file format at unknown block F82D at 38887783
Invalid sparse file format at unknown block 3542 at 38887784
Invalid sparse file format at unknown block 4082 at 38887785
Invalid sparse file format at unknown block 5218 at 38887786
Invalid sparse file format at unknown block 97DB at 38887788
Invalid sparse file format at unknown block 549E at 38887789
Invalid sparse file format at unknown block 1B9B at 38887790
Invalid sparse file format at unknown block D3FE at 38887791
Invalid sparse file format at unknown block 67B9 at 38887792
Invalid sparse file format at unknown block 0834 at 38887794
Invalid sparse file format at unknown block 2553 at 38887795
Invalid sparse file format at unknown block B161 at 38887796
Invalid sparse file format at unknown block A727 at 38887797
Invalid sparse file format at unknown block E23A at 38887798
Invalid sparse file format at unknown block 6C9E at 38887800
Invalid sparse file format at unknown block E846 at 38887801
Invalid sparse file format at unknown block 4F42 at 38887802
Invalid sparse file format at unknown block 7CFC at 38887803
Invalid sparse file format at unknown block 824C at 38887804
Invalid sparse file format at unknown block 1C58 at 38887806
Invalid sparse file format at unknown block D920 at 38887807
Invalid sparse file format at unknown block 0F8B at 38887808
Invalid sparse file format at unknown block 6D5E at 38887809
Invalid sparse file format at unknown block 16C1 at 38887810
Invalid sparse file format at unknown block DA92 at 38887812
Invalid sparse file format at unknown block 418B at 38887813
Invalid sparse file format at unknown block 470D at 38887814
Invalid sparse file format at unknown block A2AC at 38887815
Invalid sparse file format at unknown block 8A7A at 38887816
Invalid sparse file format at unknown block 62E6 at 38887818
Invalid sparse file format at unknown block 5880 at 38887819
Invalid sparse file format at unknown block 4A97 at 38887820
Invalid sparse file format at unknown block 1C87 at 38887821
Invalid sparse file format at unknown block 42EC at 38887822
Invalid sparse file format at unknown block F730 at 38887824
Invalid sparse file format at unknown block 69FC at 38887825
Invalid sparse file format at unknown block EC4E at 38887826
Invalid sparse file format at unknown block 5F5F at 38887827
Invalid sparse file format at unknown block 55E3 at 38887828
Invalid sparse file format at unknown block DF7F at 38887830
Invalid sparse file format at unknown block 6319 at 38887831
Invalid sparse file format at unknown block D440 at 38887832
Invalid sparse file format at unknown block 6116 at 38887833
Invalid sparse file format at unknown block 96FE at 38887834
Invalid sparse file format at unknown block FE19 at 38887836
Invalid sparse file format at unknown block 40B4 at 38887837
Invalid sparse file format at unknown block 910C at 38887838
Invalid sparse file format at unknown block 6D80 at 38887839
Invalid sparse file format at unknown block 7658 at 38887840
Invalid sparse file format at unknown block 2353 at 38887842
Invalid sparse file format at unknown block 9D2A at 38887843
Invalid sparse file format at unknown block 4600 at 38887844
Invalid sparse file format at unknown block 81DE at 38887845
Invalid sparse file format at unknown block E842 at 38887846
Invalid sparse file format at unknown block A2BC at 38887848
Invalid sparse file format at unknown block E984 at 38887849
Invalid sparse file format at unknown block 36A9 at 38887850
Invalid sparse file format at unknown block 93AD at 38887851
Invalid sparse file format at unknown block F11F at 38887852
Invalid sparse file format at unknown block B495 at 38887854
Invalid sparse file format at unknown block 2F51 at 38887855
Invalid sparse file format at unknown block 57BC at 38887856
Invalid sparse file format at unknown block CBB8 at 38887857
Invalid sparse file format at unknown block CDF0 at 38887858
Invalid sparse file format at unknown block 3284 at 38887860
Invalid sparse file format at unknown block 2C37 at 38887861
Invalid sparse file format at unknown block 3A89 at 38887862
Invalid sparse file format at unknown block C80F at 38887863
Invalid sparse file format at unknown block 0D77 at 38887864
Invalid sparse file format at unknown block E2E0 at 38887866
Invalid sparse file format at unknown block 203E at 38887867
Invalid sparse file format at unknown block 2F35 at 38887868
Invalid sparse file format at unknown block 0476 at 38887869
Invalid sparse file format at unknown block 404F at 38887870
Invalid sparse file format at unknown block 7110 at 38887872
Invalid sparse file format at unknown block 3A19 at 38887873
Invalid sparse file format at unknown block 1C2B at 38887874
Invalid sparse file format at unknown block 0D45 at 38887875
Invalid sparse file format at unknown block 524E at 38887876
Invalid sparse file format at unknown block AB29 at 38887878
Invalid sparse file format at unknown block E884 at 38887879
Invalid sparse file format at unknown block DBB2 at 38887880
Invalid sparse file format at unknown block 207C at 38887881
Invalid sparse file format at unknown block 5C1E at 38887882
Invalid sparse file format at unknown block 4DBF at 38887884
Invalid sparse file format at unknown block 43BA at 38887885
Invalid sparse file format at unknown block 5166 at 38887886
Invalid sparse file format at unknown block 33D8 at 38887887
Invalid sparse file format at unknown block C3E4 at 38887888
Invalid sparse file format at unknown block 4735 at 38887890
Invalid sparse file format at unknown block 172D at 38887891
Invalid sparse file format at unknown block 8551 at 38887892
Invalid sparse file format at unknown block 6F91 at 38887893
Invalid sparse file format at unknown block 5BB4 at 38887894
Invalid sparse file format at unknown block 5F0C at 38887896
Invalid sparse file format at unknown block 4A34 at 38887897
Invalid sparse file format at unknown block 9403 at 38887898
Invalid sparse file format at unknown block F8B9 at 38887899
Invalid sparse file format at unknown block D82D at 38887900
Invalid sparse file format at unknown block F97D at 38887902
Invalid sparse file format at unknown block EDDE at 38887903
Invalid sparse file format at unknown block EAF4 at 38887904
Invalid sparse file format at unknown block C149 at 38887905
Invalid sparse file format at unknown block 6782 at 38887906
Invalid sparse file format at unknown block AE5E at 38887908
Invalid sparse file format at unknown block BB7D at 38887909
Invalid sparse file format at unknown block 7E28 at 38887910
Invalid sparse file format at unknown block 1A9D at 38887911
Invalid sparse file format at unknown block 77C3 at 38887912
Invalid sparse file format at unknown block 0D56 at 38887914
Invalid sparse file format at unknown block E6CE at 38887915
Invalid sparse file format at unknown block C1FC at 38887916
Invalid sparse file format at unknown block D7E8 at 38887917
Invalid sparse file format at unknown block 12B0 at 38887918
Invalid sparse file format at unknown block B333 at 38887920
Invalid sparse file format at unknown block CD9C at 38887921
Invalid sparse file format at unknown block 9CD6 at 38887922
Invalid sparse file format at unknown block 0BDD at 38887923
Invalid sparse file format at unknown block F97A at 38887924
Invalid sparse file format at unknown block CD74 at 38887926
Invalid sparse file format at unknown block 335B at 38887927
Invalid sparse file format at unknown block 337F at 38887928
Invalid sparse file format at unknown block B083 at 38887929
Invalid sparse file format at unknown block 4D5D at 38887930
Invalid sparse file format at unknown block 04B3 at 38887932
Invalid sparse file format at unknown block 40E4 at 38887933
Invalid sparse file format at unknown block CDC6 at 38887934
Invalid sparse file format at unknown block BFEC at 38887935
Invalid sparse file format at unknown block 1897 at 38887936
Invalid sparse file format at unknown block D44C at 38887938
Invalid sparse file format at unknown block 0777 at 38887939
Invalid sparse file format at unknown block 28B9 at 38887940
Invalid sparse file format at unknown block 918B at 38887941
Invalid sparse file format at unknown block 93E1 at 38887942
Invalid sparse file format at unknown block FE22 at 38887944
Invalid sparse file format at unknown block 3301 at 38887945
Invalid sparse file format at unknown block B494 at 38887946
Invalid sparse file format at unknown block FFC5 at 38887947
Invalid sparse file format at unknown block 45AB at 38887948
Invalid sparse file format at unknown block DE72 at 38887950
Invalid sparse file format at unknown block 1C56 at 38887951
Invalid sparse file format at unknown block 341B at 38887952
Invalid sparse file format at unknown block 6553 at 38887953
Invalid sparse file format at unknown block BDA7 at 38887954
Invalid sparse file format at unknown block B30B at 38887956
Invalid sparse file format at unknown block DE53 at 38887957
Invalid sparse file format at unknown block 9645 at 38887958
Invalid sparse file format at unknown block 8474 at 38887959
Invalid sparse file format at unknown block 89E5 at 38887960
Invalid sparse file format at unknown block 74A3 at 38887962
Invalid sparse file format at unknown block 1C13 at 38887963
Invalid sparse file format at unknown block 5766 at 38887964
Invalid sparse file format at unknown block 518A at 38887965
Invalid sparse file format at unknown block 4F5E at 38887966
Invalid sparse file format at unknown block 949A at 38887968
Invalid sparse file format at unknown block 2B4A at 38887969
Invalid sparse file format at unknown block DF52 at 38887970
Invalid sparse file format at unknown block 244F at 38887971
Invalid sparse file format at unknown block 9627 at 38887972
Invalid sparse file format at unknown block A989 at 38887974
Invalid sparse file format at unknown block 748E at 38887975
Invalid sparse file format at unknown block 9033 at 38887976
Invalid sparse file format at unknown block 375C at 38887977
Invalid sparse file format at unknown block 48E9 at 38887978
Invalid sparse file format at unknown block FD9E at 38887980
Invalid sparse file format at unknown block CA38 at 38887981
Invalid sparse file format at unknown block DB80 at 38887982
Invalid sparse file format at unknown block B289 at 38887983
Invalid sparse file format at unknown block 822B at 38887984
Invalid sparse file format at unknown block 4D11 at 38887986
Invalid sparse file format at unknown block FB7E at 38887987
Invalid sparse file format at unknown block 450E at 38887988
Invalid sparse file format at unknown block 411C at 38887989
Invalid sparse file format at unknown block C642 at 38887990
Invalid sparse file format at unknown block 4A98 at 38887992
Invalid sparse file format at unknown block C137 at 38887993
Invalid sparse file format at unknown block F2F4 at 38887994
Invalid sparse file format at unknown block 7414 at 38887995
Invalid sparse file format at unknown block E7CF at 38887996
Invalid sparse file format at unknown block BCE5 at 38887998
Invalid sparse file format at unknown block 48B7 at 38887999
Invalid sparse file format at unknown block 1C4A at 38888000
Invalid sparse file format at unknown block 006E at 38888001
Invalid sparse file format at unknown block 2209 at 38888002
Invalid sparse file format at unknown block 9CFA at 38888004
Invalid sparse file format at unknown block C9E0 at 38888005
Invalid sparse file format at unknown block C4E2 at 38888006
Invalid sparse file format at unknown block 55C9 at 38888007
Invalid sparse file format at unknown block F704 at 38888008
Invalid sparse file format at unknown block 4363 at 38888010
Invalid sparse file format at unknown block 5C27 at 38888011
Invalid sparse file format at unknown block 616C at 38888012
Invalid sparse file format at unknown block 0F25 at 38888013
Invalid sparse file format at unknown block 5D98 at 38888014
Invalid sparse file format at unknown block 466E at 38888016
Invalid sparse file format at unknown block DB26 at 38888017
Invalid sparse file format at unknown block 20AB at 38888018
Invalid sparse file format at unknown block 3FEC at 38888019
Invalid sparse file format at unknown block 158D at 38888020
Invalid sparse file format at unknown block A317 at 38888022
Invalid sparse file format at unknown block 8F80 at 38888023
Invalid sparse file format at unknown block 77DA at 38888024
Invalid sparse file format at unknown block 0566 at 38888025
Invalid sparse file format at unknown block 7E7A at 38888026
Invalid sparse file format at unknown block BBD8 at 38888028
Invalid sparse file format at unknown block E8E4 at 38888029
Invalid sparse file format at unknown block 7100 at 38888030
Invalid sparse file format at unknown block EB30 at 38888031
Invalid sparse file format at unknown block 7727 at 38888032
Invalid sparse file format at unknown block 97A4 at 38888034
Invalid sparse file format at unknown block 588E at 38888035
Invalid sparse file format at unknown block E770 at 38888036
Invalid sparse file format at unknown block B2AB at 38888037
Invalid sparse file format at unknown block A656 at 38888038
Invalid sparse file format at unknown block 6C3B at 38888040
Invalid sparse file format at unknown block D207 at 38888041
Invalid sparse file format at unknown block B9B1 at 38888042
Invalid sparse file format at unknown block CBF2 at 38888043
Invalid sparse file format at unknown block C8C5 at 38888044
Invalid sparse file format at unknown block 98F7 at 38888046
Invalid sparse file format at unknown block E8A7 at 38888047
Invalid sparse file format at unknown block C63B at 38888048
Invalid sparse file format at unknown block F71C at 38888049
Invalid sparse file format at unknown block B14E at 38888050
Invalid sparse file format at unknown block 8278 at 38888052
Invalid sparse file format at unknown block EDD0 at 38888053
Invalid sparse file format at unknown block F35F at 38888054
Invalid sparse file format at unknown block 24DD at 38888055
Invalid sparse file format at unknown block E8A3 at 38888056
Invalid sparse file format at unknown block 7A07 at 38888058
Invalid sparse file format at unknown block 76BB at 38888059
Invalid sparse file format at unknown block 11B8 at 38888060
Invalid sparse file format at unknown block 00A9 at 38888061
Invalid sparse file format at unknown block 6089 at 38888062
Invalid sparse file format at unknown block 3537 at 38888064
Invalid sparse file format at unknown block 8227 at 38888065
Invalid sparse file format at unknown block 5084 at 38888066
Invalid sparse file format at unknown block 1A3A at 38888067
Invalid sparse file format at unknown block 1A64 at 38888068
Invalid sparse file format at unknown block 966B at 38888070
Invalid sparse file format at unknown block 02E4 at 38888071
Invalid sparse file format at unknown block 7E1C at 38888072
Invalid sparse file format at unknown block 2A03 at 38888073
Invalid sparse file format at unknown block D0EC at 38888074
Invalid sparse file format at unknown block 0360 at 38888076
Invalid sparse file format at unknown block 1B6E at 38888077
Invalid sparse file format at unknown block C5ED at 38888078
Invalid sparse file format at unknown block C723 at 38888079
Invalid sparse file format at unknown block EA21 at 38888080
Invalid sparse file format at unknown block 5806 at 38888082
Invalid sparse file format at unknown block 3FE9 at 38888083
Invalid sparse file format at unknown block 16DD at 38888084
Invalid sparse file format at unknown block 8806 at 38888085
Invalid sparse file format at unknown block 898B at 38888086
Invalid sparse file format at unknown block A65D at 38888088
Invalid sparse file format at unknown block BF71 at 38888089
Invalid sparse file format at unknown block 924B at 38888090
Invalid sparse file format at unknown block FEDD at 38888091
Invalid sparse file format at unknown block 7289 at 38888092
Invalid sparse file format at unknown block 00DC at 38888094
Invalid sparse file format at unknown block A443 at 38888095
Invalid sparse file format at unknown block 201E at 38888096
Invalid sparse file format at unknown block 6979 at 38888097
Invalid sparse file format at unknown block 7F7E at 38888098
Invalid sparse file format at unknown block DB73 at 38888100
Invalid sparse file format at unknown block 34DA at 38888101
Invalid sparse file format at unknown block F2E9 at 38888102
Invalid sparse file format at unknown block 7A6C at 38888103
Invalid sparse file format at unknown block E405 at 38888104
Invalid sparse file format at unknown block 1BE0 at 38888106
Invalid sparse file format at unknown block EF73 at 38888107
Invalid sparse file format at unknown block 3F50 at 38888108
Invalid sparse file format at unknown block EF6B at 38888109
Invalid sparse file format at unknown block 68C2 at 38888110
Invalid sparse file format at unknown block 19D0 at 38888112
Invalid sparse file format at unknown block 77C3 at 38888113
Invalid sparse file format at unknown block E120 at 38888114
Invalid sparse file format at unknown block D7A9 at 38888115
Invalid sparse file format at unknown block C0D0 at 38888116
Invalid sparse file format at unknown block 817B at 38888118
Invalid sparse file format at unknown block CEE6 at 38888119
Invalid sparse file format at unknown block 5386 at 38888120
Invalid sparse file format at unknown block 5FBF at 38888121
Invalid sparse file format at unknown block 12E8 at 38888122
Invalid sparse file format at unknown block 1354 at 38888124
Invalid sparse file format at unknown block A300 at 38888125
Invalid sparse file format at unknown block C110 at 38888126
Invalid sparse file format at unknown block DEC1 at 38888127
Invalid sparse file format at unknown block AC36 at 38888128
Invalid sparse file format at unknown block 0450 at 38888130
Invalid sparse file format at unknown block D8A5 at 38888131
Invalid sparse file format at unknown block CDFC at 38888132
Invalid sparse file format at unknown block 6FFF at 38888133
Invalid sparse file format at unknown block 29E6 at 38888134
Invalid sparse file format at unknown block A428 at 38888136
Invalid sparse file format at unknown block D8B1 at 38888137
Invalid sparse file format at unknown block B87A at 38888138
Invalid sparse file format at unknown block 04BC at 38888139
Invalid sparse file format at unknown block 60DB at 38888140
Invalid sparse file format at unknown block 0FDD at 38888142
Invalid sparse file format at unknown block F18C at 38888143
Invalid sparse file format at unknown block 3E1E at 38888144
Invalid sparse file format at unknown block 817F at 38888145
Invalid sparse file format at unknown block F875 at 38888146
Invalid sparse file format at unknown block 76E9 at 38888148
Invalid sparse file format at unknown block 43D7 at 38888149
Invalid sparse file format at unknown block B8A3 at 38888150
Invalid sparse file format at unknown block 705A at 38888151
Invalid sparse file format at unknown block 042E at 38888152
Invalid sparse file format at unknown block E05D at 38888154
Invalid sparse file format at unknown block 4FF6 at 38888155
Invalid sparse file format at unknown block 4DB5 at 38888156
Invalid sparse file format at unknown block 4281 at 38888157
Invalid sparse file format at unknown block 8389 at 38888158
Invalid sparse file format at unknown block E673 at 38888160
Invalid sparse file format at unknown block 7D9D at 38888161
Invalid sparse file format at unknown block 70C0 at 38888162
Invalid sparse file format at unknown block 4418 at 38888163
Invalid sparse file format at unknown block EBE0 at 38888164
Invalid sparse file format at unknown block 1D3D at 38888166
Invalid sparse file format at unknown block F5C4 at 38888167
Invalid sparse file format at unknown block F33C at 38888168
Invalid sparse file format at unknown block 3E4F at 38888169
Invalid sparse file format at unknown block 79B2 at 38888170
Invalid sparse file format at unknown block 3F57 at 38888172
Invalid sparse file format at unknown block DDD9 at 38888173
Invalid sparse file format at unknown block D730 at 38888174
Invalid sparse file format at unknown block 2879 at 38888175
Invalid sparse file format at unknown block F7A0 at 38888176
Invalid sparse file format at unknown block 5E21 at 38888178
Invalid sparse file format at unknown block A41F at 38888179
Invalid sparse file format at unknown block 6AB5 at 38888180
Invalid sparse file format at unknown block E8DB at 38888181
Invalid sparse file format at unknown block A51E at 38888182
Invalid sparse file format at unknown block 19AA at 38888184
Invalid sparse file format at unknown block 2BCF at 38888185
Invalid sparse file format at unknown block 8561 at 38888186
Invalid sparse file format at unknown block B932 at 38888187
Invalid sparse file format at unknown block 5C28 at 38888188
Invalid sparse file format at unknown block 41F4 at 38888190
Invalid sparse file format at unknown block 6942 at 38888191
Invalid sparse file format at unknown block 1F05 at 38888192
Invalid sparse file format at unknown block 7E1B at 38888193
Invalid sparse file format at unknown block 423C at 38888194
Invalid sparse file format at unknown block C66A at 38888196
Invalid sparse file format at unknown block C27D at 38888197
Invalid sparse file format at unknown block 0835 at 38888198
Invalid sparse file format at unknown block AFF5 at 38888199
Invalid sparse file format at unknown block C93C at 38888200
Invalid sparse file format at unknown block A4A1 at 38888202
Invalid sparse file format at unknown block 43FC at 38888203
Invalid sparse file format at unknown block 1CB4 at 38888204
Invalid sparse file format at unknown block B4A4 at 38888205
Invalid sparse file format at unknown block 1174 at 38888206
Invalid sparse file format at unknown block FF0C at 38888208
Invalid sparse file format at unknown block FC2F at 38888209
Invalid sparse file format at unknown block F151 at 38888210
Invalid sparse file format at unknown block 8403 at 38888211
Invalid sparse file format at unknown block 3BE1 at 38888212
Invalid sparse file format at unknown block CDDC at 38888214
Invalid sparse file format at unknown block BE7D at 38888215
Invalid sparse file format at unknown block 5EAB at 38888216
Invalid sparse file format at unknown block AF8C at 38888217
Invalid sparse file format at unknown block 454E at 38888218
Invalid sparse file format at unknown block C15B at 38888220
Invalid sparse file format at unknown block E4B3 at 38888221
Invalid sparse file format at unknown block C025 at 38888222
Invalid sparse file format at unknown block 0527 at 38888223
Invalid sparse file format at unknown block 35B5 at 38888224
Invalid sparse file format at unknown block 3063 at 38888226
Invalid sparse file format at unknown block 70D7 at 38888227
Invalid sparse file format at unknown block 70DE at 38888228
Invalid sparse file format at unknown block 864F at 38888229
Invalid sparse file format at unknown block 09B7 at 38888230
Invalid sparse file format at unknown block B755 at 38888232
Invalid sparse file format at unknown block C484 at 38888233
Invalid sparse file format at unknown block 6AEE at 38888234
Invalid sparse file format at unknown block DCE6 at 38888235
Invalid sparse file format at unknown block F2E5 at 38888236
Invalid sparse file format at unknown block 18EC at 38888238
Invalid sparse file format at unknown block 33B5 at 38888239
Invalid sparse file format at unknown block 172B at 38888240
Invalid sparse file format at unknown block 0BB6 at 38888241
Invalid sparse file format at unknown block 0BB0 at 38888242
Invalid sparse file format at unknown block 3E7E at 38888244
Invalid sparse file format at unknown block 5510 at 38888245
Invalid sparse file format at unknown block CCD2 at 38888246
Invalid sparse file format at unknown block 442A at 38888247
Invalid sparse file format at unknown block DF08 at 38888248
