imx8mq: How to load yocto image on non-root cell of jailhouse hypervisor
2,500 次查看
vsuneja63
I am running jailhouse hypervisor on imx8mqevk. Created a non-root cell but how I can load yocto image on that. I want to load multiple yocto images in non-root cells of jailhouse hypervisor. Can you please guide me on the same? Its a blocker for me, would like to hear from you asap.
Thanks & Regards,
Vipul Kumar
4 回复数
2,349 次查看
Bio_TICFSL
Hello Vipul,
The partition with the rootfs used by the Linux non-root cell in this demo is defined in the eMMC: root=/dev/mmcblk0p2. You can just flash the same Linux image on the emmc.
2,349 次查看
vsuneja63
Can you share steps for reference to go ahead with this?
Thanks & Regards,
Vipul Kumar
2,349 次查看
Peng_Fan
So you wanna know how to burn yocto images to emmc? Use uuu tool following linux user guide.
Kernel & Virtualization Engineer
2,349 次查看
vsuneja63
Any suggestion on the question, as some configuration commit happened for imx8mq.
Thanks & Regards,
Vipul Kumar
