imx8mq: How to load yocto image on non-root cell of jailhouse hypervisor
Search instead for
vsuneja63
I am running jailhouse hypervisor on imx8mqevk. Created a non-root cell but how I can load yocto image on that. I want to load multiple yocto images in non-root cells of jailhouse hypervisor. Can you please guide me on the same? Its a blocker for me, would like to hear from you asap.
Thanks & Regards,
Vipul Kumar
Bio_TICFSL
Hello Vipul,
The partition with the rootfs used by the Linux non-root cell in this demo is defined in the eMMC: root=/dev/mmcblk0p2. You can just flash the same Linux image on the emmc.
vsuneja63
Can you share steps for reference to go ahead with this?
Thanks & Regards,
Vipul Kumar
pengfan
So you wanna know how to burn yocto images to emmc? Use uuu tool following linux user guide.
vsuneja63
Any suggestion on the question, as some configuration commit happened for imx8mq.
Thanks & Regards,
Vipul Kumar