Invalid sparse file format at unknown block BB97 at 38888250
Invalid sparse file format at unknown block C3FA at 38888251
Invalid sparse file format at unknown block F1B4 at 38888252
Invalid sparse file format at unknown block 2B2D at 38888253
Invalid sparse file format at unknown block 4F22 at 38888254
Invalid sparse file format at unknown block F64C at 38888256
Invalid sparse file format at unknown block 1E3A at 38888257
Invalid sparse file format at unknown block 0998 at 38888258
Invalid sparse file format at unknown block 96B6 at 38888259
Invalid sparse file format at unknown block 9F6C at 38888260
Invalid sparse file format at unknown block 578C at 38888262
Invalid sparse file format at unknown block 98DF at 38888263
Invalid sparse file format at unknown block 773B at 38888264
Invalid sparse file format at unknown block EA3B at 38888265
Invalid sparse file format at unknown block 275E at 38888266
Invalid sparse file format at unknown block 2D7E at 38888268
Invalid sparse file format at unknown block B1C8 at 38888269
Invalid sparse file format at unknown block A96F at 38888270
Invalid sparse file format at unknown block 8B7F at 38888271
Invalid sparse file format at unknown block 0490 at 38888272
Invalid sparse file format at unknown block 065F at 38888274
Invalid sparse file format at unknown block 3576 at 38888275
Invalid sparse file format at unknown block 6405 at 38888276
Invalid sparse file format at unknown block 8E66 at 38888277
Invalid sparse file format at unknown block 8AAC at 38888278
Invalid sparse file format at unknown block FAA1 at 38888280
Invalid sparse file format at unknown block 13E8 at 38888281
Invalid sparse file format at unknown block 867D at 38888282
Invalid sparse file format at unknown block B5B0 at 38888283
Invalid sparse file format at unknown block 2555 at 38888284
Invalid sparse file format at unknown block 010D at 38888286
Invalid sparse file format at unknown block C5E4 at 38888287
Invalid sparse file format at unknown block 0537 at 38888288
Invalid sparse file format at unknown block C959 at 38888289
Invalid sparse file format at unknown block F05E at 38888290
Invalid sparse file format at unknown block 51B7 at 38888292
Invalid sparse file format at unknown block C2B1 at 38888293
Invalid sparse file format at unknown block 59A3 at 38888294
Invalid sparse file format at unknown block 8395 at 38888295
Invalid sparse file format at unknown block 8260 at 38888296
Invalid sparse file format at unknown block A95C at 38888298
Invalid sparse file format at unknown block 936C at 38888299
Invalid sparse file format at unknown block 30FC at 38888300
Invalid sparse file format at unknown block E6C8 at 38888301
Invalid sparse file format at unknown block 3437 at 38888302
Invalid sparse file format at unknown block C448 at 38888304
Invalid sparse file format at unknown block C8C4 at 38888305
Invalid sparse file format at unknown block 82C8 at 38888306
Invalid sparse file format at unknown block D6E8 at 38888307
Invalid sparse file format at unknown block 1D6E at 38888308
Invalid sparse file format at unknown block DA1B at 38888310
Invalid sparse file format at unknown block CDA4 at 38888311
Invalid sparse file format at unknown block D6A5 at 38888312
Invalid sparse file format at unknown block 23E8 at 38888313
Invalid sparse file format at unknown block 7576 at 38888314
Invalid sparse file format at unknown block F8DE at 38888316
Invalid sparse file format at unknown block 143F at 38888317
Invalid sparse file format at unknown block BECA at 38888318
Invalid sparse file format at unknown block 24CA at 38888319
Invalid sparse file format at unknown block 6A3F at 38888320
Invalid sparse file format at unknown block C538 at 38888322
Invalid sparse file format at unknown block 51A5 at 38888323
Invalid sparse file format at unknown block 59E6 at 38888324
Invalid sparse file format at unknown block C159 at 38888325
Invalid sparse file format at unknown block 938D at 38888326
Invalid sparse file format at unknown block 0D22 at 38888328
Invalid sparse file format at unknown block 1D57 at 38888329
Invalid sparse file format at unknown block 5B62 at 38888330
Invalid sparse file format at unknown block B395 at 38888331
Invalid sparse file format at unknown block E7C9 at 38888332
Invalid sparse file format at unknown block B58A at 38888334
Invalid sparse file format at unknown block E38D at 38888335
Invalid sparse file format at unknown block 36FD at 38888336
Invalid sparse file format at unknown block E68A at 38888337
Invalid sparse file format at unknown block 3C33 at 38888338
Invalid sparse file format at unknown block 15A6 at 38888340
Invalid sparse file format at unknown block 59E3 at 38888341
Invalid sparse file format at unknown block 35F6 at 38888342
Invalid sparse file format at unknown block B565 at 38888343
Invalid sparse file format at unknown block E169 at 38888344
Invalid sparse file format at unknown block 643C at 38888346
Invalid sparse file format at unknown block 0B4B at 38888347
Invalid sparse file format at unknown block F388 at 38888348
Invalid sparse file format at unknown block 5F90 at 38888349
Invalid sparse file format at unknown block 9252 at 38888350
Invalid sparse file format at unknown block C047 at 38888352
Invalid sparse file format at unknown block 257E at 38888353
Invalid sparse file format at unknown block 6929 at 38888354
Invalid sparse file format at unknown block 624B at 38888355
Invalid sparse file format at unknown block 0832 at 38888356
Invalid sparse file format at unknown block 391C at 38888358
Invalid sparse file format at unknown block FECA at 38888359
Invalid sparse file format at unknown block AE29 at 38888360
Invalid sparse file format at unknown block B6C5 at 38888361
Invalid sparse file format at unknown block C327 at 38888362
Invalid sparse file format at unknown block C69B at 38888364
Invalid sparse file format at unknown block E6ED at 38888365
Invalid sparse file format at unknown block 26E6 at 38888366
Invalid sparse file format at unknown block 9738 at 38888367
Invalid sparse file format at unknown block 9B8F at 38888368
Invalid sparse file format at unknown block 0E40 at 38888370
Invalid sparse file format at unknown block EF27 at 38888371
Invalid sparse file format at unknown block 73EB at 38888372
Invalid sparse file format at unknown block 61E1 at 38888373
Invalid sparse file format at unknown block 69A6 at 38888374
Invalid sparse file format at unknown block 25E6 at 38888376
Invalid sparse file format at unknown block 45E7 at 38888377
Invalid sparse file format at unknown block DAB0 at 38888378
Invalid sparse file format at unknown block C936 at 38888379
Invalid sparse file format at unknown block 8784 at 38888380
Invalid sparse file format at unknown block 1FD3 at 38888382
Invalid sparse file format at unknown block 0BFE at 38888383
Invalid sparse file format at unknown block 47DF at 38888384
Invalid sparse file format at unknown block 9764 at 38888385
Invalid sparse file format at unknown block E9B8 at 38888386
Invalid sparse file format at unknown block 9DD7 at 38888388
Invalid sparse file format at unknown block 1886 at 38888389
Invalid sparse file format at unknown block BED9 at 38888390
Invalid sparse file format at unknown block 38C2 at 38888391
Invalid sparse file format at unknown block E861 at 38888392
Invalid sparse file format at unknown block DB19 at 38888394
Invalid sparse file format at unknown block 7585 at 38888395
Invalid sparse file format at unknown block 35F9 at 38888396
Invalid sparse file format at unknown block B443 at 38888397
Invalid sparse file format at unknown block F48B at 38888398
Invalid sparse file format at unknown block DA5E at 38888400
Invalid sparse file format at unknown block 106B at 38888401
Invalid sparse file format at unknown block 632D at 38888402
Invalid sparse file format at unknown block B2A7 at 38888403
Invalid sparse file format at unknown block 9EE6 at 38888404
Invalid sparse file format at unknown block 2A2F at 38888406
Invalid sparse file format at unknown block C2D2 at 38888407
Invalid sparse file format at unknown block 480A at 38888408
Invalid sparse file format at unknown block C2AD at 38888409
Invalid sparse file format at unknown block 32E1 at 38888410
Invalid sparse file format at unknown block 171D at 38888412
Invalid sparse file format at unknown block 3514 at 38888413
Invalid sparse file format at unknown block BD14 at 38888414
Invalid sparse file format at unknown block 6983 at 38888415
Invalid sparse file format at unknown block B0B8 at 38888416
Invalid sparse file format at unknown block DA59 at 38888418
Invalid sparse file format at unknown block 95A2 at 38888419
Invalid sparse file format at unknown block 6882 at 38888420
Invalid sparse file format at unknown block 1233 at 38888421
Invalid sparse file format at unknown block 7311 at 38888422
Invalid sparse file format at unknown block 69F3 at 38888424
Invalid sparse file format at unknown block 9048 at 38888425
Invalid sparse file format at unknown block 410D at 38888426
Invalid sparse file format at unknown block C20D at 38888427
Invalid sparse file format at unknown block 736F at 38888428
Invalid sparse file format at unknown block D5F5 at 38888430
Invalid sparse file format at unknown block 246E at 38888431
Invalid sparse file format at unknown block 4B8B at 38888432
Invalid sparse file format at unknown block 75E9 at 38888433
Invalid sparse file format at unknown block 1C0C at 38888434
Invalid sparse file format at unknown block 121F at 38888436
Invalid sparse file format at unknown block 689E at 38888437
Invalid sparse file format at unknown block F4BF at 38888438
Invalid sparse file format at unknown block C1EA at 38888439
Invalid sparse file format at unknown block 103C at 38888440
Invalid sparse file format at unknown block 4202 at 38888442
Invalid sparse file format at unknown block C1FB at 38888443
Invalid sparse file format at unknown block 2AEB at 38888444
Invalid sparse file format at unknown block D537 at 38888445
Invalid sparse file format at unknown block 43B3 at 38888446
Invalid sparse file format at unknown block FE3B at 38888448
Invalid sparse file format at unknown block 5B9E at 38888449
Invalid sparse file format at unknown block ADA8 at 38888450
Invalid sparse file format at unknown block 3F30 at 38888451
Invalid sparse file format at unknown block FAC2 at 38888452
Invalid sparse file format at unknown block 0F4B at 38888454
Invalid sparse file format at unknown block 19DC at 38888455
Invalid sparse file format at unknown block F4B4 at 38888456
Invalid sparse file format at unknown block B9F0 at 38888457
Invalid sparse file format at unknown block 9E3A at 38888458
Invalid sparse file format at unknown block F47F at 38888460
Invalid sparse file format at unknown block 24F1 at 38888461
Invalid sparse file format at unknown block 5455 at 38888462
Invalid sparse file format at unknown block 8AB5 at 38888463
Invalid sparse file format at unknown block F009 at 38888464
Invalid sparse file format at unknown block 61F2 at 38888466
Invalid sparse file format at unknown block DE95 at 38888467
Invalid sparse file format at unknown block 171F at 38888468
Invalid sparse file format at unknown block 9F18 at 38888469
Invalid sparse file format at unknown block A732 at 38888470
Invalid sparse file format at unknown block 258B at 38888472
Invalid sparse file format at unknown block 3FB0 at 38888473
Invalid sparse file format at unknown block EFAF at 38888474
Invalid sparse file format at unknown block FC8D at 38888475
Invalid sparse file format at unknown block 421B at 38888476
Invalid sparse file format at unknown block 5D4C at 38888478
Invalid sparse file format at unknown block F306 at 38888479
Invalid sparse file format at unknown block 3A9A at 38888480
Invalid sparse file format at unknown block 33E8 at 38888481
Invalid sparse file format at unknown block C357 at 38888482
Invalid sparse file format at unknown block 5E0E at 38888484
Invalid sparse file format at unknown block 331F at 38888485
Invalid sparse file format at unknown block F336 at 38888486
Invalid sparse file format at unknown block 1F4C at 38888487
Invalid sparse file format at unknown block 6B73 at 38888488
Invalid sparse file format at unknown block ABB7 at 38888490
Invalid sparse file format at unknown block 7831 at 38888491
Invalid sparse file format at unknown block 67D6 at 38888492
Invalid sparse file format at unknown block AE86 at 38888493
Invalid sparse file format at unknown block EB8B at 38888494
Invalid sparse file format at unknown block 28D2 at 38888496
Invalid sparse file format at unknown block 595F at 38888497
Invalid sparse file format at unknown block BE02 at 38888498
Invalid sparse file format at unknown block B53E at 38888499
Invalid sparse file format at unknown block 296F at 38888500
Invalid sparse file format at unknown block D0FD at 38888502
Invalid sparse file format at unknown block 9EAE at 38888503
Invalid sparse file format at unknown block 1308 at 38888504
Invalid sparse file format at unknown block 9CC0 at 38888505
Invalid sparse file format at unknown block 592B at 38888506
Invalid sparse file format at unknown block 688D at 38888508
Invalid sparse file format at unknown block A73E at 38888509
Invalid sparse file format at unknown block B479 at 38888510
Invalid sparse file format at unknown block CCE9 at 38888511
Invalid sparse file format at unknown block 27E7 at 38888512
Invalid sparse file format at unknown block EA2B at 38888514
Invalid sparse file format at unknown block DA1A at 38888515
Invalid sparse file format at unknown block 90AB at 38888516
Invalid sparse file format at unknown block 0362 at 38888517
Invalid sparse file format at unknown block 124C at 38888518
Invalid sparse file format at unknown block 5849 at 38888520
Invalid sparse file format at unknown block D64C at 38888521
Invalid sparse file format at unknown block F9A7 at 38888522
Invalid sparse file format at unknown block 4FD3 at 38888523
Invalid sparse file format at unknown block 98B5 at 38888524
Invalid sparse file format at unknown block 96E5 at 38888526
Invalid sparse file format at unknown block AB82 at 38888527
Invalid sparse file format at unknown block 7E0A at 38888528
Invalid sparse file format at unknown block 6898 at 38888529
Invalid sparse file format at unknown block A2A8 at 38888530
Invalid sparse file format at unknown block 8A4F at 38888532
Invalid sparse file format at unknown block 56AF at 38888533
Invalid sparse file format at unknown block 85C9 at 38888534
Invalid sparse file format at unknown block A387 at 38888535
Invalid sparse file format at unknown block DD9E at 38888536
Invalid sparse file format at unknown block 902C at 38888538
Invalid sparse file format at unknown block C6F6 at 38888539
Invalid sparse file format at unknown block 39F8 at 38888540
Invalid sparse file format at unknown block 658B at 38888541
Invalid sparse file format at unknown block 2976 at 38888542
Invalid sparse file format at unknown block 098D at 38888544
Invalid sparse file format at unknown block 0E00 at 38888545
Invalid sparse file format at unknown block 2DED at 38888546
Invalid sparse file format at unknown block B002 at 38888547
Invalid sparse file format at unknown block DA0C at 38888548
Invalid sparse file format at unknown block CA53 at 38888550
Invalid sparse file format at unknown block BC76 at 38888551
Invalid sparse file format at unknown block CB59 at 38888552
Invalid sparse file format at unknown block BD68 at 38888553
Invalid sparse file format at unknown block DFE2 at 38888554
Invalid sparse file format at unknown block 56F4 at 38888556
Invalid sparse file format at unknown block 4F4B at 38888557
Invalid sparse file format at unknown block 3D02 at 38888558
Invalid sparse file format at unknown block D4B2 at 38888559
Invalid sparse file format at unknown block 6884 at 38888560
Invalid sparse file format at unknown block B886 at 38888562
Invalid sparse file format at unknown block 8A30 at 38888563
Invalid sparse file format at unknown block 6195 at 38888564
Invalid sparse file format at unknown block 0DAA at 38888565
Invalid sparse file format at unknown block D14F at 38888566
Invalid sparse file format at unknown block 485B at 38888568
Invalid sparse file format at unknown block D82B at 38888569
Invalid sparse file format at unknown block 334A at 38888570
Invalid sparse file format at unknown block D3B8 at 38888571
Invalid sparse file format at unknown block CAAF at 38888572
Invalid sparse file format at unknown block 9F7E at 38888574
Invalid sparse file format at unknown block 040A at 38888575
Invalid sparse file format at unknown block 6EBF at 38888576
Invalid sparse file format at unknown block 0EBB at 38888577
Invalid sparse file format at unknown block 10C5 at 38888578
Invalid sparse file format at unknown block 6551 at 38888580
Invalid sparse file format at unknown block A304 at 38888581
Invalid sparse file format at unknown block 63EA at 38888582
Invalid sparse file format at unknown block F989 at 38888583
Invalid sparse file format at unknown block 0050 at 38888584
Invalid sparse file format at unknown block 86C7 at 38888586
Invalid sparse file format at unknown block DD20 at 38888587
Invalid sparse file format at unknown block F971 at 38888588
Invalid sparse file format at unknown block 8D9D at 38888589
Invalid sparse file format at unknown block 1956 at 38888590
Invalid sparse file format at unknown block CBD1 at 38888592
Invalid sparse file format at unknown block DEA0 at 38888593
Invalid sparse file format at unknown block 9A17 at 38888594
Invalid sparse file format at unknown block 934F at 38888595
Invalid sparse file format at unknown block A154 at 38888596
Invalid sparse file format at unknown block C33C at 38888598
Invalid sparse file format at unknown block D1C8 at 38888599
Invalid sparse file format at unknown block 4B5C at 38888600
Invalid sparse file format at unknown block 06CB at 38888601
Invalid sparse file format at unknown block 2B73 at 38888602
Invalid sparse file format at unknown block 10C7 at 38888604
Invalid sparse file format at unknown block FEE8 at 38888605
Invalid sparse file format at unknown block A56B at 38888606
Invalid sparse file format at unknown block A1C9 at 38888607
Invalid sparse file format at unknown block C393 at 38888608
Invalid sparse file format at unknown block 8BFA at 38888610
Invalid sparse file format at unknown block B561 at 38888611
Invalid sparse file format at unknown block 9182 at 38888612
Invalid sparse file format at unknown block 42A3 at 38888613
Invalid sparse file format at unknown block 4BFA at 38888614
Invalid sparse file format at unknown block 682E at 38888616
Invalid sparse file format at unknown block 7E56 at 38888617
Invalid sparse file format at unknown block 5B85 at 38888618
Invalid sparse file format at unknown block 4389 at 38888619
Invalid sparse file format at unknown block F060 at 38888620
Invalid sparse file format at unknown block 9E03 at 38888622
Invalid sparse file format at unknown block B9A7 at 38888623
Invalid sparse file format at unknown block EB83 at 38888624
Invalid sparse file format at unknown block A217 at 38888625
Invalid sparse file format at unknown block 4126 at 38888626
Invalid sparse file format at unknown block 0A07 at 38888628
Invalid sparse file format at unknown block 2B1C at 38888629
Invalid sparse file format at unknown block F05A at 38888630
Invalid sparse file format at unknown block 7873 at 38888631
Invalid sparse file format at unknown block F1EA at 38888632
Invalid sparse file format at unknown block 67AB at 38888634
Invalid sparse file format at unknown block E322 at 38888635
Invalid sparse file format at unknown block B78E at 38888636
Invalid sparse file format at unknown block 38E9 at 38888637
Invalid sparse file format at unknown block B325 at 38888638
Invalid sparse file format at unknown block 4681 at 38888640
Invalid sparse file format at unknown block 54B4 at 38888641
Invalid sparse file format at unknown block EF57 at 38888642
Invalid sparse file format at unknown block 847E at 38888643
Invalid sparse file format at unknown block 2DDE at 38888644
Invalid sparse file format at unknown block 84ED at 38888646
Invalid sparse file format at unknown block 8E13 at 38888647
Invalid sparse file format at unknown block 18A6 at 38888648
Invalid sparse file format at unknown block 5E20 at 38888649
Invalid sparse file format at unknown block 330C at 38888650
Invalid sparse file format at unknown block D51A at 38888652
Invalid sparse file format at unknown block 9E29 at 38888653
Invalid sparse file format at unknown block 2F00 at 38888654
Invalid sparse file format at unknown block 4880 at 38888655
Invalid sparse file format at unknown block 1CDA at 38888656
Invalid sparse file format at unknown block 694A at 38888658
Invalid sparse file format at unknown block 53F1 at 38888659
Invalid sparse file format at unknown block BDFC at 38888660
Invalid sparse file format at unknown block 1EE1 at 38888661
Invalid sparse file format at unknown block 293B at 38888662
Invalid sparse file format at unknown block A40C at 38888664
Invalid sparse file format at unknown block BF16 at 38888665
Invalid sparse file format at unknown block 129C at 38888666
Invalid sparse file format at unknown block 2CC7 at 38888667
Invalid sparse file format at unknown block C706 at 38888668
Invalid sparse file format at unknown block 31E1 at 38888670
Invalid sparse file format at unknown block 38AE at 38888671
Invalid sparse file format at unknown block 2B60 at 38888672
Invalid sparse file format at unknown block 3FC1 at 38888673
Invalid sparse file format at unknown block 03C9 at 38888674
Invalid sparse file format at unknown block 6E8D at 38888676
Invalid sparse file format at unknown block 8539 at 38888677
Invalid sparse file format at unknown block 32F0 at 38888678
Invalid sparse file format at unknown block 2D94 at 38888679
Invalid sparse file format at unknown block 35A0 at 38888680
Invalid sparse file format at unknown block A46A at 38888682
Invalid sparse file format at unknown block 37A3 at 38888683
Invalid sparse file format at unknown block 44BF at 38888684
Invalid sparse file format at unknown block 9DA1 at 38888685
Invalid sparse file format at unknown block 794C at 38888686
Invalid sparse file format at unknown block C878 at 38888688
Invalid sparse file format at unknown block E0C0 at 38888689
Invalid sparse file format at unknown block A5D1 at 38888690
Invalid sparse file format at unknown block 76BA at 38888691
Invalid sparse file format at unknown block 25F3 at 38888692
Invalid sparse file format at unknown block B4F8 at 38888694
Invalid sparse file format at unknown block 10E4 at 38888695
Invalid sparse file format at unknown block 3591 at 38888696
Invalid sparse file format at unknown block 338F at 38888697
Invalid sparse file format at unknown block 4ABF at 38888698
Invalid sparse file format at unknown block 735E at 38888700
Invalid sparse file format at unknown block A30B at 38888701
Invalid sparse file format at unknown block 4E0A at 38888702
Invalid sparse file format at unknown block 521D at 38888703
Invalid sparse file format at unknown block C56A at 38888704
Invalid sparse file format at unknown block 1B15 at 38888706
Invalid sparse file format at unknown block 7E7B at 38888707
Invalid sparse file format at unknown block 32F6 at 38888708
Invalid sparse file format at unknown block 6993 at 38888709
Invalid sparse file format at unknown block 6A6A at 38888710
Invalid sparse file format at unknown block 11EE at 38888712
Invalid sparse file format at unknown block C1EA at 38888713
Invalid sparse file format at unknown block D6FB at 38888714
