imx8mq-EVK在哪里找交叉编译工具?
Here could you tell us which version BSP are you using? Linux or Andorid BSP?
L4.14.98_2.0.0 linux
应该还是GFW的问题,虽然换了manifest的链接,但还是会去找repo python脚本写的clone.bundle的路径,这个路径不能访问导致,
但是我换了repo init -u https://mirrors.tuna.tsinghua.edu.cn/git/lineageOS/LineageOS/android.git -b cm-14.1 --repo-url=https://gerrit-googlesource.lug.ustc.edu.cn/git-repo可以成功一部分,报了一个not found 404错,同步的时候也是有些没找到,error: Cannot fetch platform/external/llvm from https://android.googlesource.com/platform/external/llvm error: Exited sync due to fetch errors,能不能提供一个可用的网址和操作步骤?
You can refer to https://community.nxp.com/docs/DOC-343273
按照 i.MX Yocto Project User's Guide.pdf第4节安装 Yocto Project时, repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-rocko -m imx-4.9.88-2.0.0_ga.xml 报连接不上,换成repo init -u https://source.codeaurora.org/external/imx/imx-manifest/tree/?h=imx-linux-rocko -b imx-linux-rocko -m imx-4.9.88-2.0.0_ga.xml也一样,多次删除了.repo目录再试也一样,
i.MX Yocto Project User's Guide.pdf里从3节开始到repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-rocko -m imx-4.9.88-2.0.0_ga.xml 命令前的操作都是成功的,请问这是什么原因导致呢?谢谢
按照use i.MX Yocto Project User's Guide.pdf第4节安装 Yocto Project时,
