Hi community:
What is the difference between evk_8mq-userdebug and evk_8mq_drm-userdebug?
When I "lunch evk_8mq_drm-userdebug; make", there is a error:
ninja: error: 'vendor/nxp/drm_artifacts/playready/Samples/devcert.dat', needed by 'out/target/product/evk_8mq/vendor/playready/devcert.dat', missing and no known rule to make it
09:05:47 ninja failed with: exit status 1
Where can I get "vendor/nxp/drm_artifacts/playready/Samples/devcert.dat" ?
解決済! 解決策の投稿を見る。
Hello Mr Xue,
(1) evk_8mq-userdebug: this is a our standard release version.
(2) evk_8mq_drm-userdebug:Android team adds protection to DRM stream on the basis of standard version.
probably you can add some lines below to BoardConfig.mk, then try to compile it!
ifeq ($(PRODUCT_IMX_DRM),true)
BOARD_SEPOLICY_DIRS += \
$(IMX_DEVICE_PATH)/sepolicy_drm
endif
If you still meet error, compile standard version, please!
Have a nice day!
BR,
Weidong
Thanks !