Invalid sparse file format at unknown block 1919 at 38888715
Invalid sparse file format at unknown block 13C3 at 38888716
Invalid sparse file format at unknown block 062F at 38888718
Invalid sparse file format at unknown block 6907 at 38888719
Invalid sparse file format at unknown block 01CA at 38888720
Invalid sparse file format at unknown block 1590 at 38888721
Invalid sparse file format at unknown block 0713 at 38888722
Invalid sparse file format at unknown block 273D at 38888724
Invalid sparse file format at unknown block 9BEB at 38888725
Invalid sparse file format at unknown block E1B5 at 38888726
Invalid sparse file format at unknown block 3343 at 38888727
Invalid sparse file format at unknown block E95E at 38888728
Invalid sparse file format at unknown block C9A9 at 38888730
Invalid sparse file format at unknown block 937C at 38888731
Invalid sparse file format at unknown block 6F5A at 38888732
Invalid sparse file format at unknown block 311A at 38888733
Invalid sparse file format at unknown block 2718 at 38888734
Invalid sparse file format at unknown block 60A8 at 38888736
Invalid sparse file format at unknown block AA78 at 38888737
Invalid sparse file format at unknown block E530 at 38888738
Invalid sparse file format at unknown block F253 at 38888739
Invalid sparse file format at unknown block 97E4 at 38888740
Invalid sparse file format at unknown block 10C5 at 38888742
Invalid sparse file format at unknown block E15D at 38888743
Invalid sparse file format at unknown block 59D0 at 38888744
Invalid sparse file format at unknown block 63B8 at 38888745
Invalid sparse file format at unknown block 9BBD at 38888746
Invalid sparse file format at unknown block 65C7 at 38888748
Invalid sparse file format at unknown block 97D0 at 38888749
Invalid sparse file format at unknown block 6299 at 38888750
Invalid sparse file format at unknown block E06B at 38888751
Invalid sparse file format at unknown block 8F0D at 38888752
Invalid sparse file format at unknown block 2638 at 38888754
Invalid sparse file format at unknown block F91F at 38888755
Invalid sparse file format at unknown block 7E7F at 38888756
Invalid sparse file format at unknown block 8C71 at 38888757
Invalid sparse file format at unknown block E921 at 38888758
Invalid sparse file format at unknown block 5707 at 38888760
Invalid sparse file format at unknown block EFB5 at 38888761
Invalid sparse file format at unknown block 4B72 at 38888762
Invalid sparse file format at unknown block 408A at 38888763
Invalid sparse file format at unknown block A69D at 38888764
Invalid sparse file format at unknown block 3826 at 38888766
Invalid sparse file format at unknown block 01F9 at 38888767
Invalid sparse file format at unknown block EF4A at 38888768
Invalid sparse file format at unknown block E299 at 38888769
Invalid sparse file format at unknown block 22C0 at 38888770
Invalid sparse file format at unknown block AA37 at 38888772
Invalid sparse file format at unknown block 06AC at 38888773
Invalid sparse file format at unknown block 115A at 38888774
Invalid sparse file format at unknown block F704 at 38888775
Invalid sparse file format at unknown block 9CEF at 38888776
Invalid sparse file format at unknown block FF05 at 38888778
Invalid sparse file format at unknown block 314D at 38888779
Invalid sparse file format at unknown block 1A20 at 38888780
Invalid sparse file format at unknown block D138 at 38888781
Invalid sparse file format at unknown block 3C7B at 38888782
Invalid sparse file format at unknown block 72CE at 38888784
Invalid sparse file format at unknown block BCE0 at 38888785
Invalid sparse file format at unknown block 2DC6 at 38888786
Invalid sparse file format at unknown block 73D3 at 38888787
Invalid sparse file format at unknown block CC7B at 38888788
Invalid sparse file format at unknown block 1CC8 at 38888790
Invalid sparse file format at unknown block 864C at 38888791
Invalid sparse file format at unknown block 0D92 at 38888792
Invalid sparse file format at unknown block 1A71 at 38888793
Invalid sparse file format at unknown block 8C5C at 38888794
Invalid sparse file format at unknown block 7F70 at 38888796
Invalid sparse file format at unknown block 926A at 38888797
Invalid sparse file format at unknown block A891 at 38888798
Invalid sparse file format at unknown block 7663 at 38888799
Invalid sparse file format at unknown block E99E at 38888800
Invalid sparse file format at unknown block D9CA at 38888802
Invalid sparse file format at unknown block CB38 at 38888803
Invalid sparse file format at unknown block 9E85 at 38888804
Invalid sparse file format at unknown block A6AC at 38888805
Invalid sparse file format at unknown block 05EB at 38888806
Invalid sparse file format at unknown block 5AFA at 38888808
Invalid sparse file format at unknown block D811 at 38888809
Invalid sparse file format at unknown block F9FF at 38888810
Invalid sparse file format at unknown block 3B63 at 38888811
Invalid sparse file format at unknown block 822A at 38888812
Invalid sparse file format at unknown block 8121 at 38888814
Invalid sparse file format at unknown block 9094 at 38888815
Invalid sparse file format at unknown block 8359 at 38888816
Invalid sparse file format at unknown block 85BF at 38888817
Invalid sparse file format at unknown block 2D09 at 38888818
Invalid sparse file format at unknown block 5EA3 at 38888820
Invalid sparse file format at unknown block 92D3 at 38888821
Invalid sparse file format at unknown block A732 at 38888822
Invalid sparse file format at unknown block AE9B at 38888823
Invalid sparse file format at unknown block 276E at 38888824
Invalid sparse file format at unknown block 67F8 at 38888826
Invalid sparse file format at unknown block EAF4 at 38888827
Invalid sparse file format at unknown block 78C7 at 38888828
Invalid sparse file format at unknown block 9BDE at 38888829
Invalid sparse file format at unknown block 4F86 at 38888830
Invalid sparse file format at unknown block 8173 at 38888832
Invalid sparse file format at unknown block 0265 at 38888833
Invalid sparse file format at unknown block 582E at 38888834
Invalid sparse file format at unknown block 550D at 38888835
Invalid sparse file format at unknown block D916 at 38888836
Invalid sparse file format at unknown block 1FF7 at 38888838
Invalid sparse file format at unknown block 3AB0 at 38888839
Invalid sparse file format at unknown block 95D5 at 38888840
Invalid sparse file format at unknown block 3458 at 38888841
Invalid sparse file format at unknown block 0CAA at 38888842
Invalid sparse file format at unknown block 26CD at 38888844
Invalid sparse file format at unknown block 3B83 at 38888845
Invalid sparse file format at unknown block F089 at 38888846
Invalid sparse file format at unknown block BBBD at 38888847
Invalid sparse file format at unknown block 6FF4 at 38888848
Invalid sparse file format at unknown block 4476 at 38888850
Invalid sparse file format at unknown block AEEA at 38888851
Invalid sparse file format at unknown block 340A at 38888852
Invalid sparse file format at unknown block 7233 at 38888853
Invalid sparse file format at unknown block A176 at 38888854
Invalid sparse file format at unknown block 0D50 at 38888856
Invalid sparse file format at unknown block 3CCD at 38888857
Invalid sparse file format at unknown block 4E68 at 38888858
Invalid sparse file format at unknown block 78F6 at 38888859
Invalid sparse file format at unknown block 26AD at 38888860
Invalid sparse file format at unknown block E21C at 38888862
Invalid sparse file format at unknown block 23FD at 38888863
Invalid sparse file format at unknown block 0CA9 at 38888864
Invalid sparse file format at unknown block 7113 at 38888865
Invalid sparse file format at unknown block BBCB at 38888866
Invalid sparse file format at unknown block D893 at 38888868
Invalid sparse file format at unknown block 15DA at 38888869
Invalid sparse file format at unknown block EC17 at 38888870
Invalid sparse file format at unknown block 04AE at 38888871
Invalid sparse file format at unknown block DA86 at 38888872
Invalid sparse file format at unknown block 048A at 38888874
Invalid sparse file format at unknown block FAFB at 38888875
Invalid sparse file format at unknown block DB3D at 38888876
Invalid sparse file format at unknown block 9F30 at 38888877
Invalid sparse file format at unknown block A458 at 38888878
Invalid sparse file format at unknown block 6B8C at 38888880
Invalid sparse file format at unknown block D505 at 38888881
Invalid sparse file format at unknown block FB27 at 38888882
Invalid sparse file format at unknown block C745 at 38888883
Invalid sparse file format at unknown block 7989 at 38888884
Invalid sparse file format at unknown block 223B at 38888886
Invalid sparse file format at unknown block 9B84 at 38888887
Invalid sparse file format at unknown block 3F22 at 38888888
Invalid sparse file format at unknown block A196 at 38888889
Invalid sparse file format at unknown block CD2F at 38888890
Invalid sparse file format at unknown block EDCB at 38888892
Invalid sparse file format at unknown block BB33 at 38888893
Invalid sparse file format at unknown block 9C96 at 38888894
Invalid sparse file format at unknown block 6FA2 at 38888895
Invalid sparse file format at unknown block 3AA2 at 38888896
Invalid sparse file format at unknown block 6AB0 at 38888898
Invalid sparse file format at unknown block 4241 at 38888899
Invalid sparse file format at unknown block D926 at 38888900
Invalid sparse file format at unknown block 3CF1 at 38888901
Invalid sparse file format at unknown block F1EC at 38888902
Invalid sparse file format at unknown block 2333 at 38888904
Invalid sparse file format at unknown block 4937 at 38888905
Invalid sparse file format at unknown block 26E4 at 38888906
Invalid sparse file format at unknown block 5B8F at 38888907
Invalid sparse file format at unknown block 5944 at 38888908
Invalid sparse file format at unknown block 0725 at 38888910
Invalid sparse file format at unknown block 7712 at 38888911
Invalid sparse file format at unknown block BC97 at 38888912
Invalid sparse file format at unknown block FCBB at 38888913
Invalid sparse file format at unknown block 7D13 at 38888914
Invalid sparse file format at unknown block F549 at 38888916
Invalid sparse file format at unknown block 20AB at 38888917
Invalid sparse file format at unknown block 901F at 38888918
Invalid sparse file format at unknown block 4DF4 at 38888919
Invalid sparse file format at unknown block 2A4A at 38888920
Invalid sparse file format at unknown block 556C at 38888922
Invalid sparse file format at unknown block 174E at 38888923
Invalid sparse file format at unknown block 7193 at 38888924
Invalid sparse file format at unknown block 3940 at 38888925
Invalid sparse file format at unknown block BB5A at 38888926
Invalid sparse file format at unknown block ACE7 at 38888928
Invalid sparse file format at unknown block 3C8B at 38888929
Invalid sparse file format at unknown block 0B6E at 38888930
Invalid sparse file format at unknown block 6A0F at 38888931
Invalid sparse file format at unknown block 2A29 at 38888932
Invalid sparse file format at unknown block 061E at 38888934
Invalid sparse file format at unknown block 4E99 at 38888935
Invalid sparse file format at unknown block C26A at 38888936
Invalid sparse file format at unknown block 041B at 38888937
Invalid sparse file format at unknown block AD82 at 38888938
Invalid sparse file format at unknown block DEF9 at 38888940
Invalid sparse file format at unknown block 2F29 at 38888941
Invalid sparse file format at unknown block 7A58 at 38888942
Invalid sparse file format at unknown block A96B at 38888943
Invalid sparse file format at unknown block D46D at 38888944
Invalid sparse file format at unknown block 6E40 at 38888946
Invalid sparse file format at unknown block 81B7 at 38888947
Invalid sparse file format at unknown block C9C2 at 38888948
Invalid sparse file format at unknown block 9761 at 38888949
Invalid sparse file format at unknown block 6789 at 38888950
Invalid sparse file format at unknown block 9A8D at 38888952
Invalid sparse file format at unknown block 5270 at 38888953
Invalid sparse file format at unknown block D239 at 38888954
Invalid sparse file format at unknown block 69C9 at 38888955
Invalid sparse file format at unknown block 96FA at 38888956
Invalid sparse file format at unknown block 314A at 38888958
Invalid sparse file format at unknown block 05DA at 38888959
Invalid sparse file format at unknown block 5B7D at 38888960
Invalid sparse file format at unknown block E725 at 38888961
Invalid sparse file format at unknown block FDA9 at 38888962
Invalid sparse file format at unknown block C8CA at 38888964
Invalid sparse file format at unknown block ACA5 at 38888965
Invalid sparse file format at unknown block D029 at 38888966
Invalid sparse file format at unknown block A7A0 at 38888967
Invalid sparse file format at unknown block D66A at 38888968
Invalid sparse file format at unknown block 113D at 38888970
Invalid sparse file format at unknown block 588E at 38888971
Invalid sparse file format at unknown block 1526 at 38888972
Invalid sparse file format at unknown block CF3C at 38888973
Invalid sparse file format at unknown block 372F at 38888974
Invalid sparse file format at unknown block 3473 at 38888976
Invalid sparse file format at unknown block 2C65 at 38888977
Invalid sparse file format at unknown block 8B56 at 38888978
Invalid sparse file format at unknown block 4D43 at 38888979
Invalid sparse file format at unknown block 1D5A at 38888980
Invalid sparse file format at unknown block 3936 at 38888982
Invalid sparse file format at unknown block 6200 at 38888983
Invalid sparse file format at unknown block 2035 at 38888984
Invalid sparse file format at unknown block 387D at 38888985
Invalid sparse file format at unknown block C2A8 at 38888986
Invalid sparse file format at unknown block 11DE at 38888988
Invalid sparse file format at unknown block 0709 at 38888989
Invalid sparse file format at unknown block 5E17 at 38888990
Invalid sparse file format at unknown block FE5B at 38888991
Invalid sparse file format at unknown block CA34 at 38888992
Invalid sparse file format at unknown block 7158 at 38888994
Invalid sparse file format at unknown block DE8E at 38888995
Invalid sparse file format at unknown block 8017 at 38888996
Invalid sparse file format at unknown block D961 at 38888997
Invalid sparse file format at unknown block B1F0 at 38888998
Invalid sparse file format at unknown block DE4E at 38889000
Invalid sparse file format at unknown block 3871 at 38889001
Invalid sparse file format at unknown block 8E02 at 38889002
Invalid sparse file format at unknown block 80D1 at 38889003
Invalid sparse file format at unknown block 5E8B at 38889004
Invalid sparse file format at unknown block 94FD at 38889006
Invalid sparse file format at unknown block 5736 at 38889007
Invalid sparse file format at unknown block 9788 at 38889008
Invalid sparse file format at unknown block 090E at 38889009
Invalid sparse file format at unknown block E929 at 38889010
Invalid sparse file format at unknown block 76CA at 38889012
Invalid sparse file format at unknown block 1FBF at 38889013
Invalid sparse file format at unknown block 5147 at 38889014
Invalid sparse file format at unknown block E203 at 38889015
Invalid sparse file format at unknown block 1D40 at 38889016
Invalid sparse file format at unknown block 088D at 38889018
Invalid sparse file format at unknown block 78C7 at 38889019
Invalid sparse file format at unknown block 1A58 at 38889020
Invalid sparse file format at unknown block E818 at 38889021
Invalid sparse file format at unknown block EEED at 38889022
Invalid sparse file format at unknown block 1F94 at 38889024
Invalid sparse file format at unknown block 8CA9 at 38889025
Invalid sparse file format at unknown block 4B37 at 38889026
Invalid sparse file format at unknown block 4B4D at 38889027
Invalid sparse file format at unknown block B4CB at 38889028
Invalid sparse file format at unknown block 9F37 at 38889030
Invalid sparse file format at unknown block 739A at 38889031
Invalid sparse file format at unknown block 4362 at 38889032
Invalid sparse file format at unknown block B0B2 at 38889033
Invalid sparse file format at unknown block E248 at 38889034
Invalid sparse file format at unknown block 7F21 at 38889036
Invalid sparse file format at unknown block 610B at 38889037
Invalid sparse file format at unknown block 2A19 at 38889038
Invalid sparse file format at unknown block 1C7F at 38889039
Invalid sparse file format at unknown block 5780 at 38889040
Invalid sparse file format at unknown block F8E4 at 38889042
Invalid sparse file format at unknown block C339 at 38889043
Invalid sparse file format at unknown block E5EA at 38889044
Invalid sparse file format at unknown block 277B at 38889045
Invalid sparse file format at unknown block 0556 at 38889046
Invalid sparse file format at unknown block 5267 at 38889048
Invalid sparse file format at unknown block 69DA at 38889049
Invalid sparse file format at unknown block E74F at 38889050
Invalid sparse file format at unknown block C175 at 38889051
Invalid sparse file format at unknown block CABD at 38889052
Invalid sparse file format at unknown block 1296 at 38889054
Invalid sparse file format at unknown block 921F at 38889055
Invalid sparse file format at unknown block E484 at 38889056
Invalid sparse file format at unknown block DB72 at 38889057
Invalid sparse file format at unknown block 8666 at 38889058
Invalid sparse file format at unknown block D6F7 at 38889060
Invalid sparse file format at unknown block 4ACF at 38889061
Invalid sparse file format at unknown block E004 at 38889062
Invalid sparse file format at unknown block B212 at 38889063
Invalid sparse file format at unknown block C7BD at 38889064
Invalid sparse file format at unknown block AFFD at 38889066
Invalid sparse file format at unknown block 143A at 38889067
Invalid sparse file format at unknown block FD27 at 38889068
Invalid sparse file format at unknown block 94D5 at 38889069
Invalid sparse file format at unknown block 1A86 at 38889070
Invalid sparse file format at unknown block CADC at 38889072
Invalid sparse file format at unknown block 93C4 at 38889073
Invalid sparse file format at unknown block CF3A at 38889074
Invalid sparse file format at unknown block FD08 at 38889075
Invalid sparse file format at unknown block B511 at 38889076
Invalid sparse file format at unknown block D15D at 38889078
Invalid sparse file format at unknown block 87DB at 38889079
Invalid sparse file format at unknown block 8A5B at 38889080
Invalid sparse file format at unknown block 8CA5 at 38889081
Invalid sparse file format at unknown block DE23 at 38889082
Invalid sparse file format at unknown block A96B at 38889084
Invalid sparse file format at unknown block CC56 at 38889085
Invalid sparse file format at unknown block 0759 at 38889086
Invalid sparse file format at unknown block D017 at 38889087
Invalid sparse file format at unknown block 9C5C at 38889088
Invalid sparse file format at unknown block 3F6D at 38889090
Invalid sparse file format at unknown block D656 at 38889091
Invalid sparse file format at unknown block 5861 at 38889092
Invalid sparse file format at unknown block 0595 at 38889093
Invalid sparse file format at unknown block E5F3 at 38889094
Invalid sparse file format at unknown block 8ADA at 38889096
Invalid sparse file format at unknown block ACF9 at 38889097
Invalid sparse file format at unknown block DF38 at 38889098
Invalid sparse file format at unknown block 1D3B at 38889099
Invalid sparse file format at unknown block 7975 at 38889100
Invalid sparse file format at unknown block D826 at 38889102
Invalid sparse file format at unknown block F139 at 38889103
Invalid sparse file format at unknown block 76CB at 38889104
Invalid sparse file format at unknown block 55D0 at 38889105
Invalid sparse file format at unknown block 2134 at 38889106
Invalid sparse file format at unknown block 9EE3 at 38889108
Invalid sparse file format at unknown block 4BFA at 38889109
Invalid sparse file format at unknown block 2AC2 at 38889110
Invalid sparse file format at unknown block E097 at 38889111
Invalid sparse file format at unknown block C0C3 at 38889112
Invalid sparse file format at unknown block 7987 at 38889114
Invalid sparse file format at unknown block DBAC at 38889115
Invalid sparse file format at unknown block 1807 at 38889116
Invalid sparse file format at unknown block A546 at 38889117
Invalid sparse file format at unknown block AA2C at 38889118
Invalid sparse file format at unknown block 25D5 at 38889120
Invalid sparse file format at unknown block 1608 at 38889121
Invalid sparse file format at unknown block 7251 at 38889122
Invalid sparse file format at unknown block 9509 at 38889123
Invalid sparse file format at unknown block AC50 at 38889124
Invalid sparse file format at unknown block 8832 at 38889126
Invalid sparse file format at unknown block 3C16 at 38889127
Invalid sparse file format at unknown block 7D88 at 38889128
Invalid sparse file format at unknown block F0AB at 38889129
Invalid sparse file format at unknown block FA84 at 38889130
Invalid sparse file format at unknown block 34D8 at 38889132
Invalid sparse file format at unknown block 195A at 38889133
Invalid sparse file format at unknown block E37E at 38889134
Invalid sparse file format at unknown block 9E9F at 38889135
Invalid sparse file format at unknown block 66D8 at 38889136
Invalid sparse file format at unknown block 18F0 at 38889138
Invalid sparse file format at unknown block 168C at 38889139
Invalid sparse file format at unknown block C641 at 38889140
Invalid sparse file format at unknown block 4500 at 38889141
Invalid sparse file format at unknown block F06C at 38889142
Invalid sparse file format at unknown block DAE5 at 38889144
Invalid sparse file format at unknown block C90E at 38889145
Invalid sparse file format at unknown block F169 at 38889146
Invalid sparse file format at unknown block 7140 at 38889147
Invalid sparse file format at unknown block 27D4 at 38889148
Invalid sparse file format at unknown block 8608 at 38889150
Invalid sparse file format at unknown block 6234 at 38889151
Invalid sparse file format at unknown block 429A at 38889152
Invalid sparse file format at unknown block 2EBA at 38889153
Invalid sparse file format at unknown block B75C at 38889154
Invalid sparse file format at unknown block 3DF6 at 38889156
Invalid sparse file format at unknown block AEB6 at 38889157
Invalid sparse file format at unknown block 7F96 at 38889158
Invalid sparse file format at unknown block 1169 at 38889159
Invalid sparse file format at unknown block 9222 at 38889160
Invalid sparse file format at unknown block 5F37 at 38889162
Invalid sparse file format at unknown block C198 at 38889163
Invalid sparse file format at unknown block E431 at 38889164
Invalid sparse file format at unknown block 5515 at 38889165
Invalid sparse file format at unknown block 179C at 38889166
Invalid sparse file format at unknown block 98ED at 38889168
Invalid sparse file format at unknown block 1DF8 at 38889169
Invalid sparse file format at unknown block F942 at 38889170
Invalid sparse file format at unknown block B7F0 at 38889171
Invalid sparse file format at unknown block 964A at 38889172
Invalid sparse file format at unknown block 8468 at 38889174
Invalid sparse file format at unknown block D133 at 38889175
Invalid sparse file format at unknown block A58C at 38889176
Invalid sparse file format at unknown block DA61 at 38889177
Failed to read sparse file
UTP: sending Non-success to kernel for command $ simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`.
[ 64.515273] utp_poll: exit with status 65280
U-Boot 2017.03-svn157 (Jul 24 2018 - 17:56:13 +0800)
CPU: Freescale i.MX8MQ rev2.0 1500 MHz (running at 1000 MHz)
CPU: Commercial temperature grade (0C to 95C) at 46C
Reset cause: POR
Model: InnoComm i.MX8MQ Wibo board
I2C: ready
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
MMC: no card present
mmc_init: -123, time 2
*** Warning - MMC init failed, using default environment
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF 6a83ae0
- U-Boot 2017.03-svn157
mmc_init: -123, time 1
Net:
Warning: ethernet@30be0000 using MAC address from ROM
eth0: ethernet@30be0000
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: run mfgtool_args;booti ${loadaddr} ${initrd_addr} ${fdt_addr};
Hit any key to stop autoboot: 0
## Loading init Ramdisk from Legacy Image at 43800000 ...
Image Name: fsl-image-mfgtool-initramfs-imx8
Image Type: AArch64 Linux RAMDisk Image (uncompressed)
Data Size: 8944215 Bytes = 8.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Using Device Tree in place at 0000000043000000, end 000000004300e173
Found /hdmi@32c00000 node
Modify /hdmi@32c00000:status disabled
Found /display-subsystem node
Modify /display-subsystem:status disabled
Found /sound-hdmi node
Modify /sound-hdmi:status disabled
Found /usb@38100000/dwc3 node
Modify /usb@38100000/dwc3:maximum-speed = high-speed
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.78-svn163 (ipc173@ipc173-D830MT) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT8
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030860000 (options '115200,115200')
[ 0.000000] bootconsole [ec_imx6q0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000046000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffff80007ff66000 s48640 r8192 d29184 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515840
[ 0.000000] Kernel command line: console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200,115200 rdinit=/linuxrc g_mass_stord
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14376(87%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1964572K/2096128K available (12540K kernel code, 1370K rwdata, 5184K rodata, 1152K init, 374K bss, 66020K )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008cc0000 ( 12544 KB)
[ 0.000000] .rodata : 0xffff000008cc0000 - 0xffff0000091e0000 ( 5248 KB)
[ 0.000000] .init : 0xffff0000091e0000 - 0xffff000009300000 ( 1152 KB)
[ 0.000000] .data : 0xffff000009300000 - 0xffff000009456a00 ( 1371 KB)
[ 0.000000] .bss : 0xffff000009456a00 - 0xffff0000094b43a0 ( 375 KB)
[ 0.000000] fixed : 0xffff7dfffe7fb000 - 0xffff7dfffec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0002000000 ( 32 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff800080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] i.MX8MQ clock driver init done
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 8.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.000003] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.008234] system counter timer init
[ 0.011723] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
[ 0.019709] clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
[ 0.030355] Console: colour dummy device 80x25
[ 0.034464] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
[ 0.044734] pid_max: default: 32768 minimum: 301
[ 0.049409] Security Framework initialized
[ 0.053491] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.060175] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.068072] sched-energy: CPU device node has no sched-energy-costs
[ 0.073612] Invalid sched_group_energy for CPU0
[ 0.078137] CPU0: update cpu_capacity 1024
[ 0.082239] ASID allocator initialised with 32768 entries
[ 0.120496] Cannot find MU entry in device tree
[ 0.122283] CPU identified as i.MX8MQ, silicon rev 2.0
[ 0.127431] EFI services will not be available.
[ 0.180065] Detected VIPT I-cache on CPU1
[ 0.180093] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.180126] Invalid sched_group_energy for CPU1
[ 0.180129] CPU1: update cpu_capacity 1024
[ 0.180132] CPU1: Booted secondary processor [410fd034]
[ 0.212129] Detected VIPT I-cache on CPU2
[ 0.212152] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.212182] Invalid sched_group_energy for CPU2
[ 0.212185] CPU2: update cpu_capacity 1024
[ 0.212188] CPU2: Booted secondary processor [410fd034]
[ 0.244208] Detected VIPT I-cache on CPU3
[ 0.244229] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.244261] Invalid sched_group_energy for CPU3
[ 0.244266] CPU3: update cpu_capacity 1024
[ 0.244268] CPU3: Booted secondary processor [410fd034]
[ 0.244479] Brought up 4 CPUs
[ 0.318878] SMP: Total of 4 processors activated.
[ 0.323595] CPU features: detected feature: GIC system register CPU interface
[ 0.330747] CPU features: detected feature: 32-bit EL0 Support
[ 0.336921] CPU: All CPU(s) started at EL2
[ 0.340848] alternatives: patching kernel code
[ 0.345299] Invalid sched_group_energy for CPU3
[ 0.349668] Invalid sched_group_energy for Cluster3
[ 0.354548] Invalid sched_group_energy for CPU2
[ 0.359082] Invalid sched_group_energy for Cluster2
[ 0.363965] Invalid sched_group_energy for CPU1
[ 0.368500] Invalid sched_group_energy for Cluster1
[ 0.373385] Invalid sched_group_energy for CPU0
[ 0.377917] Invalid sched_group_energy for Cluster0
[ 0.383368] devtmpfs: initialized
[ 0.393614] DMI not present or invalid.
[ 0.395031] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.404377] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.412684] pinctrl core: initialized pinctrl subsystem
[ 0.417537] NET: Registered protocol family 16
[ 0.440388] cpuidle: using governor menu
[ 0.442185] vdso: 2 pages (1 code @ ffff000008cc7000, 1 data @ ffff000009304000)
[ 0.448886] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.459820] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.464623] Serial: AMBA PL011 UART driver
[ 0.473745] imx8mq-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.531433] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.544202] ACPI: Interpreter disabled.
[ 0.547947] mxs-dma 33000000.dma-apbh: initialized
[ 0.552091] vgaarb: loaded
[ 0.553247] SCSI subsystem initialized
[ 0.557672] usbcore: registered new interface driver usbfs
[ 0.562030] usbcore: registered new interface driver hub
[ 0.567733] usbcore: registered new device driver usb
[ 0.576557] bd71837 0-004b: Device ID=0xA2
[ 0.577796] bd71837 0-004b: gpio_intr = 7
[ 0.581977] bd71837 0-004b: chip_irq=47
[ 0.594061] bd71837-pmic bd71837-pmic: regulator register name 'buck1'
[ 0.622350] bd71837-pmic bd71837-pmic: regulator register name 'buck2'
[ 0.654450] bd71837-pmic bd71837-pmic: regulator register name 'buck3'
[ 0.678527] bd71837-pmic bd71837-pmic: regulator register name 'buck4'
[ 0.702605] bd71837-pmic bd71837-pmic: regulator register name 'buck5'
[ 0.726680] bd71837-pmic bd71837-pmic: regulator register name 'buck6'
[ 0.750756] bd71837-pmic bd71837-pmic: regulator register name 'buck7'
[ 0.774850] bd71837-pmic bd71837-pmic: regulator register name 'buck8'
[ 0.798922] bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
[ 0.818924] bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
[ 0.826922] bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
[ 0.847050] bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
[ 0.867051] bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
[ 0.882846] random: fast init done
[ 0.887154] bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
[ 0.907167] bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
[ 0.967327] i2c i2c-0: IMX I2C adapter registered
[ 0.969181] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.974970] media: Linux media interface: v0.10
[ 0.979125] Linux video capture interface: v2.00
[ 0.983969] pps_core: LinuxPPS API ver. 1 registered
[ 0.988689] BD71837:bd71837_pmic_interrupt() in.
[ 0.993250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.002704] PTP clock support registered
[ 1.006385] BD71837:IRQ_WDOG
[ 1.006657] dmi: Firmware registration failed.
[ 1.006723] Linux cec interface: v0.10
[ 1.007074] MU is ready for cross core communication!
[ 1.010058] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 1.010119] imx rpmsg driver is registered.
[ 1.010247] Advanced Linux Sound Architecture Driver Initialized.
[ 1.010739] Bluetooth: Core ver 2.22
[ 1.010761] NET: Registered protocol family 31
[ 1.010764] Bluetooth: HCI device and connection manager initialized
[ 1.010771] Bluetooth: HCI socket layer initialized
[ 1.010776] Bluetooth: L2CAP socket layer initialized
[ 1.010793] Bluetooth: SCO socket layer initialized
[ 1.013678] clocksource: Switched to clocksource arch_sys_counter
[ 1.013891] VFS: Disk quotas dquot_6.6.0
[ 1.013932] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.084482] BD71837:IRQ_ON_REQ
[ 1.087689] pnp: PnP ACPI: disabled
[ 1.111254] NET: Registered protocol family 2
[ 1.113302] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.120217] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.126996] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.133268] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.139235] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.145856] NET: Registered protocol family 1
[ 1.150938] RPC: Registered named UNIX socket transport module.
[ 1.155989] RPC: Registered udp transport module.
[ 1.160641] RPC: Registered tcp transport module.
[ 1.165403] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.171951] Unpacking initramfs...
[ 1.632636] Freeing initrd memory: 8728K
[ 1.634353] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.641925] kvm [1]: 8-bit VMID
[ 1.644607] kvm [1]: IDMAP page: 40cb2000
[ 1.648642] kvm [1]: HYP VA range: 800000000000:ffffffffffff
[ 1.655170] kvm [1]: Hyp mode initialized successfully
[ 1.659500] kvm [1]: GICv3: no GICV resource entry
[ 1.664291] kvm [1]: disabling GICv2 emulation
[ 1.668801] kvm [1]: GIC system register CPU interface enabled
[ 1.674889] kvm [1]: vgic interrupt IRQ1
[ 1.678465] kvm [1]: virtual timer IRQ4
[ 1.689034] audit: initializing netlink subsys (disabled)
[ 1.691691] audit: type=2000 audit(1.571:1): initialized
[ 1.698230] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 1.715810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.720008] NFS: Registering the id_resolver key type
[ 1.723933] Key type id_resolver registered
[ 1.728407] Key type id_legacy registered
[ 1.732105] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.738846] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 1.745526] 9p: Installing v9fs 9p2000 file system support
[ 1.766704] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.771269] io scheduler noop registered
[ 1.775410] io scheduler cfq registered (default)
[ 1.781724] libphy: mdio_driver_register: phy-bcm-ns2-pci
[ 1.794162] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ 1.799819] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 1.805522] imx-sdma 302c0000.sdma: no iram assigned, using external mem
[ 1.811134] imx-sdma 302c0000.sdma: loaded firmware 4.2
[ 1.821505] Bus freq driver module loaded
[ 1.824784] xenfs: not registering filesystem on non-xen platform
[ 1.838259] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
%�F) driver initializedH)
[ 1.849315] console [ttymxc0] enabled
[ 1.853065] bootconsole [ec_imx6q0] disabled
[ 1.858105] msm_serial: driver initialized
[ 1.864504] [drm] Initialized
[ 1.879950] loop: module loaded
[ 1.884816] hisi_sas: driver version v1.6
[ 1.891487] slram: not enough parameters.
[ 1.898147] libphy: Fixed MDIO Bus: probed
[ 1.902597] tun: Universal TUN/TAP device driver, 1.6
[ 1.907663] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.914225] CAN device driver interface
[ 1.919750] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.925600] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.931688] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.938665] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.944402] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.952247] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.958333] sky2: driver version 1.30
[ 1.971568] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.978183] ehci-pci: EHCI PCI platform driver
[ 1.982742] ehci-platform: EHCI generic platform driver
[ 1.988207] ehci-exynos: EHCI EXYNOS driver
[ 1.992553] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 1.998328] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.004533] ohci-pci: OHCI PCI platform driver
[ 2.009137] ohci-platform: OHCI generic platform driver
[ 2.014521] ohci-exynos: OHCI EXYNOS driver
[ 2.019496] usbcore: registered new interface driver usb-storage
[ 2.025602] usbcore: registered new interface driver usb_ehset_test
[ 2.034073] mousedev: PS/2 mouse device common for all mice
[ 2.039998] input: 30370000.snvs:snvs-powerkey as /devices/platform/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 2.053743] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc0
[ 2.063068] i2c /dev entries driver
[ 2.072239] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 2.078789] Bluetooth: HCI UART driver ver 2.3
[ 2.083310] Bluetooth: HCI UART protocol H4 registered
[ 2.088464] Bluetooth: HCI UART protocol BCSP registered
[ 2.093844] Bluetooth: HCI UART protocol ATH3K registered
[ 2.099257] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.105652] Bluetooth: HCI UART protocol Broadcom registered
[ 2.111326] Bluetooth: HCI UART protocol QCA registered
[ 2.118085] sdhci: Secure Digital Host Controller Interface driver
[ 2.124339] sdhci: Copyright(c) Pierre Ossman
[ 2.129125] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.181707] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 2.194793] sdhci-esdhc-imx 30b50000.usdhc: Got CD GPIO
[ 2.251999] mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
[ 2.262543] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.269061] caam 30900000.caam: ERA source: CCBVID.
[ 2.274109] Can't support > 32 bit dma.
[ 2.281319] caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
[ 2.281319] job rings = 3, qi = 0
[ 2.291568] Can't support > 32 bit dma.
[ 2.299017] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.305372] Failed to run desc RNG4 SH0 status (0xfffffff5)
[ 2.311227] Failed to run desc RNG4 SH1 status (0xfffffff5)
[ 2.316913] caam_jr 30901000.jr0: Entropy delay = 3600
[ 2.351640] mmc0: new HS400 MMC card at address 0001
[ 2.358012] mmcblk0: mmc0:0001 M32508 7.13 GiB
[ 2.364027] mmcblk0boot0: mmc0:0001 M32508 partition 1 4.00 MiB
[ 2.374564] mmcblk0boot1: mmc0:0001 M32508 partition 2 4.00 MiB
[ 2.385035] mmcblk0rpmb: mmc0:0001 M32508 partition 3 4.00 MiB
[ 2.390892] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.399854] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 2.457463] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.463402] Can't support > 32 bit dma.
[ 2.468750] Can't support > 32 bit dma.
[ 2.488643] caam algorithms registered in /proc/crypto
[ 2.498924] caam_jr 30901000.jr0: registering rng-caam
[ 2.504477] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.512925] platform caam_sm: blkkey_ex: 2 keystore units available
[ 2.520482] platform caam_sm: 64-bit clear key:
[ 2.525042] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.530715] platform caam_sm: 64-bit black key:
[ 2.535318] platform caam_sm: [0000] df f4 a7 6a 37 60 e0 c9
[ 2.540992] platform caam_sm: [0008] 61 1c 6a 0d 2d 49 50 3b
[ 2.546719] platform caam_sm: 128-bit clear key:
[ 2.551353] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.557082] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.562753] platform caam_sm: 128-bit black key:
[ 2.567443] platform caam_sm: [0000] 34 93 99 3e 26 32 3d 30
[ 2.573119] platform caam_sm: [0008] e2 d1 c4 ea aa 07 d2 0a
[ 2.578796] platform caam_sm: 192-bit clear key:
[ 2.583429] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.589104] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.594783] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.600454] platform caam_sm: 192-bit black key:
[ 2.605088] platform caam_sm: [0000] 22 ee c7 06 57 68 e4 7f
[ 2.610766] platform caam_sm: [0008] 60 76 bc c4 25 77 04 c8
[ 2.616440] platform caam_sm: [0016] 18 c9 3d 48 b7 fa c4 f9
[ 2.622116] platform caam_sm: [0024] b6 fa 50 81 16 46 04 31
[ 2.627789] platform caam_sm: 256-bit clear key:
[ 2.632421] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.638096] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.643773] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.649448] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.655123] platform caam_sm: 256-bit black key:
[ 2.659755] platform caam_sm: [0000] de 76 a1 99 83 fc 2f 1c
[ 2.665431] platform caam_sm: [0008] 96 35 1e 3d 18 f7 af 59
[ 2.671106] platform caam_sm: [0016] 9f 78 80 d6 f0 72 a5 36
[ 2.676781] platform caam_sm: [0024] 3f c7 15 02 22 fd bd 30
[ 2.682454] platform caam_sm: 64-bit unwritten blob:
[ 2.687439] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.693113] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.698789] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.704464] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.710140] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.715815] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.721490] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.727168] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.732844] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.738519] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.744197] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.749871] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.755550] platform caam_sm: 128-bit unwritten blob:
[ 2.760619] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.766294] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.771969] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.777647] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.783321] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.788995] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.794672] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.800346] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.806023] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.811700] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.817373] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.823049] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.828724] platform caam_sm: 196-bit unwritten blob:
[ 2.833791] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.839466] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.845144] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.850818] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.856493] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.862169] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.867844] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.873520] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.879197] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.884874] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.890548] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.896223] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.901900] platform caam_sm: 256-bit unwritten blob:
[ 2.906966] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.912641] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.918319] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.923993] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.929668] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.935353] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.941026] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.946701] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.952381] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.958055] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.963730] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.969408] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.979358] platform caam_sm: 64-bit black key in blob:
[ 2.984611] platform caam_sm: [0000] fa c1 48 6f 58 ae 81 95
[ 2.990291] platform caam_sm: [0008] e7 0a 60 7c 1f 0d a5 ab
[ 2.995966] platform caam_sm: [0016] 34 f5 30 92 44 e6 b9 48
[ 3.001641] platform caam_sm: [0024] d7 33 0c 56 d1 44 f9 66
[ 3.007317] platform caam_sm: [0032] 39 0a 22 6d 70 f6 b2 bd
[ 3.012997] platform caam_sm: [0040] 33 6c 14 42 7b 92 11 f6
[ 3.018674] platform caam_sm: [0048] 02 54 88 96 8c 62 6c e7
[ 3.024349] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.030027] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.035701] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.041377] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.047055] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.052728] platform caam_sm: 128-bit black key in blob:
[ 3.058058] platform caam_sm: [0000] c1 06 41 9a 16 bc 8a 91
[ 3.063736] platform caam_sm: [0008] 51 2b 35 51 b7 60 74 9a
[ 3.069410] platform caam_sm: [0016] 61 82 90 af 4d 1e 6f 56
[ 3.075086] platform caam_sm: [0024] 1e bc a7 5f ff 7c bc 98
[ 3.080764] platform caam_sm: [0032] b4 07 5f 19 45 5e a6 00
[ 3.086438] platform caam_sm: [0040] 8e 05 06 e2 2e 5d cb eb
[ 3.092114] platform caam_sm: [0048] 58 74 43 bd e5 5e 64 46
[ 3.097791] platform caam_sm: [0056] 27 7e b1 cf 2b 1b aa fc
[ 3.103466] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.109141] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.114816] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.120492] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.126168] platform caam_sm: 192-bit black key in blob:
[ 3.131499] platform caam_sm: [0000] 82 6c 6b 36 82 d6 b6 58
[ 3.137176] platform caam_sm: [0008] 9d 9f 03 6a 2f 02 2b 31
[ 3.142853] platform caam_sm: [0016] b0 01 50 a1 1e 69 78 35
[ 3.148529] platform caam_sm: [0024] ae c6 24 6e 4c 29 53 ef
[ 3.154208] platform caam_sm: [0032] 5d 97 3d c3 ab 2d e3 a0
[ 3.159885] platform caam_sm: [0040] d2 cd 4c db cb 4f 05 3d
[ 3.165561] platform caam_sm: [0048] 13 e3 d1 15 7b 73 e1 98
[ 3.171238] platform caam_sm: [0056] 5c 85 e1 64 a8 ed d8 af
[ 3.176917] platform caam_sm: [0064] cb ad ae 99 5f 22 1f 35
[ 3.182593] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.188269] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.193945] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.199619] platform caam_sm: 256-bit black key in blob:
[ 3.204951] platform caam_sm: [0000] a1 c9 f4 b6 c1 7a 1b c6
[ 3.210625] platform caam_sm: [0008] 57 45 d8 05 b1 dc 8d 62
[ 3.216302] platform caam_sm: [0016] 53 dc df e2 30 a7 61 7c
[ 3.221979] platform caam_sm: [0024] aa de 62 a3 c3 f5 68 64
[ 3.227655] platform caam_sm: [0032] f8 01 f5 00 f3 b1 88 f6
[ 3.233331] platform caam_sm: [0040] 82 48 7f 7a 50 f8 32 99
[ 3.239008] platform caam_sm: [0048] 8b b9 0d a4 3c 71 e2 93
[ 3.244685] platform caam_sm: [0056] 2a d6 13 cf e4 d1 7c 54
[ 3.250364] platform caam_sm: [0064] 15 b9 c7 65 8a 7f ff 0f
[ 3.256038] platform caam_sm: [0072] 90 45 4f 97 6e d3 86 3c
[ 3.261716] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.267396] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.277348] platform caam_sm: restored 64-bit black key:
[ 3.282686] platform caam_sm: [0000] b7 b1 3d e6 8b 7c e2 58
[ 3.288363] platform caam_sm: [0008] ad a0 46 f9 78 2d 00 75
[ 3.294038] platform caam_sm: restored 128-bit black key:
[ 3.299455] platform caam_sm: [0000] 34 93 99 3e 26 32 3d 30
[ 3.305132] platform caam_sm: [0008] e2 d1 c4 ea aa 07 d2 0a
[ 3.310806] platform caam_sm: restored 192-bit black key:
[ 3.316221] platform caam_sm: [0000] 22 ee c7 06 57 68 e4 7f
[ 3.321898] platform caam_sm: [0008] 60 76 bc c4 25 77 04 c8
[ 3.327575] platform caam_sm: [0016] 51 92 a7 ec 29 20 0d ba
[ 3.333251] platform caam_sm: [0024] 62 a8 3d 74 2a b9 93 74
[ 3.338923] platform caam_sm: restored 256-bit black key:
[ 3.344339] platform caam_sm: [0000] de 76 a1 99 83 fc 2f 1c
[ 3.350016] platform caam_sm: [0008] 96 35 1e 3d 18 f7 af 59
[ 3.355693] platform caam_sm: [0016] 9f 78 80 d6 f0 72 a5 36
[ 3.361369] platform caam_sm: [0024] 3f c7 15 02 22 fd bd 30
[ 3.367316] caam-snvs 30370000.caam-snvs: can't get snvs clock
[ 3.373213] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[ 3.382470] usbcore: registered new interface driver usbhid
[ 3.388063] usbhid: USB HID core driver
[ 3.400698] NET: Registered protocol family 26
[ 3.405267] NET: Registered protocol family 17
[ 3.409789] can: controller area network core (rev 20120528 abi 9)
[ 3.416033] NET: Registered protocol family 29
[ 3.420549] can: raw protocol (rev 20120528)
[ 3.424832] can: broadcast manager protocol (rev 20161123 t)
[ 3.430562] can: netlink gateway (rev 20130117) max_hops=1
[ 3.437322] Bluetooth: RFCOMM TTY layer initialized
[ 3.442282] Bluetooth: RFCOMM socket layer initialized
[ 3.447444] Bluetooth: RFCOMM ver 1.11
[ 3.451267] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.456591] Bluetooth: BNEP filters: protocol multicast
[ 3.461889] Bluetooth: BNEP socket layer initialized
[ 3.466867] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.472803] Bluetooth: HIDP socket layer initialized
[ 3.478080] 9pnet: Installing 9P2000 support
[ 3.482549] Key type dns_resolver registered
[ 3.489327] registered taskstats version 1
[ 3.520774] cpu cpu0: registered imx8mq-cpufreq
[ 3.528567] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[ 3.536212] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
[ 3.545579] clk: Not disabling unused clocks
[ 3.549982] VSD_3V3: disabling
[ 3.553073] reg_bt_wake: disabling
[ 3.556542] dhd_module_init in
[ 3.560038] bcmdhd_wlan@0 supply wlreg_on not found, using dummy regulator
[ 3.567253] No Broadcom PCI device enumerated!
[ 3.571904] dhd_wifi_platform_load_pcie: pcie_register_driver failed
[ 3.578407] bcmdhd_wlan: probe of bcmdhd_wlan@0 failed with error -1
[ 3.585045] dhd_module_init out
[ 3.588229] ALSA device list:
[ 3.591301] No soundcards found.
[ 3.596214] Freeing unused kernel memory: 1152K
The available udc:
/sys/class/udc/38100000.dwc3
[ 3.683001] Mass Storage Function, version: 2009/09/11
[ 3.688296] LUN: removable file: (no medium)
MFG tool will use 1st udc:38100000.dwc3
Starting UTP
uuc 0.5 [built Mar 12 2018 12:14:52]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
[ 3.942986] configfs-gadget gadget: high-speed config #1: c
UTP: received command '$ while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done '
UTP: executing "while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done "
UTP: sending Success to kernel for command $ while [ ! -e /dev/mmcblk0 ]; do sleep 1; echo waiting...; done .
[ 4.275383] utp_poll: pass returned.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168"
7168+0 records in
7168+0 records out
7340032 bytes (7.3 MB, 7.0 MiB) copied, 0.77733 s, 9.4 MB/[ 5.072271] utp_poll: pass returned.
s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=1k seek=33 conv=fsync count=7168.
UTP: received command '$ echo 0 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 0 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 0 > /sys/block/mmcblk0boot0/force_ro.
[ 5.338023] utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33'
UTP: executing "dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33"
[ 5.660785] random: crng init done
988+1 records in
988+1 records out
1012676 bytes (1.0 MB, 989 KiB) copied, 0.260027 s, 3.9 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0boot0 bs=1k seek=33.
[ 5.929512] utp_poll: pass returned.
UTP: received command '$ echo 1 > /sys/block/mmcblk0boot0/force_ro'
UTP: executing "echo 1 > /sys/block/mmcblk0boot0/force_ro"
UTP: sending Success to kernel for command $ echo 1 > /sys/block/mmcblk0boot0/force_ro.
[ 6.195701] utp_poll: pass returned.
UTP: received command '$ mmc bootpart enable 1 1 /dev/mmcblk0'
UTP: executing "mmc bootpart enable 1 1 /dev/mmcblk0"
UTP: sending Success to kernel for command $ mmc bootpart enable 1 1 /dev/mmcblk0.
[ 6.461747] utp_poll: pass returned.
UTP: received command '$ ls -l /dev/mmc* '
UTP: executing "ls -l /dev/mmc* "
brw------- 1 root root 179, 0 Jan 1 00:00 /dev/mmcblk0
brw------- 1 root root 179, 32 Jan 1 00:00 /dev/mmcblk0boot0
brw------- 1 root root 179, 64 Jan 1 00:00 /dev/mmcblk0boot1
brw------- 1 root root 179, 1 Jan 1 00:00 /dev/mmcblk0p1
brw------- 1 root root 179, 10 Jan 1 00:00 /dev/mmcblk0p10
brw------- 1 root root 179, 11 Jan 1 00:00 /dev/mmcblk0p11
brw------- 1 root root 179, 12 Jan 1 00:00 /dev/mmcblk0p12
brw------- 1 root root 179, 13 Jan 1 00:00 /dev/mmcblk0p13
brw------- 1 root root 179, 2 Jan 1 00:00 /dev/mmcblk0p2
brw------- 1 root root 179, 3 Jan 1 00:00 /dev/mmcblk0p3
brw------- 1 root root 179, 4 Jan 1 00:00 /dev/mmcblk0p4
brw------- 1 root root 179, 5 Jan 1 00:00 /dev/mmcblk0p5
brw------- 1 root root 179, 6 Jan 1 00:00 /dev/mmcblk0p6
brw------- 1 root root 179, 7 Jan 1 00:00 /dev/mmcblk0p7
brw------- 1 root root 179, 8 Jan 1 00:00 /dev/mmcblk0p8
brw------- 1 root root 179, 9 Jan 1 00:00 /dev/mmcblk0p9
brw------- 1 root root 179, 96 Jan 1 00:00 /dev/mmcblk0rpmb
UTP: sending Success to kernel for command $ ls -l /dev/mmc* .
[ 6.726830] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 conv=fsync"
67+0 records in
67+0 records out
34304 bytes (34 kB, 34 KiB) copied, 0.0161089 s, 2.1 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 conv=fsync.
[ 7.005824] utp_poll: pass returned.
[ 7.287403] utp_poll: pass returned.
UTP: received command '$ hdparm -z /dev/mmcblk0'
UTP: executing "hdparm -z /dev/mmcblk0"
/dev/mmcblk0:
re-reading partition table
[ 7.312745] Alternate GPT is invalid, using primary GPT.
[ 7.318177] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
UTP: sending Success to kernel for command $ hdparm -z /dev/mmcblk0.
[ 7.555093] utp_poll: pass returned.
UTP: received command '$ gdisk -l /dev/mmcblk0 '
UTP: executing "gdisk -l /dev/mmcblk0 "
GPT fdisk (gdisk) version 1.0.1
Caution: invalid backup GPT header, but valid main header; regenerating
backup header from main header.
Warning! Main and backup partition tables differ! Use the 'c' and 'e' options
on the recovery & transformation menu to examine the two tables.
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/mmcblk0: 14942208 sectors, 7.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 3F7BACF6-D26C-4E05-B1FF-2140A571438A
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 14680030
Partitions will be aligned on 2048-sector boundaries
Total free space is 28605 sectors (14.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 16384 81919 32.0 MiB FFFF boot_a
2 81920 147455 32.0 MiB FFFF boot_b
3 147456 2605055 1.2 GiB FFFF system_a
4 2605056 5062655 1.2 GiB FFFF system_b
5 5062656 5070847 4.0 MiB FFFF misc
6 5070848 5074943 2.0 MiB FFFF metadata
7 5074944 5076991 1024.0 KiB FFFF presistdata
8 5079040 5308415 112.0 MiB FFFF vendor_a
9 5308416 5537791 112.0 MiB FFFF vendor_b
10 5537792 14663679 4.4 GiB FFFF userdata
11 14663680 14665727 1024.0 KiB 0700 fbmisc
12 14667776 14669823 1024.0 KiB FFFF vbmeta_a
13 14671872 14673919 1024.0 KiB FFFF vbmeta_b
UTP: sending Success to kernel for command $ gdisk -l /dev/mmcblk0 .
[ 7.835389] utp_poll: pass returned.
UTP: received command '$ echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0'
UTP: executing "echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0"
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Command (? for help):
Recovery/transformation command (? for help): Warning! This will probably do weird things if you've converted an MBR to
GPT form and haven't yet saved the GPT! Proceed? (Y/N):
Recovery/transformation command (? for help): Warning! Secondary header is placed too early on the disk! Do you want to
correct this problem? (Y/N): Have moved second header and partition table to correct location.
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): OK; writing new GUID partition table (GPT) to /dev/mmcblk0.
[ 8.915510] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
The operation has completed successfully.
UTP: sending Success to kernel for command $ echo -e 'r\ne\nY\nw\nY\nY' | gdisk /dev/mmcblk0.
[ 9.144662] utp_poll: pass returned.
UTP: received command '$ echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx'
UTP: executing "echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx"
UTP: sending Success to kernel for command $ echo `gdisk -l /dev/mmcblk0 | grep boot | awk '{print $1}'` > /tmp/partIdx.
[ 10.707664] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`'
UTP: executing "dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`"
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 3.129 s, 10.7 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`.
[ 14.101202] utp_poll: pass returned.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`'
UTP: executing "dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`"
65536+0 records in
65536+0 records out
33554432 bytes (34 MB, 32 MiB) copied, 3.64563 s, 9.2 MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0p`cat /tmp/partIdx | awk '{print $2}'`.
[ 17.961090] utp_poll: pass returned.
UTP: received command '$ mount -o remount,size=1536M rootfs /'
UTP: executing "mount -o remount,size=1536M rootfs /"
UTP: sending Success to kernel for command $ mount -o remount,size=1536M rootfs /.
[ 18.226729] utp_poll: pass returned.
UTP: received command '$ cat /proc/meminfo'
UTP: executing "cat /proc/meminfo"
MemTotal: 2039988 kB
MemFree: 1961180 kB
MemAvailable: 1929704 kB
Buffers: 0 kB
Cached: 56824 kB
SwapCached: 0 kB
Active: 40972 kB
Inactive: 16504 kB
Active(anon): 40972 kB
Inactive(anon): 16392 kB
Active(file): 0 kB
Inactive(file): 112 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 512 kB
Mapped: 2356 kB
Shmem: 56792 kB
Slab: 14692 kB
SReclaimable: 4516 kB
SUnreclaim: 10176 kB
KernelStack: 1504 kB
PageTables: 68 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1019992 kB
Committed_AS: 55580 kB
VmallocTotal: 135290290112 kB
VmallocUsed: 0 kB
VmallocChunk: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
CmaTotal: 65536 kB
CmaFree: 64896 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
UTP: sending Success to kernel for command $ cat /proc/meminfo.
[ 18.492547] utp_poll: pass returned.
UTP: received command '$ echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx'
UTP: executing "echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx"
UTP: sending Success to kernel for command $ echo `gdisk -l /dev/mmcblk0 | grep system | awk '{print $1}'` > /tmp/partIdx.
[ 56.506224] utp_poll: pass returned.
UTP: received command '$ simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`'
UTP: executing "simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`"
Invalid sparse file format at unknown block 294A at 38887461
Invalid sparse file format at unknown block A12E at 38887462
Invalid sparse file format at unknown block B6B4 at 38887464
Invalid sparse file format at unknown block C27A at 38887465
Invalid sparse file format at unknown block 726F at 38887466
Invalid sparse file format at unknown block 6ED4 at 38887467
Invalid sparse file format at unknown block 529D at 38887468
Invalid sparse file format at unknown block C75A at 38887470
Invalid sparse file format at unknown block 333F at 38887471
Invalid sparse file format at unknown block 2F89 at 38887472
Invalid sparse file format at unknown block D6BD at 38887473
Invalid sparse file format at unknown block B192 at 38887474
Invalid sparse file format at unknown block E970 at 38887476
Invalid sparse file format at unknown block 42F9 at 38887477
Invalid sparse file format at unknown block CB2D at 38887478
Invalid sparse file format at unknown block 27BC at 38887479
Invalid sparse file format at unknown block AD35 at 38887480
Invalid sparse file format at unknown block C571 at 38887482
Invalid sparse file format at unknown block 2E91 at 38887483
Invalid sparse file format at unknown block 357C at 38887484
Invalid sparse file format at unknown block 1631 at 38887485
Invalid sparse file format at unknown block 815F at 38887486
Invalid sparse file format at unknown block 4445 at 38887488
Invalid sparse file format at unknown block 72B8 at 38887489
Invalid sparse file format at unknown block 49DE at 38887490
Invalid sparse file format at unknown block 3034 at 38887491
Invalid sparse file format at unknown block 25F6 at 38887492
Invalid sparse file format at unknown block CCB2 at 38887494
Invalid sparse file format at unknown block 323C at 38887495
Invalid sparse file format at unknown block 9CC7 at 38887496
Invalid sparse file format at unknown block D5D5 at 38887497
Invalid sparse file format at unknown block E344 at 38887498
Invalid sparse file format at unknown block 94AB at 38887500
Invalid sparse file format at unknown block 7233 at 38887501
Invalid sparse file format at unknown block 4816 at 38887502
Invalid sparse file format at unknown block 74A9 at 38887503
Invalid sparse file format at unknown block A13B at 38887504
Invalid sparse file format at unknown block FA11 at 38887506
Invalid sparse file format at unknown block 3DAD at 38887507
Invalid sparse file format at unknown block 96F9 at 38887508
Invalid sparse file format at unknown block 2538 at 38887509
Invalid sparse file format at unknown block 605D at 38887510
Invalid sparse file format at unknown block BF05 at 38887512
Invalid sparse file format at unknown block E1E1 at 38887513
Invalid sparse file format at unknown block BA17 at 38887514
Invalid sparse file format at unknown block 878C at 38887515
Invalid sparse file format at unknown block 8B23 at 38887516
Invalid sparse file format at unknown block 7592 at 38887518
Invalid sparse file format at unknown block CC62 at 38887519
Invalid sparse file format at unknown block 6304 at 38887520
Invalid sparse file format at unknown block 542A at 38887521
Invalid sparse file format at unknown block E75B at 38887522
Invalid sparse file format at unknown block 5F24 at 38887524
Invalid sparse file format at unknown block 6F1F at 38887525
Invalid sparse file format at unknown block BE12 at 38887526
Invalid sparse file format at unknown block 881A at 38887527
Invalid sparse file format at unknown block 20D8 at 38887528
Invalid sparse file format at unknown block 740B at 38887530
Invalid sparse file format at unknown block 63B8 at 38887531
Invalid sparse file format at unknown block 46C7 at 38887532
Invalid sparse file format at unknown block 779A at 38887533
Invalid sparse file format at unknown block F2B8 at 38887534
Invalid sparse file format at unknown block C011 at 38887536
Invalid sparse file format at unknown block 9FDB at 38887537
Invalid sparse file format at unknown block 938E at 38887538
Invalid sparse file format at unknown block 9671 at 38887539
Invalid sparse file format at unknown block 181C at 38887540
Invalid sparse file format at unknown block 8A27 at 38887542
Invalid sparse file format at unknown block 1D8B at 38887543
Invalid sparse file format at unknown block D5F8 at 38887544
Invalid sparse file format at unknown block 12F7 at 38887545
Invalid sparse file format at unknown block 20D1 at 38887546
Invalid sparse file format at unknown block 4411 at 38887548
Invalid sparse file format at unknown block 44B5 at 38887549
Invalid sparse file format at unknown block F523 at 38887550
Invalid sparse file format at unknown block 5BA8 at 38887551
Invalid sparse file format at unknown block 791B at 38887552
Invalid sparse file format at unknown block 7748 at 38887554
Invalid sparse file format at unknown block 4AF8 at 38887555
Invalid sparse file format at unknown block A294 at 38887556
Invalid sparse file format at unknown block BCDC at 38887557
Invalid sparse file format at unknown block 1423 at 38887558
Invalid sparse file format at unknown block 7737 at 38887560
Invalid sparse file format at unknown block D159 at 38887561
Invalid sparse file format at unknown block B4EC at 38887562
Invalid sparse file format at unknown block CFCF at 38887563
Invalid sparse file format at unknown block 9CB8 at 38887564
Invalid sparse file format at unknown block 6CC9 at 38887566
Invalid sparse file format at unknown block 68C3 at 38887567
Invalid sparse file format at unknown block 619B at 38887568
Invalid sparse file format at unknown block C68E at 38887569
Invalid sparse file format at unknown block 9124 at 38887570
Invalid sparse file format at unknown block AD9E at 38887572
Invalid sparse file format at unknown block EDDC at 38887573
Invalid sparse file format at unknown block 2281 at 38887574
Invalid sparse file format at unknown block 6625 at 38887575
Invalid sparse file format at unknown block E296 at 38887576
Invalid sparse file format at unknown block 5C21 at 38887578
Invalid sparse file format at unknown block A776 at 38887579
Invalid sparse file format at unknown block E3A8 at 38887580
Invalid sparse file format at unknown block C23C at 38887581
Invalid sparse file format at unknown block 83EC at 38887582
Invalid sparse file format at unknown block B686 at 38887584
Invalid sparse file format at unknown block A2B3 at 38887585
Invalid sparse file format at unknown block AF60 at 38887586
Invalid sparse file format at unknown block 6BE5 at 38887587
Invalid sparse file format at unknown block EA7F at 38887588
Invalid sparse file format at unknown block C189 at 38887590
Invalid sparse file format at unknown block 8DB2 at 38887591
Invalid sparse file format at unknown block 42CC at 38887592
Invalid sparse file format at unknown block AA47 at 38887593
Invalid sparse file format at unknown block 107B at 38887594
Invalid sparse file format at unknown block 0CBA at 38887596
Invalid sparse file format at unknown block 475B at 38887597
Invalid sparse file format at unknown block 7BCB at 38887598
Invalid sparse file format at unknown block 1DDC at 38887599
Invalid sparse file format at unknown block C9B1 at 38887600
Invalid sparse file format at unknown block 4852 at 38887602
Invalid sparse file format at unknown block F732 at 38887603
Invalid sparse file format at unknown block 23BB at 38887604
Invalid sparse file format at unknown block C248 at 38887605
Invalid sparse file format at unknown block DD7E at 38887606
Invalid sparse file format at unknown block 4B76 at 38887608
Invalid sparse file format at unknown block 370B at 38887609
Invalid sparse file format at unknown block 7BC2 at 38887610
Invalid sparse file format at unknown block C637 at 38887611
Invalid sparse file format at unknown block 309A at 38887612
Invalid sparse file format at unknown block 3AA3 at 38887614
Invalid sparse file format at unknown block 4911 at 38887615
Invalid sparse file format at unknown block 865E at 38887616
Invalid sparse file format at unknown block 016D at 38887617
Invalid sparse file format at unknown block 3310 at 38887618
Invalid sparse file format at unknown block 8E09 at 38887620
Invalid sparse file format at unknown block A2C3 at 38887621
Invalid sparse file format at unknown block E420 at 38887622
Invalid sparse file format at unknown block C209 at 38887623
Invalid sparse file format at unknown block 22F7 at 38887624
Invalid sparse file format at unknown block 78B3 at 38887626
Invalid sparse file format at unknown block 725B at 38887627
Invalid sparse file format at unknown block 1F3C at 38887628
Invalid sparse file format at unknown block 81F4 at 38887629
Invalid sparse file format at unknown block F701 at 38887630
Invalid sparse file format at unknown block B5B4 at 38887632
Invalid sparse file format at unknown block EB76 at 38887633
Invalid sparse file format at unknown block B201 at 38887634
Invalid sparse file format at unknown block 1F23 at 38887635
Invalid sparse file format at unknown block 7CFB at 38887636
Invalid sparse file format at unknown block DE27 at 38887638
Invalid sparse file format at unknown block F96E at 38887639
Invalid sparse file format at unknown block 4B3B at 38887640
Invalid sparse file format at unknown block F187 at 38887641
Invalid sparse file format at unknown block DAA9 at 38887642
Invalid sparse file format at unknown block 79A8 at 38887644
Invalid sparse file format at unknown block 8CD9 at 38887645
Invalid sparse file format at unknown block 41F2 at 38887646
Invalid sparse file format at unknown block BA20 at 38887647
Invalid sparse file format at unknown block 193B at 38887648
Invalid sparse file format at unknown block 7C74 at 38887650
Invalid sparse file format at unknown block DD98 at 38887651
Invalid sparse file format at unknown block 3436 at 38887652
Invalid sparse file format at unknown block 14C0 at 38887653
Invalid sparse file format at unknown block D613 at 38887654
Invalid sparse file format at unknown block CF44 at 38887656
Invalid sparse file format at unknown block AB93 at 38887657
Invalid sparse file format at unknown block 4DCD at 38887658
Invalid sparse file format at unknown block 7D5B at 38887659
Invalid sparse file format at unknown block 38CF at 38887660
Invalid sparse file format at unknown block 4DD8 at 38887662
Invalid sparse file format at unknown block 29EE at 38887663
Invalid sparse file format at unknown block 9E06 at 38887664
Invalid sparse file format at unknown block 0EFF at 38887665
Invalid sparse file format at unknown block 649D at 38887666
Invalid sparse file format at unknown block D6DD at 38887668
Invalid sparse file format at unknown block F314 at 38887669
Invalid sparse file format at unknown block 1AC2 at 38887670
Invalid sparse file format at unknown block 1542 at 38887671
Invalid sparse file format at unknown block BC52 at 38887672
Invalid sparse file format at unknown block 716D at 38887674
Invalid sparse file format at unknown block F665 at 38887675
Invalid sparse file format at unknown block A64B at 38887676
Invalid sparse file format at unknown block CD71 at 38887677
Invalid sparse file format at unknown block AE00 at 38887678
Invalid sparse file format at unknown block 0748 at 38887680
Invalid sparse file format at unknown block A884 at 38887681
Invalid sparse file format at unknown block E94E at 38887682
Invalid sparse file format at unknown block 5C42 at 38887683
Invalid sparse file format at unknown block 1988 at 38887684
Invalid sparse file format at unknown block 9BB8 at 38887686
Invalid sparse file format at unknown block 75D0 at 38887687
Invalid sparse file format at unknown block 14CE at 38887688
Invalid sparse file format at unknown block 06BA at 38887689
Invalid sparse file format at unknown block 2F68 at 38887690
Invalid sparse file format at unknown block 9132 at 38887692
Invalid sparse file format at unknown block 7A9D at 38887693
Invalid sparse file format at unknown block A15E at 38887694
Invalid sparse file format at unknown block 7C2A at 38887695
Invalid sparse file format at unknown block EE5A at 38887696
Invalid sparse file format at unknown block 6D9B at 38887698
Invalid sparse file format at unknown block 89F5 at 38887699
Invalid sparse file format at unknown block 01C8 at 38887700
Invalid sparse file format at unknown block D5D5 at 38887701
Invalid sparse file format at unknown block 143E at 38887702
Invalid sparse file format at unknown block CDF3 at 38887704
Invalid sparse file format at unknown block 1F60 at 38887705
Invalid sparse file format at unknown block 4A51 at 38887706
Invalid sparse file format at unknown block E125 at 38887707
Invalid sparse file format at unknown block 5CF1 at 38887708
Invalid sparse file format at unknown block BC8C at 38887710
Invalid sparse file format at unknown block 42B1 at 38887711
Invalid sparse file format at unknown block 03B8 at 38887712
Invalid sparse file format at unknown block AE82 at 38887713
Invalid sparse file format at unknown block 0F77 at 38887714
Invalid sparse file format at unknown block B7D6 at 38887716
Invalid sparse file format at unknown block 6146 at 38887717
Invalid sparse file format at unknown block 0E14 at 38887718
Invalid sparse file format at unknown block DE77 at 38887719
Invalid sparse file format at unknown block 1475 at 38887720
Invalid sparse file format at unknown block FF76 at 38887722
Invalid sparse file format at unknown block 4DA1 at 38887723
Invalid sparse file format at unknown block 78EC at 38887724
Invalid sparse file format at unknown block A4BE at 38887725
Invalid sparse file format at unknown block 387B at 38887726
Invalid sparse file format at unknown block 6E23 at 38887728
Invalid sparse file format at unknown block F25F at 38887729
Invalid sparse file format at unknown block F3B6 at 38887730
Invalid sparse file format at unknown block AECB at 38887731
Invalid sparse file format at unknown block 362D at 38887732
Invalid sparse file format at unknown block 46BD at 38887734
Invalid sparse file format at unknown block 969C at 38887735
Invalid sparse file format at unknown block F15C at 38887736
Invalid sparse file format at unknown block 66B5 at 38887737
Invalid sparse file format at unknown block 332A at 38887738
Invalid sparse file format at unknown block C37F at 38887740
Invalid sparse file format at unknown block B3D3 at 38887741
Invalid sparse file format at unknown block 0B2B at 38887742
Invalid sparse file format at unknown block 46BF at 38887743
Invalid sparse file format at unknown block 21DB at 38887744
Invalid sparse file format at unknown block DF80 at 38887746
Invalid sparse file format at unknown block A468 at 38887747
Invalid sparse file format at unknown block E0AE at 38887748
Invalid sparse file format at unknown block AB41 at 38887749
Invalid sparse file format at unknown block A28D at 38887750
Invalid sparse file format at unknown block 68DE at 38887752
Invalid sparse file format at unknown block BBA3 at 38887753
Invalid sparse file format at unknown block AD8A at 38887754
Invalid sparse file format at unknown block C4BD at 38887755
Invalid sparse file format at unknown block 22BA at 38887756
Invalid sparse file format at unknown block 7310 at 38887758
Invalid sparse file format at unknown block FEF7 at 38887759
Invalid sparse file format at unknown block EAFC at 38887760
Invalid sparse file format at unknown block A5DA at 38887761
Invalid sparse file format at unknown block E602 at 38887762
Invalid sparse file format at unknown block C3A4 at 38887764
Invalid sparse file format at unknown block FD96 at 38887765
Invalid sparse file format at unknown block E9D0 at 38887766
Invalid sparse file format at unknown block 2C0A at 38887767
Invalid sparse file format at unknown block B3E5 at 38887768
Invalid sparse file format at unknown block A76A at 38887770
Invalid sparse file format at unknown block 820A at 38887771
Invalid sparse file format at unknown block 00D4 at 38887772
Invalid sparse file format at unknown block AB55 at 38887773
Invalid sparse file format at unknown block E68C at 38887774
Invalid sparse file format at unknown block EAF5 at 38887776
Invalid sparse file format at unknown block 59E9 at 38887777
Invalid sparse file format at unknown block A2A7 at 38887778
Invalid sparse file format at unknown block 87EC at 38887779
Invalid sparse file format at unknown block 7E8E at 38887780
Invalid sparse file format at unknown block 553E at 38887782
Invalid sparse file format at unknown block F82D at 38887783
Invalid sparse file format at unknown block 3542 at 38887784
Invalid sparse file format at unknown block 4082 at 38887785
Invalid sparse file format at unknown block 5218 at 38887786
Invalid sparse file format at unknown block 97DB at 38887788
Invalid sparse file format at unknown block 549E at 38887789
Invalid sparse file format at unknown block 1B9B at 38887790
Invalid sparse file format at unknown block D3FE at 38887791
Invalid sparse file format at unknown block 67B9 at 38887792
Invalid sparse file format at unknown block 0834 at 38887794
Invalid sparse file format at unknown block 2553 at 38887795
Invalid sparse file format at unknown block B161 at 38887796
Invalid sparse file format at unknown block A727 at 38887797
Invalid sparse file format at unknown block E23A at 38887798
Invalid sparse file format at unknown block 6C9E at 38887800
Invalid sparse file format at unknown block E846 at 38887801
Invalid sparse file format at unknown block 4F42 at 38887802
Invalid sparse file format at unknown block 7CFC at 38887803
Invalid sparse file format at unknown block 824C at 38887804
Invalid sparse file format at unknown block 1C58 at 38887806
Invalid sparse file format at unknown block D920 at 38887807
Invalid sparse file format at unknown block 0F8B at 38887808
Invalid sparse file format at unknown block 6D5E at 38887809
Invalid sparse file format at unknown block 16C1 at 38887810
Invalid sparse file format at unknown block DA92 at 38887812
Invalid sparse file format at unknown block 418B at 38887813
Invalid sparse file format at unknown block 470D at 38887814
Invalid sparse file format at unknown block A2AC at 38887815
Invalid sparse file format at unknown block 8A7A at 38887816
Invalid sparse file format at unknown block 62E6 at 38887818
Invalid sparse file format at unknown block 5880 at 38887819
Invalid sparse file format at unknown block 4A97 at 38887820
Invalid sparse file format at unknown block 1C87 at 38887821
Invalid sparse file format at unknown block 42EC at 38887822
Invalid sparse file format at unknown block F730 at 38887824
Invalid sparse file format at unknown block 69FC at 38887825
Invalid sparse file format at unknown block EC4E at 38887826
Invalid sparse file format at unknown block 5F5F at 38887827
Invalid sparse file format at unknown block 55E3 at 38887828
Invalid sparse file format at unknown block DF7F at 38887830
Invalid sparse file format at unknown block 6319 at 38887831
Invalid sparse file format at unknown block D440 at 38887832
Invalid sparse file format at unknown block 6116 at 38887833
Invalid sparse file format at unknown block 96FE at 38887834
Invalid sparse file format at unknown block FE19 at 38887836
Invalid sparse file format at unknown block 40B4 at 38887837
Invalid sparse file format at unknown block 910C at 38887838
Invalid sparse file format at unknown block 6D80 at 38887839
Invalid sparse file format at unknown block 7658 at 38887840
Invalid sparse file format at unknown block 2353 at 38887842
Invalid sparse file format at unknown block 9D2A at 38887843
Invalid sparse file format at unknown block 4600 at 38887844
Invalid sparse file format at unknown block 81DE at 38887845
Invalid sparse file format at unknown block E842 at 38887846
Invalid sparse file format at unknown block A2BC at 38887848
Invalid sparse file format at unknown block E984 at 38887849
Invalid sparse file format at unknown block 36A9 at 38887850
Invalid sparse file format at unknown block 93AD at 38887851
Invalid sparse file format at unknown block F11F at 38887852
Invalid sparse file format at unknown block B495 at 38887854
Invalid sparse file format at unknown block 2F51 at 38887855
Invalid sparse file format at unknown block 57BC at 38887856
Invalid sparse file format at unknown block CBB8 at 38887857
Invalid sparse file format at unknown block CDF0 at 38887858
Invalid sparse file format at unknown block 3284 at 38887860
Invalid sparse file format at unknown block 2C37 at 38887861
Invalid sparse file format at unknown block 3A89 at 38887862
Invalid sparse file format at unknown block C80F at 38887863
Invalid sparse file format at unknown block 0D77 at 38887864
Invalid sparse file format at unknown block E2E0 at 38887866
Invalid sparse file format at unknown block 203E at 38887867
Invalid sparse file format at unknown block 2F35 at 38887868
Invalid sparse file format at unknown block 0476 at 38887869
Invalid sparse file format at unknown block 404F at 38887870
Invalid sparse file format at unknown block 7110 at 38887872
Invalid sparse file format at unknown block 3A19 at 38887873
Invalid sparse file format at unknown block 1C2B at 38887874
Invalid sparse file format at unknown block 0D45 at 38887875
Invalid sparse file format at unknown block 524E at 38887876
Invalid sparse file format at unknown block AB29 at 38887878
Invalid sparse file format at unknown block E884 at 38887879
Invalid sparse file format at unknown block DBB2 at 38887880
Invalid sparse file format at unknown block 207C at 38887881
Invalid sparse file format at unknown block 5C1E at 38887882
Invalid sparse file format at unknown block 4DBF at 38887884
Invalid sparse file format at unknown block 43BA at 38887885
Invalid sparse file format at unknown block 5166 at 38887886
Invalid sparse file format at unknown block 33D8 at 38887887
Invalid sparse file format at unknown block C3E4 at 38887888
Invalid sparse file format at unknown block 4735 at 38887890
Invalid sparse file format at unknown block 172D at 38887891
Invalid sparse file format at unknown block 8551 at 38887892
Invalid sparse file format at unknown block 6F91 at 38887893
Invalid sparse file format at unknown block 5BB4 at 38887894
Invalid sparse file format at unknown block 5F0C at 38887896
Invalid sparse file format at unknown block 4A34 at 38887897
Invalid sparse file format at unknown block 9403 at 38887898
Invalid sparse file format at unknown block F8B9 at 38887899
Invalid sparse file format at unknown block D82D at 38887900
Invalid sparse file format at unknown block F97D at 38887902
Invalid sparse file format at unknown block EDDE at 38887903
Invalid sparse file format at unknown block EAF4 at 38887904
Invalid sparse file format at unknown block C149 at 38887905
Invalid sparse file format at unknown block 6782 at 38887906
Invalid sparse file format at unknown block AE5E at 38887908
Invalid sparse file format at unknown block BB7D at 38887909
Invalid sparse file format at unknown block 7E28 at 38887910
Invalid sparse file format at unknown block 1A9D at 38887911
Invalid sparse file format at unknown block 77C3 at 38887912
Invalid sparse file format at unknown block 0D56 at 38887914
Invalid sparse file format at unknown block E6CE at 38887915
Invalid sparse file format at unknown block C1FC at 38887916
Invalid sparse file format at unknown block D7E8 at 38887917
Invalid sparse file format at unknown block 12B0 at 38887918
Invalid sparse file format at unknown block B333 at 38887920
Invalid sparse file format at unknown block CD9C at 38887921
Invalid sparse file format at unknown block 9CD6 at 38887922
Invalid sparse file format at unknown block 0BDD at 38887923
Invalid sparse file format at unknown block F97A at 38887924
Invalid sparse file format at unknown block CD74 at 38887926
Invalid sparse file format at unknown block 335B at 38887927
Invalid sparse file format at unknown block 337F at 38887928
Invalid sparse file format at unknown block B083 at 38887929
Invalid sparse file format at unknown block 4D5D at 38887930
Invalid sparse file format at unknown block 04B3 at 38887932
Invalid sparse file format at unknown block 40E4 at 38887933
Invalid sparse file format at unknown block CDC6 at 38887934
Invalid sparse file format at unknown block BFEC at 38887935
Invalid sparse file format at unknown block 1897 at 38887936
Invalid sparse file format at unknown block D44C at 38887938
Invalid sparse file format at unknown block 0777 at 38887939
Invalid sparse file format at unknown block 28B9 at 38887940
Invalid sparse file format at unknown block 918B at 38887941
Invalid sparse file format at unknown block 93E1 at 38887942
Invalid sparse file format at unknown block FE22 at 38887944
Invalid sparse file format at unknown block 3301 at 38887945
Invalid sparse file format at unknown block B494 at 38887946
Invalid sparse file format at unknown block FFC5 at 38887947
Invalid sparse file format at unknown block 45AB at 38887948
Invalid sparse file format at unknown block DE72 at 38887950
Invalid sparse file format at unknown block 1C56 at 38887951
Invalid sparse file format at unknown block 341B at 38887952
Invalid sparse file format at unknown block 6553 at 38887953
Invalid sparse file format at unknown block BDA7 at 38887954
Invalid sparse file format at unknown block B30B at 38887956
Invalid sparse file format at unknown block DE53 at 38887957
Invalid sparse file format at unknown block 9645 at 38887958
Invalid sparse file format at unknown block 8474 at 38887959
Invalid sparse file format at unknown block 89E5 at 38887960
Invalid sparse file format at unknown block 74A3 at 38887962
Invalid sparse file format at unknown block 1C13 at 38887963
Invalid sparse file format at unknown block 5766 at 38887964
Invalid sparse file format at unknown block 518A at 38887965
Invalid sparse file format at unknown block 4F5E at 38887966
Invalid sparse file format at unknown block 949A at 38887968
Invalid sparse file format at unknown block 2B4A at 38887969
Invalid sparse file format at unknown block DF52 at 38887970
Invalid sparse file format at unknown block 244F at 38887971
Invalid sparse file format at unknown block 9627 at 38887972
Invalid sparse file format at unknown block A989 at 38887974
Invalid sparse file format at unknown block 748E at 38887975
Invalid sparse file format at unknown block 9033 at 38887976
Invalid sparse file format at unknown block 375C at 38887977
Invalid sparse file format at unknown block 48E9 at 38887978
Invalid sparse file format at unknown block FD9E at 38887980
Invalid sparse file format at unknown block CA38 at 38887981
Invalid sparse file format at unknown block DB80 at 38887982
Invalid sparse file format at unknown block B289 at 38887983
Invalid sparse file format at unknown block 822B at 38887984
Invalid sparse file format at unknown block 4D11 at 38887986
Invalid sparse file format at unknown block FB7E at 38887987
Invalid sparse file format at unknown block 450E at 38887988
Invalid sparse file format at unknown block 411C at 38887989
Invalid sparse file format at unknown block C642 at 38887990
Invalid sparse file format at unknown block 4A98 at 38887992
Invalid sparse file format at unknown block C137 at 38887993
Invalid sparse file format at unknown block F2F4 at 38887994
Invalid sparse file format at unknown block 7414 at 38887995
Invalid sparse file format at unknown block E7CF at 38887996
Invalid sparse file format at unknown block BCE5 at 38887998
Invalid sparse file format at unknown block 48B7 at 38887999
Invalid sparse file format at unknown block 1C4A at 38888000
Invalid sparse file format at unknown block 006E at 38888001
Invalid sparse file format at unknown block 2209 at 38888002
Invalid sparse file format at unknown block 9CFA at 38888004
Invalid sparse file format at unknown block C9E0 at 38888005
Invalid sparse file format at unknown block C4E2 at 38888006
Invalid sparse file format at unknown block 55C9 at 38888007
Invalid sparse file format at unknown block F704 at 38888008
Invalid sparse file format at unknown block 4363 at 38888010
Invalid sparse file format at unknown block 5C27 at 38888011
Invalid sparse file format at unknown block 616C at 38888012
Invalid sparse file format at unknown block 0F25 at 38888013
Invalid sparse file format at unknown block 5D98 at 38888014
Invalid sparse file format at unknown block 466E at 38888016
Invalid sparse file format at unknown block DB26 at 38888017
Invalid sparse file format at unknown block 20AB at 38888018
Invalid sparse file format at unknown block 3FEC at 38888019
Invalid sparse file format at unknown block 158D at 38888020
Invalid sparse file format at unknown block A317 at 38888022
Invalid sparse file format at unknown block 8F80 at 38888023
Invalid sparse file format at unknown block 77DA at 38888024
Invalid sparse file format at unknown block 0566 at 38888025
Invalid sparse file format at unknown block 7E7A at 38888026
Invalid sparse file format at unknown block BBD8 at 38888028
Invalid sparse file format at unknown block E8E4 at 38888029
Invalid sparse file format at unknown block 7100 at 38888030
Invalid sparse file format at unknown block EB30 at 38888031
Invalid sparse file format at unknown block 7727 at 38888032
Invalid sparse file format at unknown block 97A4 at 38888034
Invalid sparse file format at unknown block 588E at 38888035
Invalid sparse file format at unknown block E770 at 38888036
Invalid sparse file format at unknown block B2AB at 38888037
Invalid sparse file format at unknown block A656 at 38888038
Invalid sparse file format at unknown block 6C3B at 38888040
Invalid sparse file format at unknown block D207 at 38888041
Invalid sparse file format at unknown block B9B1 at 38888042
Invalid sparse file format at unknown block CBF2 at 38888043
Invalid sparse file format at unknown block C8C5 at 38888044
Invalid sparse file format at unknown block 98F7 at 38888046
Invalid sparse file format at unknown block E8A7 at 38888047
Invalid sparse file format at unknown block C63B at 38888048
Invalid sparse file format at unknown block F71C at 38888049
Invalid sparse file format at unknown block B14E at 38888050
Invalid sparse file format at unknown block 8278 at 38888052
Invalid sparse file format at unknown block EDD0 at 38888053
Invalid sparse file format at unknown block F35F at 38888054
Invalid sparse file format at unknown block 24DD at 38888055
Invalid sparse file format at unknown block E8A3 at 38888056
Invalid sparse file format at unknown block 7A07 at 38888058
Invalid sparse file format at unknown block 76BB at 38888059
Invalid sparse file format at unknown block 11B8 at 38888060
Invalid sparse file format at unknown block 00A9 at 38888061
Invalid sparse file format at unknown block 6089 at 38888062
Invalid sparse file format at unknown block 3537 at 38888064
Invalid sparse file format at unknown block 8227 at 38888065
Invalid sparse file format at unknown block 5084 at 38888066
Invalid sparse file format at unknown block 1A3A at 38888067
Invalid sparse file format at unknown block 1A64 at 38888068
Invalid sparse file format at unknown block 966B at 38888070
Invalid sparse file format at unknown block 02E4 at 38888071
Invalid sparse file format at unknown block 7E1C at 38888072
Invalid sparse file format at unknown block 2A03 at 38888073
Invalid sparse file format at unknown block D0EC at 38888074
Invalid sparse file format at unknown block 0360 at 38888076
Invalid sparse file format at unknown block 1B6E at 38888077
Invalid sparse file format at unknown block C5ED at 38888078
Invalid sparse file format at unknown block C723 at 38888079
Invalid sparse file format at unknown block EA21 at 38888080
Invalid sparse file format at unknown block 5806 at 38888082
Invalid sparse file format at unknown block 3FE9 at 38888083
Invalid sparse file format at unknown block 16DD at 38888084
Invalid sparse file format at unknown block 8806 at 38888085
Invalid sparse file format at unknown block 898B at 38888086
Invalid sparse file format at unknown block A65D at 38888088
Invalid sparse file format at unknown block BF71 at 38888089
Invalid sparse file format at unknown block 924B at 38888090
Invalid sparse file format at unknown block FEDD at 38888091
Invalid sparse file format at unknown block 7289 at 38888092
Invalid sparse file format at unknown block 00DC at 38888094
Invalid sparse file format at unknown block A443 at 38888095
Invalid sparse file format at unknown block 201E at 38888096
Invalid sparse file format at unknown block 6979 at 38888097
Invalid sparse file format at unknown block 7F7E at 38888098
Invalid sparse file format at unknown block DB73 at 38888100
Invalid sparse file format at unknown block 34DA at 38888101
Invalid sparse file format at unknown block F2E9 at 38888102
Invalid sparse file format at unknown block 7A6C at 38888103
Invalid sparse file format at unknown block E405 at 38888104
Invalid sparse file format at unknown block 1BE0 at 38888106
Invalid sparse file format at unknown block EF73 at 38888107
Invalid sparse file format at unknown block 3F50 at 38888108
Invalid sparse file format at unknown block EF6B at 38888109
Invalid sparse file format at unknown block 68C2 at 38888110
Invalid sparse file format at unknown block 19D0 at 38888112
Invalid sparse file format at unknown block 77C3 at 38888113
Invalid sparse file format at unknown block E120 at 38888114
Invalid sparse file format at unknown block D7A9 at 38888115
Invalid sparse file format at unknown block C0D0 at 38888116
Invalid sparse file format at unknown block 817B at 38888118
Invalid sparse file format at unknown block CEE6 at 38888119
Invalid sparse file format at unknown block 5386 at 38888120
Invalid sparse file format at unknown block 5FBF at 38888121
Invalid sparse file format at unknown block 12E8 at 38888122
Invalid sparse file format at unknown block 1354 at 38888124
Invalid sparse file format at unknown block A300 at 38888125
Invalid sparse file format at unknown block C110 at 38888126
Invalid sparse file format at unknown block DEC1 at 38888127
Invalid sparse file format at unknown block AC36 at 38888128
Invalid sparse file format at unknown block 0450 at 38888130
Invalid sparse file format at unknown block D8A5 at 38888131
Invalid sparse file format at unknown block CDFC at 38888132
Invalid sparse file format at unknown block 6FFF at 38888133
Invalid sparse file format at unknown block 29E6 at 38888134
Invalid sparse file format at unknown block A428 at 38888136
Invalid sparse file format at unknown block D8B1 at 38888137
Invalid sparse file format at unknown block B87A at 38888138
Invalid sparse file format at unknown block 04BC at 38888139
Invalid sparse file format at unknown block 60DB at 38888140
Invalid sparse file format at unknown block 0FDD at 38888142
Invalid sparse file format at unknown block F18C at 38888143
Invalid sparse file format at unknown block 3E1E at 38888144
Invalid sparse file format at unknown block 817F at 38888145
Invalid sparse file format at unknown block F875 at 38888146
Invalid sparse file format at unknown block 76E9 at 38888148
Invalid sparse file format at unknown block 43D7 at 38888149
Invalid sparse file format at unknown block B8A3 at 38888150
Invalid sparse file format at unknown block 705A at 38888151
Invalid sparse file format at unknown block 042E at 38888152
Invalid sparse file format at unknown block E05D at 38888154
Invalid sparse file format at unknown block 4FF6 at 38888155
Invalid sparse file format at unknown block 4DB5 at 38888156
Invalid sparse file format at unknown block 4281 at 38888157
Invalid sparse file format at unknown block 8389 at 38888158
Invalid sparse file format at unknown block E673 at 38888160
Invalid sparse file format at unknown block 7D9D at 38888161
Invalid sparse file format at unknown block 70C0 at 38888162
Invalid sparse file format at unknown block 4418 at 38888163
Invalid sparse file format at unknown block EBE0 at 38888164
Invalid sparse file format at unknown block 1D3D at 38888166
Invalid sparse file format at unknown block F5C4 at 38888167
Invalid sparse file format at unknown block F33C at 38888168
Invalid sparse file format at unknown block 3E4F at 38888169
Invalid sparse file format at unknown block 79B2 at 38888170
Invalid sparse file format at unknown block 3F57 at 38888172
Invalid sparse file format at unknown block DDD9 at 38888173
Invalid sparse file format at unknown block D730 at 38888174
Invalid sparse file format at unknown block 2879 at 38888175
Invalid sparse file format at unknown block F7A0 at 38888176
Invalid sparse file format at unknown block 5E21 at 38888178
Invalid sparse file format at unknown block A41F at 38888179
Invalid sparse file format at unknown block 6AB5 at 38888180
Invalid sparse file format at unknown block E8DB at 38888181
Invalid sparse file format at unknown block A51E at 38888182
Invalid sparse file format at unknown block 19AA at 38888184
Invalid sparse file format at unknown block 2BCF at 38888185
Invalid sparse file format at unknown block 8561 at 38888186
Invalid sparse file format at unknown block B932 at 38888187
Invalid sparse file format at unknown block 5C28 at 38888188
Invalid sparse file format at unknown block 41F4 at 38888190
Invalid sparse file format at unknown block 6942 at 38888191
Invalid sparse file format at unknown block 1F05 at 38888192
Invalid sparse file format at unknown block 7E1B at 38888193
Invalid sparse file format at unknown block 423C at 38888194
Invalid sparse file format at unknown block C66A at 38888196
Invalid sparse file format at unknown block C27D at 38888197
Invalid sparse file format at unknown block 0835 at 38888198
Invalid sparse file format at unknown block AFF5 at 38888199
Invalid sparse file format at unknown block C93C at 38888200
Invalid sparse file format at unknown block A4A1 at 38888202
Invalid sparse file format at unknown block 43FC at 38888203
Invalid sparse file format at unknown block 1CB4 at 38888204
Invalid sparse file format at unknown block B4A4 at 38888205
Invalid sparse file format at unknown block 1174 at 38888206
Invalid sparse file format at unknown block FF0C at 38888208
Invalid sparse file format at unknown block FC2F at 38888209
Invalid sparse file format at unknown block F151 at 38888210
Invalid sparse file format at unknown block 8403 at 38888211
Invalid sparse file format at unknown block 3BE1 at 38888212
Invalid sparse file format at unknown block CDDC at 38888214
Invalid sparse file format at unknown block BE7D at 38888215
Invalid sparse file format at unknown block 5EAB at 38888216
Invalid sparse file format at unknown block AF8C at 38888217
Invalid sparse file format at unknown block 454E at 38888218
Invalid sparse file format at unknown block C15B at 38888220
Invalid sparse file format at unknown block E4B3 at 38888221
Invalid sparse file format at unknown block C025 at 38888222
Invalid sparse file format at unknown block 0527 at 38888223
Invalid sparse file format at unknown block 35B5 at 38888224
Invalid sparse file format at unknown block 3063 at 38888226
Invalid sparse file format at unknown block 70D7 at 38888227
Invalid sparse file format at unknown block 70DE at 38888228
Invalid sparse file format at unknown block 864F at 38888229
Invalid sparse file format at unknown block 09B7 at 38888230
Invalid sparse file format at unknown block B755 at 38888232
Invalid sparse file format at unknown block C484 at 38888233
Invalid sparse file format at unknown block 6AEE at 38888234
Invalid sparse file format at unknown block DCE6 at 38888235
Invalid sparse file format at unknown block F2E5 at 38888236
Invalid sparse file format at unknown block 18EC at 38888238
Invalid sparse file format at unknown block 33B5 at 38888239
Invalid sparse file format at unknown block 172B at 38888240
Invalid sparse file format at unknown block 0BB6 at 38888241
Invalid sparse file format at unknown block 0BB0 at 38888242
Invalid sparse file format at unknown block 3E7E at 38888244
Invalid sparse file format at unknown block 5510 at 38888245
Invalid sparse file format at unknown block CCD2 at 38888246
Invalid sparse file format at unknown block 442A at 38888247
Invalid sparse file format at unknown block DF08 at 38888248
Invalid sparse file format at unknown block BB97 at 38888250
Invalid sparse file format at unknown block C3FA at 38888251
Invalid sparse file format at unknown block F1B4 at 38888252
Invalid sparse file format at unknown block 2B2D at 38888253
Invalid sparse file format at unknown block 4F22 at 38888254
Invalid sparse file format at unknown block F64C at 38888256
Invalid sparse file format at unknown block 1E3A at 38888257
Invalid sparse file format at unknown block 0998 at 38888258
Invalid sparse file format at unknown block 96B6 at 38888259
Invalid sparse file format at unknown block 9F6C at 38888260
Invalid sparse file format at unknown block 578C at 38888262
Invalid sparse file format at unknown block 98DF at 38888263
Invalid sparse file format at unknown block 773B at 38888264
Invalid sparse file format at unknown block EA3B at 38888265
Invalid sparse file format at unknown block 275E at 38888266
Invalid sparse file format at unknown block 2D7E at 38888268
Invalid sparse file format at unknown block B1C8 at 38888269
Invalid sparse file format at unknown block A96F at 38888270
Invalid sparse file format at unknown block 8B7F at 38888271
Invalid sparse file format at unknown block 0490 at 38888272
Invalid sparse file format at unknown block 065F at 38888274
Invalid sparse file format at unknown block 3576 at 38888275
Invalid sparse file format at unknown block 6405 at 38888276
Invalid sparse file format at unknown block 8E66 at 38888277
Invalid sparse file format at unknown block 8AAC at 38888278
Invalid sparse file format at unknown block FAA1 at 38888280
Invalid sparse file format at unknown block 13E8 at 38888281
Invalid sparse file format at unknown block 867D at 38888282
Invalid sparse file format at unknown block B5B0 at 38888283
Invalid sparse file format at unknown block 2555 at 38888284
Invalid sparse file format at unknown block 010D at 38888286
Invalid sparse file format at unknown block C5E4 at 38888287
Invalid sparse file format at unknown block 0537 at 38888288
Invalid sparse file format at unknown block C959 at 38888289
Invalid sparse file format at unknown block F05E at 38888290
Invalid sparse file format at unknown block 51B7 at 38888292
Invalid sparse file format at unknown block C2B1 at 38888293
Invalid sparse file format at unknown block 59A3 at 38888294
Invalid sparse file format at unknown block 8395 at 38888295
Invalid sparse file format at unknown block 8260 at 38888296
Invalid sparse file format at unknown block A95C at 38888298
Invalid sparse file format at unknown block 936C at 38888299
Invalid sparse file format at unknown block 30FC at 38888300
Invalid sparse file format at unknown block E6C8 at 38888301
Invalid sparse file format at unknown block 3437 at 38888302
Invalid sparse file format at unknown block C448 at 38888304
Invalid sparse file format at unknown block C8C4 at 38888305
Invalid sparse file format at unknown block 82C8 at 38888306
Invalid sparse file format at unknown block D6E8 at 38888307
Invalid sparse file format at unknown block 1D6E at 38888308
Invalid sparse file format at unknown block DA1B at 38888310
Invalid sparse file format at unknown block CDA4 at 38888311
Invalid sparse file format at unknown block D6A5 at 38888312
Invalid sparse file format at unknown block 23E8 at 38888313
Invalid sparse file format at unknown block 7576 at 38888314
Invalid sparse file format at unknown block F8DE at 38888316
Invalid sparse file format at unknown block 143F at 38888317
Invalid sparse file format at unknown block BECA at 38888318
Invalid sparse file format at unknown block 24CA at 38888319
Invalid sparse file format at unknown block 6A3F at 38888320
Invalid sparse file format at unknown block C538 at 38888322
Invalid sparse file format at unknown block 51A5 at 38888323
Invalid sparse file format at unknown block 59E6 at 38888324
Invalid sparse file format at unknown block C159 at 38888325
Invalid sparse file format at unknown block 938D at 38888326
Invalid sparse file format at unknown block 0D22 at 38888328
Invalid sparse file format at unknown block 1D57 at 38888329
Invalid sparse file format at unknown block 5B62 at 38888330
Invalid sparse file format at unknown block B395 at 38888331
Invalid sparse file format at unknown block E7C9 at 38888332
Invalid sparse file format at unknown block B58A at 38888334
Invalid sparse file format at unknown block E38D at 38888335
Invalid sparse file format at unknown block 36FD at 38888336
Invalid sparse file format at unknown block E68A at 38888337
Invalid sparse file format at unknown block 3C33 at 38888338
Invalid sparse file format at unknown block 15A6 at 38888340
Invalid sparse file format at unknown block 59E3 at 38888341
Invalid sparse file format at unknown block 35F6 at 38888342
Invalid sparse file format at unknown block B565 at 38888343
Invalid sparse file format at unknown block E169 at 38888344
Invalid sparse file format at unknown block 643C at 38888346
Invalid sparse file format at unknown block 0B4B at 38888347
Invalid sparse file format at unknown block F388 at 38888348
Invalid sparse file format at unknown block 5F90 at 38888349
Invalid sparse file format at unknown block 9252 at 38888350
Invalid sparse file format at unknown block C047 at 38888352
Invalid sparse file format at unknown block 257E at 38888353
Invalid sparse file format at unknown block 6929 at 38888354
Invalid sparse file format at unknown block 624B at 38888355
Invalid sparse file format at unknown block 0832 at 38888356
Invalid sparse file format at unknown block 391C at 38888358
Invalid sparse file format at unknown block FECA at 38888359
Invalid sparse file format at unknown block AE29 at 38888360
Invalid sparse file format at unknown block B6C5 at 38888361
Invalid sparse file format at unknown block C327 at 38888362
Invalid sparse file format at unknown block C69B at 38888364
Invalid sparse file format at unknown block E6ED at 38888365
Invalid sparse file format at unknown block 26E6 at 38888366
Invalid sparse file format at unknown block 9738 at 38888367
Invalid sparse file format at unknown block 9B8F at 38888368
Invalid sparse file format at unknown block 0E40 at 38888370
Invalid sparse file format at unknown block EF27 at 38888371
Invalid sparse file format at unknown block 73EB at 38888372
Invalid sparse file format at unknown block 61E1 at 38888373
Invalid sparse file format at unknown block 69A6 at 38888374
Invalid sparse file format at unknown block 25E6 at 38888376
Invalid sparse file format at unknown block 45E7 at 38888377
Invalid sparse file format at unknown block DAB0 at 38888378
Invalid sparse file format at unknown block C936 at 38888379
Invalid sparse file format at unknown block 8784 at 38888380
Invalid sparse file format at unknown block 1FD3 at 38888382
Invalid sparse file format at unknown block 0BFE at 38888383
Invalid sparse file format at unknown block 47DF at 38888384
Invalid sparse file format at unknown block 9764 at 38888385
Invalid sparse file format at unknown block E9B8 at 38888386
Invalid sparse file format at unknown block 9DD7 at 38888388
Invalid sparse file format at unknown block 1886 at 38888389
Invalid sparse file format at unknown block BED9 at 38888390
Invalid sparse file format at unknown block 38C2 at 38888391
Invalid sparse file format at unknown block E861 at 38888392
Invalid sparse file format at unknown block DB19 at 38888394
Invalid sparse file format at unknown block 7585 at 38888395
Invalid sparse file format at unknown block 35F9 at 38888396
Invalid sparse file format at unknown block B443 at 38888397
Invalid sparse file format at unknown block F48B at 38888398
Invalid sparse file format at unknown block DA5E at 38888400
Invalid sparse file format at unknown block 106B at 38888401
Invalid sparse file format at unknown block 632D at 38888402
Invalid sparse file format at unknown block B2A7 at 38888403
Invalid sparse file format at unknown block 9EE6 at 38888404
Invalid sparse file format at unknown block 2A2F at 38888406
Invalid sparse file format at unknown block C2D2 at 38888407
Invalid sparse file format at unknown block 480A at 38888408
Invalid sparse file format at unknown block C2AD at 38888409
Invalid sparse file format at unknown block 32E1 at 38888410
Invalid sparse file format at unknown block 171D at 38888412
Invalid sparse file format at unknown block 3514 at 38888413
Invalid sparse file format at unknown block BD14 at 38888414
Invalid sparse file format at unknown block 6983 at 38888415
Invalid sparse file format at unknown block B0B8 at 38888416
Invalid sparse file format at unknown block DA59 at 38888418
Invalid sparse file format at unknown block 95A2 at 38888419
Invalid sparse file format at unknown block 6882 at 38888420
Invalid sparse file format at unknown block 1233 at 38888421
Invalid sparse file format at unknown block 7311 at 38888422
Invalid sparse file format at unknown block 69F3 at 38888424
Invalid sparse file format at unknown block 9048 at 38888425
Invalid sparse file format at unknown block 410D at 38888426
Invalid sparse file format at unknown block C20D at 38888427
Invalid sparse file format at unknown block 736F at 38888428
Invalid sparse file format at unknown block D5F5 at 38888430
Invalid sparse file format at unknown block 246E at 38888431
Invalid sparse file format at unknown block 4B8B at 38888432
Invalid sparse file format at unknown block 75E9 at 38888433
Invalid sparse file format at unknown block 1C0C at 38888434
Invalid sparse file format at unknown block 121F at 38888436
Invalid sparse file format at unknown block 689E at 38888437
Invalid sparse file format at unknown block F4BF at 38888438
Invalid sparse file format at unknown block C1EA at 38888439
Invalid sparse file format at unknown block 103C at 38888440
Invalid sparse file format at unknown block 4202 at 38888442
Invalid sparse file format at unknown block C1FB at 38888443
Invalid sparse file format at unknown block 2AEB at 38888444
Invalid sparse file format at unknown block D537 at 38888445
Invalid sparse file format at unknown block 43B3 at 38888446
Invalid sparse file format at unknown block FE3B at 38888448
Invalid sparse file format at unknown block 5B9E at 38888449
Invalid sparse file format at unknown block ADA8 at 38888450
Invalid sparse file format at unknown block 3F30 at 38888451
Invalid sparse file format at unknown block FAC2 at 38888452
Invalid sparse file format at unknown block 0F4B at 38888454
Invalid sparse file format at unknown block 19DC at 38888455
Invalid sparse file format at unknown block F4B4 at 38888456
Invalid sparse file format at unknown block B9F0 at 38888457
Invalid sparse file format at unknown block 9E3A at 38888458
Invalid sparse file format at unknown block F47F at 38888460
Invalid sparse file format at unknown block 24F1 at 38888461
Invalid sparse file format at unknown block 5455 at 38888462
Invalid sparse file format at unknown block 8AB5 at 38888463
Invalid sparse file format at unknown block F009 at 38888464
Invalid sparse file format at unknown block 61F2 at 38888466
Invalid sparse file format at unknown block DE95 at 38888467
Invalid sparse file format at unknown block 171F at 38888468
Invalid sparse file format at unknown block 9F18 at 38888469
Invalid sparse file format at unknown block A732 at 38888470
Invalid sparse file format at unknown block 258B at 38888472
Invalid sparse file format at unknown block 3FB0 at 38888473
Invalid sparse file format at unknown block EFAF at 38888474
Invalid sparse file format at unknown block FC8D at 38888475
Invalid sparse file format at unknown block 421B at 38888476
Invalid sparse file format at unknown block 5D4C at 38888478
Invalid sparse file format at unknown block F306 at 38888479
Invalid sparse file format at unknown block 3A9A at 38888480
Invalid sparse file format at unknown block 33E8 at 38888481
Invalid sparse file format at unknown block C357 at 38888482
Invalid sparse file format at unknown block 5E0E at 38888484
Invalid sparse file format at unknown block 331F at 38888485
Invalid sparse file format at unknown block F336 at 38888486
Invalid sparse file format at unknown block 1F4C at 38888487
Invalid sparse file format at unknown block 6B73 at 38888488
Invalid sparse file format at unknown block ABB7 at 38888490
Invalid sparse file format at unknown block 7831 at 38888491
Invalid sparse file format at unknown block 67D6 at 38888492
Invalid sparse file format at unknown block AE86 at 38888493
Invalid sparse file format at unknown block EB8B at 38888494
Invalid sparse file format at unknown block 28D2 at 38888496
Invalid sparse file format at unknown block 595F at 38888497
Invalid sparse file format at unknown block BE02 at 38888498
Invalid sparse file format at unknown block B53E at 38888499
Invalid sparse file format at unknown block 296F at 38888500
Invalid sparse file format at unknown block D0FD at 38888502
Invalid sparse file format at unknown block 9EAE at 38888503
Invalid sparse file format at unknown block 1308 at 38888504
Invalid sparse file format at unknown block 9CC0 at 38888505
Invalid sparse file format at unknown block 592B at 38888506
Invalid sparse file format at unknown block 688D at 38888508
Invalid sparse file format at unknown block A73E at 38888509
Invalid sparse file format at unknown block B479 at 38888510
Invalid sparse file format at unknown block CCE9 at 38888511
Invalid sparse file format at unknown block 27E7 at 38888512
Invalid sparse file format at unknown block EA2B at 38888514
Invalid sparse file format at unknown block DA1A at 38888515
Invalid sparse file format at unknown block 90AB at 38888516
Invalid sparse file format at unknown block 0362 at 38888517
Invalid sparse file format at unknown block 124C at 38888518
Invalid sparse file format at unknown block 5849 at 38888520
Invalid sparse file format at unknown block D64C at 38888521
Invalid sparse file format at unknown block F9A7 at 38888522
Invalid sparse file format at unknown block 4FD3 at 38888523
Invalid sparse file format at unknown block 98B5 at 38888524
Invalid sparse file format at unknown block 96E5 at 38888526
Invalid sparse file format at unknown block AB82 at 38888527
Invalid sparse file format at unknown block 7E0A at 38888528
Invalid sparse file format at unknown block 6898 at 38888529
Invalid sparse file format at unknown block A2A8 at 38888530
Invalid sparse file format at unknown block 8A4F at 38888532
Invalid sparse file format at unknown block 56AF at 38888533
Invalid sparse file format at unknown block 85C9 at 38888534
Invalid sparse file format at unknown block A387 at 38888535
Invalid sparse file format at unknown block DD9E at 38888536
Invalid sparse file format at unknown block 902C at 38888538
Invalid sparse file format at unknown block C6F6 at 38888539
Invalid sparse file format at unknown block 39F8 at 38888540
Invalid sparse file format at unknown block 658B at 38888541
Invalid sparse file format at unknown block 2976 at 38888542
Invalid sparse file format at unknown block 098D at 38888544
Invalid sparse file format at unknown block 0E00 at 38888545
Invalid sparse file format at unknown block 2DED at 38888546
Invalid sparse file format at unknown block B002 at 38888547
Invalid sparse file format at unknown block DA0C at 38888548
Invalid sparse file format at unknown block CA53 at 38888550
Invalid sparse file format at unknown block BC76 at 38888551
Invalid sparse file format at unknown block CB59 at 38888552
Invalid sparse file format at unknown block BD68 at 38888553
Invalid sparse file format at unknown block DFE2 at 38888554
Invalid sparse file format at unknown block 56F4 at 38888556
Invalid sparse file format at unknown block 4F4B at 38888557
Invalid sparse file format at unknown block 3D02 at 38888558
Invalid sparse file format at unknown block D4B2 at 38888559
Invalid sparse file format at unknown block 6884 at 38888560
Invalid sparse file format at unknown block B886 at 38888562
Invalid sparse file format at unknown block 8A30 at 38888563
Invalid sparse file format at unknown block 6195 at 38888564
Invalid sparse file format at unknown block 0DAA at 38888565
Invalid sparse file format at unknown block D14F at 38888566
Invalid sparse file format at unknown block 485B at 38888568
Invalid sparse file format at unknown block D82B at 38888569
Invalid sparse file format at unknown block 334A at 38888570
Invalid sparse file format at unknown block D3B8 at 38888571
Invalid sparse file format at unknown block CAAF at 38888572
Invalid sparse file format at unknown block 9F7E at 38888574
Invalid sparse file format at unknown block 040A at 38888575
Invalid sparse file format at unknown block 6EBF at 38888576
Invalid sparse file format at unknown block 0EBB at 38888577
Invalid sparse file format at unknown block 10C5 at 38888578
Invalid sparse file format at unknown block 6551 at 38888580
Invalid sparse file format at unknown block A304 at 38888581
Invalid sparse file format at unknown block 63EA at 38888582
Invalid sparse file format at unknown block F989 at 38888583
Invalid sparse file format at unknown block 0050 at 38888584
Invalid sparse file format at unknown block 86C7 at 38888586
Invalid sparse file format at unknown block DD20 at 38888587
Invalid sparse file format at unknown block F971 at 38888588
Invalid sparse file format at unknown block 8D9D at 38888589
Invalid sparse file format at unknown block 1956 at 38888590
Invalid sparse file format at unknown block CBD1 at 38888592
Invalid sparse file format at unknown block DEA0 at 38888593
Invalid sparse file format at unknown block 9A17 at 38888594
Invalid sparse file format at unknown block 934F at 38888595
Invalid sparse file format at unknown block A154 at 38888596
Invalid sparse file format at unknown block C33C at 38888598
Invalid sparse file format at unknown block D1C8 at 38888599
Invalid sparse file format at unknown block 4B5C at 38888600
Invalid sparse file format at unknown block 06CB at 38888601
Invalid sparse file format at unknown block 2B73 at 38888602
Invalid sparse file format at unknown block 10C7 at 38888604
Invalid sparse file format at unknown block FEE8 at 38888605
Invalid sparse file format at unknown block A56B at 38888606
Invalid sparse file format at unknown block A1C9 at 38888607
Invalid sparse file format at unknown block C393 at 38888608
Invalid sparse file format at unknown block 8BFA at 38888610
Invalid sparse file format at unknown block B561 at 38888611
Invalid sparse file format at unknown block 9182 at 38888612
Invalid sparse file format at unknown block 42A3 at 38888613
Invalid sparse file format at unknown block 4BFA at 38888614
Invalid sparse file format at unknown block 682E at 38888616
Invalid sparse file format at unknown block 7E56 at 38888617
Invalid sparse file format at unknown block 5B85 at 38888618
Invalid sparse file format at unknown block 4389 at 38888619
Invalid sparse file format at unknown block F060 at 38888620
Invalid sparse file format at unknown block 9E03 at 38888622
Invalid sparse file format at unknown block B9A7 at 38888623
Invalid sparse file format at unknown block EB83 at 38888624
Invalid sparse file format at unknown block A217 at 38888625
Invalid sparse file format at unknown block 4126 at 38888626
Invalid sparse file format at unknown block 0A07 at 38888628
Invalid sparse file format at unknown block 2B1C at 38888629
Invalid sparse file format at unknown block F05A at 38888630
Invalid sparse file format at unknown block 7873 at 38888631
Invalid sparse file format at unknown block F1EA at 38888632
Invalid sparse file format at unknown block 67AB at 38888634
Invalid sparse file format at unknown block E322 at 38888635
Invalid sparse file format at unknown block B78E at 38888636
Invalid sparse file format at unknown block 38E9 at 38888637
Invalid sparse file format at unknown block B325 at 38888638
Invalid sparse file format at unknown block 4681 at 38888640
Invalid sparse file format at unknown block 54B4 at 38888641
Invalid sparse file format at unknown block EF57 at 38888642
Invalid sparse file format at unknown block 847E at 38888643
Invalid sparse file format at unknown block 2DDE at 38888644
Invalid sparse file format at unknown block 84ED at 38888646
Invalid sparse file format at unknown block 8E13 at 38888647
Invalid sparse file format at unknown block 18A6 at 38888648
Invalid sparse file format at unknown block 5E20 at 38888649
Invalid sparse file format at unknown block 330C at 38888650
Invalid sparse file format at unknown block D51A at 38888652
Invalid sparse file format at unknown block 9E29 at 38888653
Invalid sparse file format at unknown block 2F00 at 38888654
Invalid sparse file format at unknown block 4880 at 38888655
Invalid sparse file format at unknown block 1CDA at 38888656
Invalid sparse file format at unknown block 694A at 38888658
Invalid sparse file format at unknown block 53F1 at 38888659
Invalid sparse file format at unknown block BDFC at 38888660
Invalid sparse file format at unknown block 1EE1 at 38888661
Invalid sparse file format at unknown block 293B at 38888662
Invalid sparse file format at unknown block A40C at 38888664
Invalid sparse file format at unknown block BF16 at 38888665
Invalid sparse file format at unknown block 129C at 38888666
Invalid sparse file format at unknown block 2CC7 at 38888667
Invalid sparse file format at unknown block C706 at 38888668
Invalid sparse file format at unknown block 31E1 at 38888670
Invalid sparse file format at unknown block 38AE at 38888671
Invalid sparse file format at unknown block 2B60 at 38888672
Invalid sparse file format at unknown block 3FC1 at 38888673
Invalid sparse file format at unknown block 03C9 at 38888674
Invalid sparse file format at unknown block 6E8D at 38888676
Invalid sparse file format at unknown block 8539 at 38888677
Invalid sparse file format at unknown block 32F0 at 38888678
Invalid sparse file format at unknown block 2D94 at 38888679
Invalid sparse file format at unknown block 35A0 at 38888680
Invalid sparse file format at unknown block A46A at 38888682
Invalid sparse file format at unknown block 37A3 at 38888683
Invalid sparse file format at unknown block 44BF at 38888684
Invalid sparse file format at unknown block 9DA1 at 38888685
Invalid sparse file format at unknown block 794C at 38888686
Invalid sparse file format at unknown block C878 at 38888688
Invalid sparse file format at unknown block E0C0 at 38888689
Invalid sparse file format at unknown block A5D1 at 38888690
Invalid sparse file format at unknown block 76BA at 38888691
Invalid sparse file format at unknown block 25F3 at 38888692
Invalid sparse file format at unknown block B4F8 at 38888694
Invalid sparse file format at unknown block 10E4 at 38888695
Invalid sparse file format at unknown block 3591 at 38888696
Invalid sparse file format at unknown block 338F at 38888697
Invalid sparse file format at unknown block 4ABF at 38888698
Invalid sparse file format at unknown block 735E at 38888700
Invalid sparse file format at unknown block A30B at 38888701
Invalid sparse file format at unknown block 4E0A at 38888702
Invalid sparse file format at unknown block 521D at 38888703
Invalid sparse file format at unknown block C56A at 38888704
Invalid sparse file format at unknown block 1B15 at 38888706
Invalid sparse file format at unknown block 7E7B at 38888707
Invalid sparse file format at unknown block 32F6 at 38888708
Invalid sparse file format at unknown block 6993 at 38888709
Invalid sparse file format at unknown block 6A6A at 38888710
Invalid sparse file format at unknown block 11EE at 38888712
Invalid sparse file format at unknown block C1EA at 38888713
Invalid sparse file format at unknown block D6FB at 38888714
Invalid sparse file format at unknown block 1919 at 38888715
Invalid sparse file format at unknown block 13C3 at 38888716
Invalid sparse file format at unknown block 062F at 38888718
Invalid sparse file format at unknown block 6907 at 38888719
Invalid sparse file format at unknown block 01CA at 38888720
Invalid sparse file format at unknown block 1590 at 38888721
Invalid sparse file format at unknown block 0713 at 38888722
Invalid sparse file format at unknown block 273D at 38888724
Invalid sparse file format at unknown block 9BEB at 38888725
Invalid sparse file format at unknown block E1B5 at 38888726
Invalid sparse file format at unknown block 3343 at 38888727
Invalid sparse file format at unknown block E95E at 38888728
Invalid sparse file format at unknown block C9A9 at 38888730
Invalid sparse file format at unknown block 937C at 38888731
Invalid sparse file format at unknown block 6F5A at 38888732
Invalid sparse file format at unknown block 311A at 38888733
Invalid sparse file format at unknown block 2718 at 38888734
Invalid sparse file format at unknown block 60A8 at 38888736
Invalid sparse file format at unknown block AA78 at 38888737
Invalid sparse file format at unknown block E530 at 38888738
Invalid sparse file format at unknown block F253 at 38888739
Invalid sparse file format at unknown block 97E4 at 38888740
Invalid sparse file format at unknown block 10C5 at 38888742
Invalid sparse file format at unknown block E15D at 38888743
Invalid sparse file format at unknown block 59D0 at 38888744
Invalid sparse file format at unknown block 63B8 at 38888745
Invalid sparse file format at unknown block 9BBD at 38888746
Invalid sparse file format at unknown block 65C7 at 38888748
Invalid sparse file format at unknown block 97D0 at 38888749
Invalid sparse file format at unknown block 6299 at 38888750
Invalid sparse file format at unknown block E06B at 38888751
Invalid sparse file format at unknown block 8F0D at 38888752
Invalid sparse file format at unknown block 2638 at 38888754
Invalid sparse file format at unknown block F91F at 38888755
Invalid sparse file format at unknown block 7E7F at 38888756
Invalid sparse file format at unknown block 8C71 at 38888757
Invalid sparse file format at unknown block E921 at 38888758
Invalid sparse file format at unknown block 5707 at 38888760
Invalid sparse file format at unknown block EFB5 at 38888761
Invalid sparse file format at unknown block 4B72 at 38888762
Invalid sparse file format at unknown block 408A at 38888763
Invalid sparse file format at unknown block A69D at 38888764
Invalid sparse file format at unknown block 3826 at 38888766
Invalid sparse file format at unknown block 01F9 at 38888767
Invalid sparse file format at unknown block EF4A at 38888768
Invalid sparse file format at unknown block E299 at 38888769
Invalid sparse file format at unknown block 22C0 at 38888770
Invalid sparse file format at unknown block AA37 at 38888772
Invalid sparse file format at unknown block 06AC at 38888773
Invalid sparse file format at unknown block 115A at 38888774
Invalid sparse file format at unknown block F704 at 38888775
Invalid sparse file format at unknown block 9CEF at 38888776
Invalid sparse file format at unknown block FF05 at 38888778
Invalid sparse file format at unknown block 314D at 38888779
Invalid sparse file format at unknown block 1A20 at 38888780
Invalid sparse file format at unknown block D138 at 38888781
Invalid sparse file format at unknown block 3C7B at 38888782
Invalid sparse file format at unknown block 72CE at 38888784
Invalid sparse file format at unknown block BCE0 at 38888785
Invalid sparse file format at unknown block 2DC6 at 38888786
Invalid sparse file format at unknown block 73D3 at 38888787
Invalid sparse file format at unknown block CC7B at 38888788
Invalid sparse file format at unknown block 1CC8 at 38888790
Invalid sparse file format at unknown block 864C at 38888791
Invalid sparse file format at unknown block 0D92 at 38888792
Invalid sparse file format at unknown block 1A71 at 38888793
Invalid sparse file format at unknown block 8C5C at 38888794
Invalid sparse file format at unknown block 7F70 at 38888796
Invalid sparse file format at unknown block 926A at 38888797
Invalid sparse file format at unknown block A891 at 38888798
Invalid sparse file format at unknown block 7663 at 38888799
Invalid sparse file format at unknown block E99E at 38888800
Invalid sparse file format at unknown block D9CA at 38888802
Invalid sparse file format at unknown block CB38 at 38888803
Invalid sparse file format at unknown block 9E85 at 38888804
Invalid sparse file format at unknown block A6AC at 38888805
Invalid sparse file format at unknown block 05EB at 38888806
Invalid sparse file format at unknown block 5AFA at 38888808
Invalid sparse file format at unknown block D811 at 38888809
Invalid sparse file format at unknown block F9FF at 38888810
Invalid sparse file format at unknown block 3B63 at 38888811
Invalid sparse file format at unknown block 822A at 38888812
Invalid sparse file format at unknown block 8121 at 38888814
Invalid sparse file format at unknown block 9094 at 38888815
Invalid sparse file format at unknown block 8359 at 38888816
Invalid sparse file format at unknown block 85BF at 38888817
Invalid sparse file format at unknown block 2D09 at 38888818
Invalid sparse file format at unknown block 5EA3 at 38888820
Invalid sparse file format at unknown block 92D3 at 38888821
Invalid sparse file format at unknown block A732 at 38888822
Invalid sparse file format at unknown block AE9B at 38888823
Invalid sparse file format at unknown block 276E at 38888824
Invalid sparse file format at unknown block 67F8 at 38888826
Invalid sparse file format at unknown block EAF4 at 38888827
Invalid sparse file format at unknown block 78C7 at 38888828
Invalid sparse file format at unknown block 9BDE at 38888829
Invalid sparse file format at unknown block 4F86 at 38888830
Invalid sparse file format at unknown block 8173 at 38888832
Invalid sparse file format at unknown block 0265 at 38888833
Invalid sparse file format at unknown block 582E at 38888834
Invalid sparse file format at unknown block 550D at 38888835
Invalid sparse file format at unknown block D916 at 38888836
Invalid sparse file format at unknown block 1FF7 at 38888838
Invalid sparse file format at unknown block 3AB0 at 38888839
Invalid sparse file format at unknown block 95D5 at 38888840
Invalid sparse file format at unknown block 3458 at 38888841
Invalid sparse file format at unknown block 0CAA at 38888842
Invalid sparse file format at unknown block 26CD at 38888844
Invalid sparse file format at unknown block 3B83 at 38888845
Invalid sparse file format at unknown block F089 at 38888846
Invalid sparse file format at unknown block BBBD at 38888847
Invalid sparse file format at unknown block 6FF4 at 38888848
Invalid sparse file format at unknown block 4476 at 38888850
Invalid sparse file format at unknown block AEEA at 38888851
Invalid sparse file format at unknown block 340A at 38888852
Invalid sparse file format at unknown block 7233 at 38888853
Invalid sparse file format at unknown block A176 at 38888854
Invalid sparse file format at unknown block 0D50 at 38888856
Invalid sparse file format at unknown block 3CCD at 38888857
Invalid sparse file format at unknown block 4E68 at 38888858
Invalid sparse file format at unknown block 78F6 at 38888859
Invalid sparse file format at unknown block 26AD at 38888860
Invalid sparse file format at unknown block E21C at 38888862
Invalid sparse file format at unknown block 23FD at 38888863
Invalid sparse file format at unknown block 0CA9 at 38888864
Invalid sparse file format at unknown block 7113 at 38888865
Invalid sparse file format at unknown block BBCB at 38888866
Invalid sparse file format at unknown block D893 at 38888868
Invalid sparse file format at unknown block 15DA at 38888869
Invalid sparse file format at unknown block EC17 at 38888870
Invalid sparse file format at unknown block 04AE at 38888871
Invalid sparse file format at unknown block DA86 at 38888872
Invalid sparse file format at unknown block 048A at 38888874
Invalid sparse file format at unknown block FAFB at 38888875
Invalid sparse file format at unknown block DB3D at 38888876
Invalid sparse file format at unknown block 9F30 at 38888877
Invalid sparse file format at unknown block A458 at 38888878
Invalid sparse file format at unknown block 6B8C at 38888880
Invalid sparse file format at unknown block D505 at 38888881
Invalid sparse file format at unknown block FB27 at 38888882
Invalid sparse file format at unknown block C745 at 38888883
Invalid sparse file format at unknown block 7989 at 38888884
Invalid sparse file format at unknown block 223B at 38888886
Invalid sparse file format at unknown block 9B84 at 38888887
Invalid sparse file format at unknown block 3F22 at 38888888
Invalid sparse file format at unknown block A196 at 38888889
Invalid sparse file format at unknown block CD2F at 38888890
Invalid sparse file format at unknown block EDCB at 38888892
Invalid sparse file format at unknown block BB33 at 38888893
Invalid sparse file format at unknown block 9C96 at 38888894
Invalid sparse file format at unknown block 6FA2 at 38888895
Invalid sparse file format at unknown block 3AA2 at 38888896
Invalid sparse file format at unknown block 6AB0 at 38888898
Invalid sparse file format at unknown block 4241 at 38888899
Invalid sparse file format at unknown block D926 at 38888900
Invalid sparse file format at unknown block 3CF1 at 38888901
Invalid sparse file format at unknown block F1EC at 38888902
Invalid sparse file format at unknown block 2333 at 38888904
Invalid sparse file format at unknown block 4937 at 38888905
Invalid sparse file format at unknown block 26E4 at 38888906
Invalid sparse file format at unknown block 5B8F at 38888907
Invalid sparse file format at unknown block 5944 at 38888908
Invalid sparse file format at unknown block 0725 at 38888910
Invalid sparse file format at unknown block 7712 at 38888911
Invalid sparse file format at unknown block BC97 at 38888912
Invalid sparse file format at unknown block FCBB at 38888913
Invalid sparse file format at unknown block 7D13 at 38888914
Invalid sparse file format at unknown block F549 at 38888916
Invalid sparse file format at unknown block 20AB at 38888917
Invalid sparse file format at unknown block 901F at 38888918
Invalid sparse file format at unknown block 4DF4 at 38888919
Invalid sparse file format at unknown block 2A4A at 38888920
Invalid sparse file format at unknown block 556C at 38888922
Invalid sparse file format at unknown block 174E at 38888923
Invalid sparse file format at unknown block 7193 at 38888924
Invalid sparse file format at unknown block 3940 at 38888925
Invalid sparse file format at unknown block BB5A at 38888926
Invalid sparse file format at unknown block ACE7 at 38888928
Invalid sparse file format at unknown block 3C8B at 38888929
Invalid sparse file format at unknown block 0B6E at 38888930
Invalid sparse file format at unknown block 6A0F at 38888931
Invalid sparse file format at unknown block 2A29 at 38888932
Invalid sparse file format at unknown block 061E at 38888934
Invalid sparse file format at unknown block 4E99 at 38888935
Invalid sparse file format at unknown block C26A at 38888936
Invalid sparse file format at unknown block 041B at 38888937
Invalid sparse file format at unknown block AD82 at 38888938
Invalid sparse file format at unknown block DEF9 at 38888940
Invalid sparse file format at unknown block 2F29 at 38888941
Invalid sparse file format at unknown block 7A58 at 38888942
Invalid sparse file format at unknown block A96B at 38888943
Invalid sparse file format at unknown block D46D at 38888944
Invalid sparse file format at unknown block 6E40 at 38888946
Invalid sparse file format at unknown block 81B7 at 38888947
Invalid sparse file format at unknown block C9C2 at 38888948
Invalid sparse file format at unknown block 9761 at 38888949
Invalid sparse file format at unknown block 6789 at 38888950
Invalid sparse file format at unknown block 9A8D at 38888952
Invalid sparse file format at unknown block 5270 at 38888953
Invalid sparse file format at unknown block D239 at 38888954
Invalid sparse file format at unknown block 69C9 at 38888955
Invalid sparse file format at unknown block 96FA at 38888956
Invalid sparse file format at unknown block 314A at 38888958
Invalid sparse file format at unknown block 05DA at 38888959
Invalid sparse file format at unknown block 5B7D at 38888960
Invalid sparse file format at unknown block E725 at 38888961
Invalid sparse file format at unknown block FDA9 at 38888962
Invalid sparse file format at unknown block C8CA at 38888964
Invalid sparse file format at unknown block ACA5 at 38888965
Invalid sparse file format at unknown block D029 at 38888966
Invalid sparse file format at unknown block A7A0 at 38888967
Invalid sparse file format at unknown block D66A at 38888968
Invalid sparse file format at unknown block 113D at 38888970
Invalid sparse file format at unknown block 588E at 38888971
Invalid sparse file format at unknown block 1526 at 38888972
Invalid sparse file format at unknown block CF3C at 38888973
Invalid sparse file format at unknown block 372F at 38888974
Invalid sparse file format at unknown block 3473 at 38888976
Invalid sparse file format at unknown block 2C65 at 38888977
Invalid sparse file format at unknown block 8B56 at 38888978
Invalid sparse file format at unknown block 4D43 at 38888979
Invalid sparse file format at unknown block 1D5A at 38888980
Invalid sparse file format at unknown block 3936 at 38888982
Invalid sparse file format at unknown block 6200 at 38888983
Invalid sparse file format at unknown block 2035 at 38888984
Invalid sparse file format at unknown block 387D at 38888985
Invalid sparse file format at unknown block C2A8 at 38888986
Invalid sparse file format at unknown block 11DE at 38888988
Invalid sparse file format at unknown block 0709 at 38888989
Invalid sparse file format at unknown block 5E17 at 38888990
Invalid sparse file format at unknown block FE5B at 38888991
Invalid sparse file format at unknown block CA34 at 38888992
Invalid sparse file format at unknown block 7158 at 38888994
Invalid sparse file format at unknown block DE8E at 38888995
Invalid sparse file format at unknown block 8017 at 38888996
Invalid sparse file format at unknown block D961 at 38888997
Invalid sparse file format at unknown block B1F0 at 38888998
Invalid sparse file format at unknown block DE4E at 38889000
Invalid sparse file format at unknown block 3871 at 38889001
Invalid sparse file format at unknown block 8E02 at 38889002
Invalid sparse file format at unknown block 80D1 at 38889003
Invalid sparse file format at unknown block 5E8B at 38889004
Invalid sparse file format at unknown block 94FD at 38889006
Invalid sparse file format at unknown block 5736 at 38889007
Invalid sparse file format at unknown block 9788 at 38889008
Invalid sparse file format at unknown block 090E at 38889009
Invalid sparse file format at unknown block E929 at 38889010
Invalid sparse file format at unknown block 76CA at 38889012
Invalid sparse file format at unknown block 1FBF at 38889013
Invalid sparse file format at unknown block 5147 at 38889014
Invalid sparse file format at unknown block E203 at 38889015
Invalid sparse file format at unknown block 1D40 at 38889016
Invalid sparse file format at unknown block 088D at 38889018
Invalid sparse file format at unknown block 78C7 at 38889019
Invalid sparse file format at unknown block 1A58 at 38889020
Invalid sparse file format at unknown block E818 at 38889021
Invalid sparse file format at unknown block EEED at 38889022
Invalid sparse file format at unknown block 1F94 at 38889024
Invalid sparse file format at unknown block 8CA9 at 38889025
Invalid sparse file format at unknown block 4B37 at 38889026
Invalid sparse file format at unknown block 4B4D at 38889027
Invalid sparse file format at unknown block B4CB at 38889028
Invalid sparse file format at unknown block 9F37 at 38889030
Invalid sparse file format at unknown block 739A at 38889031
Invalid sparse file format at unknown block 4362 at 38889032
Invalid sparse file format at unknown block B0B2 at 38889033
Invalid sparse file format at unknown block E248 at 38889034
Invalid sparse file format at unknown block 7F21 at 38889036
Invalid sparse file format at unknown block 610B at 38889037
Invalid sparse file format at unknown block 2A19 at 38889038
Invalid sparse file format at unknown block 1C7F at 38889039
Invalid sparse file format at unknown block 5780 at 38889040
Invalid sparse file format at unknown block F8E4 at 38889042
Invalid sparse file format at unknown block C339 at 38889043
Invalid sparse file format at unknown block E5EA at 38889044
Invalid sparse file format at unknown block 277B at 38889045
Invalid sparse file format at unknown block 0556 at 38889046
Invalid sparse file format at unknown block 5267 at 38889048
Invalid sparse file format at unknown block 69DA at 38889049
Invalid sparse file format at unknown block E74F at 38889050
Invalid sparse file format at unknown block C175 at 38889051
Invalid sparse file format at unknown block CABD at 38889052
Invalid sparse file format at unknown block 1296 at 38889054
Invalid sparse file format at unknown block 921F at 38889055
Invalid sparse file format at unknown block E484 at 38889056
Invalid sparse file format at unknown block DB72 at 38889057
Invalid sparse file format at unknown block 8666 at 38889058
Invalid sparse file format at unknown block D6F7 at 38889060
Invalid sparse file format at unknown block 4ACF at 38889061
Invalid sparse file format at unknown block E004 at 38889062
Invalid sparse file format at unknown block B212 at 38889063
Invalid sparse file format at unknown block C7BD at 38889064
Invalid sparse file format at unknown block AFFD at 38889066
Invalid sparse file format at unknown block 143A at 38889067
Invalid sparse file format at unknown block FD27 at 38889068
Invalid sparse file format at unknown block 94D5 at 38889069
Invalid sparse file format at unknown block 1A86 at 38889070
Invalid sparse file format at unknown block CADC at 38889072
Invalid sparse file format at unknown block 93C4 at 38889073
Invalid sparse file format at unknown block CF3A at 38889074
Invalid sparse file format at unknown block FD08 at 38889075
Invalid sparse file format at unknown block B511 at 38889076
Invalid sparse file format at unknown block D15D at 38889078
Invalid sparse file format at unknown block 87DB at 38889079
Invalid sparse file format at unknown block 8A5B at 38889080
Invalid sparse file format at unknown block 8CA5 at 38889081
Invalid sparse file format at unknown block DE23 at 38889082
Invalid sparse file format at unknown block A96B at 38889084
Invalid sparse file format at unknown block CC56 at 38889085
Invalid sparse file format at unknown block 0759 at 38889086
Invalid sparse file format at unknown block D017 at 38889087
Invalid sparse file format at unknown block 9C5C at 38889088
Invalid sparse file format at unknown block 3F6D at 38889090
Invalid sparse file format at unknown block D656 at 38889091
Invalid sparse file format at unknown block 5861 at 38889092
Invalid sparse file format at unknown block 0595 at 38889093
Invalid sparse file format at unknown block E5F3 at 38889094
Invalid sparse file format at unknown block 8ADA at 38889096
Invalid sparse file format at unknown block ACF9 at 38889097
Invalid sparse file format at unknown block DF38 at 38889098
Invalid sparse file format at unknown block 1D3B at 38889099
Invalid sparse file format at unknown block 7975 at 38889100
Invalid sparse file format at unknown block D826 at 38889102
Invalid sparse file format at unknown block F139 at 38889103
Invalid sparse file format at unknown block 76CB at 38889104
Invalid sparse file format at unknown block 55D0 at 38889105
Invalid sparse file format at unknown block 2134 at 38889106
Invalid sparse file format at unknown block 9EE3 at 38889108
Invalid sparse file format at unknown block 4BFA at 38889109
Invalid sparse file format at unknown block 2AC2 at 38889110
Invalid sparse file format at unknown block E097 at 38889111
Invalid sparse file format at unknown block C0C3 at 38889112
Invalid sparse file format at unknown block 7987 at 38889114
Invalid sparse file format at unknown block DBAC at 38889115
Invalid sparse file format at unknown block 1807 at 38889116
Invalid sparse file format at unknown block A546 at 38889117
Invalid sparse file format at unknown block AA2C at 38889118
Invalid sparse file format at unknown block 25D5 at 38889120
Invalid sparse file format at unknown block 1608 at 38889121
Invalid sparse file format at unknown block 7251 at 38889122
Invalid sparse file format at unknown block 9509 at 38889123
Invalid sparse file format at unknown block AC50 at 38889124
Invalid sparse file format at unknown block 8832 at 38889126
Invalid sparse file format at unknown block 3C16 at 38889127
Invalid sparse file format at unknown block 7D88 at 38889128
Invalid sparse file format at unknown block F0AB at 38889129
Invalid sparse file format at unknown block FA84 at 38889130
Invalid sparse file format at unknown block 34D8 at 38889132
Invalid sparse file format at unknown block 195A at 38889133
Invalid sparse file format at unknown block E37E at 38889134
Invalid sparse file format at unknown block 9E9F at 38889135
Invalid sparse file format at unknown block 66D8 at 38889136
Invalid sparse file format at unknown block 18F0 at 38889138
Invalid sparse file format at unknown block 168C at 38889139
Invalid sparse file format at unknown block C641 at 38889140
Invalid sparse file format at unknown block 4500 at 38889141
Invalid sparse file format at unknown block F06C at 38889142
Invalid sparse file format at unknown block DAE5 at 38889144
Invalid sparse file format at unknown block C90E at 38889145
Invalid sparse file format at unknown block F169 at 38889146
Invalid sparse file format at unknown block 7140 at 38889147
Invalid sparse file format at unknown block 27D4 at 38889148
Invalid sparse file format at unknown block 8608 at 38889150
Invalid sparse file format at unknown block 6234 at 38889151
Invalid sparse file format at unknown block 429A at 38889152
Invalid sparse file format at unknown block 2EBA at 38889153
Invalid sparse file format at unknown block B75C at 38889154
Invalid sparse file format at unknown block 3DF6 at 38889156
Invalid sparse file format at unknown block AEB6 at 38889157
Invalid sparse file format at unknown block 7F96 at 38889158
Invalid sparse file format at unknown block 1169 at 38889159
Invalid sparse file format at unknown block 9222 at 38889160
Invalid sparse file format at unknown block 5F37 at 38889162
Invalid sparse file format at unknown block C198 at 38889163
Invalid sparse file format at unknown block E431 at 38889164
Invalid sparse file format at unknown block 5515 at 38889165
Invalid sparse file format at unknown block 179C at 38889166
Invalid sparse file format at unknown block 98ED at 38889168
Invalid sparse file format at unknown block 1DF8 at 38889169
Invalid sparse file format at unknown block F942 at 38889170
Invalid sparse file format at unknown block B7F0 at 38889171
Invalid sparse file format at unknown block 964A at 38889172
Invalid sparse file format at unknown block 8468 at 38889174
Invalid sparse file format at unknown block D133 at 38889175
Invalid sparse file format at unknown block A58C at 38889176
Invalid sparse file format at unknown block DA61 at 38889177
Failed to read sparse file
UTP: sending Non-success to kernel for command $ simg2img $FILE /dev/mmcblk0p`cat /tmp/partIdx | awk '{print $1}'`.
[ 64.515273] utp_poll: exit with status 65280
