imx8mp vpu encoder: vc8000e: driver segmentation fault
328 次查看
vmbtech
0x0000ffffd83ba748 in VCEncStrmEncodeExt () from /lib/libhantro_vc8000e.so.1 (gdb) bt
#0 0x0000ffffd83ba748 in VCEncStrmEncodeExt () from /lib/libhantro_vc8000e.so.1 warning: could not convert 'main' from the host encoding (ANSI_X3.4-1968) to UTF-32. This normally should not happen, please file a bug report.
#1 0x0000ffffd83bdc00 in VCEncStrmEncode () from /lib/libhantro_vc8000e.so.1
#2 0x0000ffffd84e771c in VCEnc_encoder_encode () from /lib/libfslvpuwrap.so.3
#3 0x0000ffffd84e8124 in VPU_EncEncodeFrame () from /lib/libfslvpuwrap.so.3
#4 0x0000ffffd85a2af4 in ?? () from /lib/gstreamer-1.0/libgstvpu.so
#5 0x0000fffff65bf9b8 in ?? () from /lib/libgstvideo-1.0.so.0
#6 0x0000fffff78e43a8 in ?? () from /lib/libgstreamer-1.0.so.0
#7 0x0000fffff78e65bc in ?? () from /lib/libgstreamer-1.0.so.0
#8 0x0000fffff78ee6f4 in gst_pad_push () from /lib/libgstreamer-1.0.so.0
#9 0x0000fffff7aba87c in ?? () from /lib/libgstbase-1.0.so.0
#10 0x0000fffff78e43a8 in ?? () from /lib/libgstreamer-1.0.so.0
#11 0x0000fffff78e65bc in ?? () from /lib/libgstreamer-1.0.so.0
#12 0x0000fffff78ee6f4 in gst_pad_push () from /lib/libgstreamer-1.0.so.0
#13 0x0000fffff7aba87c in ?? () from /lib/libgstbase-1.0.so.0
#14 0x0000fffff78e43a8 in ?? () from /lib/libgstreamer-1.0.so.0
#15 0x0000fffff78e65bc in ?? () from /lib/libgstreamer-1.0.so.0
#16 0x0000fffff78ee6f4 in gst_pad_push () from /lib/libgstreamer-1.0.so.0
#17 0x0000ffffd86a6cac in ?? () from /lib/gstreamer-1.0/libgstvideorate.so
#18 0x0000fffff7abaeb0 in ?? () from /lib/libgstbase-1.0.so.0
#19 0x0000fffff7aba7fc in ?? () from /lib/libgstbase-1.0.so.0
#20 0x0000fffff78e43a8 in ?? () from /lib/libgstreamer-1.0.so.0
#21 0x0000fffff78e65bc in ?? () from /lib/libgstreamer-1.0.so.0
#22 0x0000fffff78ee6f4 in gst_pad_push () from /lib/libgstreamer-1.0.so.0
#23 0x0000fffff4218118 in ?? () from /lib/gstreamer-1.0/libgstcoreelements.so
#24 0x0000fffff7923390 in ?? () from /lib/libgstreamer-1.0.so.0
#25 0x0000fffff749e954 in ?? () from /lib/libglib-2.0.so.0
#26 0x0000fffff749dc68 in ?? () from /lib/libglib-2.0.so.0
#27 0x0000fffff72b0d14 in ?? () from /lib/libc.so.6
#28 0x0000fffff731364c in ?? () from /lib/libc.so.6
Certain combinations of bitrates, gop size and complexity seem to exarcerbate this.
I would like to fix the segfault at source so I need the source code for the following library:
Is this available anywhere?
296 次查看
Bio_TICFSL
The source code is proprietary you need to check with professional services if you can obtain the source code.
https://www.nxp.com/support/support/nxp-engineering-services/professional-support-for-processors-and...
%3CLINGO-SUB%20id%3D%22lingo-sub-2193434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%20vpu%20%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%9AVC8000e%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%86%E6%AE%B5%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E0x0000ffffd83ba748%20in%20VCEncStrmEncodeExt%20()%20from%20%2Flib%2Flibhantro_vc8000e.so.1%20(gdb)%20bt%3CBR%20%2F%3E%230%200x0000ffffd83ba748%20in%20VCEncStrmEncodeExt%20()%20from%20%2Flib%2Flibhantro_vc8000e.so.1%20warning%3A%20could%20not%20convert%20'main'%20from%20the%20host%20encoding%20(ANSI_X3.4-1968)%20to%20UTF-32%E3%80%82%E8%BF%99%E9%80%9A%E5%B8%B8%E4%B8%8D%E4%BC%9A%E5%8F%91%E7%94%9F%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BA%A4%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E3%80%82%3CBR%20%2F%3E%231%200x0000ffffd83bdc00%20%E5%9C%A8%20VCEncStrmEncode%20()%20%E4%B8%AD%EF%BC%8C%E6%9D%A5%E8%87%AA%20%2Flib%2Flibhantro_vc8000e.so.1%3CBR%20%2F%3E%232%200x0000ffffd84e771c%20%E5%9C%A8%20VCEnc_encoder_encode%20()%20%E4%B8%AD%EF%BC%8C%E6%9D%A5%E8%87%AA%20%2Flib%2Flibfslvpuwrap.so.3%3CBR%20%2F%3E%233%200x0000ffffd84e8124%20%E5%9C%A8%20VPU_EncEncodeFrame%20()%20%E4%B8%AD%EF%BC%8C%E6%9D%A5%E8%87%AA%20%2Flib%2Flibfslvpuwrap.so.3%3CBR%20%2F%3E%234%200x0000ffffd85a2af4%20in%20%3F%3F%20()%20from%20%2Flib%2Fgstreamer-1.0%2Flibgstvpu.so%3CBR%20%2F%3E%235%200x0000fffff65bf9b8%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstvideo-1.0.so.0%3CBR%20%2F%3E%236%200x0000fffff78e43a8%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%237%200x0000fffff78e65bc%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%238%200x0000fffff78ee6f4%20in%20gst_pad_push%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%239%200x0000fffff7aba87c%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstbase-1.0.so.0%3CBR%20%2F%3E%2310%200x0000fffff78e43a8%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2311%200x0000fffff78e65bc%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2312%200x0000fffff78ee6f4%20in%20gst_pad_push%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2313%200x0000fffff7aba87c%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstbase-1.0.so.0%3CBR%20%2F%3E%2314%200x0000fffff78e43a8%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2315%200x0000fffff78e65bc%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2316%200x0000fffff78ee6f4%20in%20gst_pad_push%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2317%200x0000ffffd86a6cac%20in%20%3F%3F%20()%20from%20%2Flib%2Fgstreamer-1.0%2Flibgstvideorate.so%3CBR%20%2F%3E%2318%200x0000fffff7abaeb0%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstbase-1.0.so.0%3CBR%20%2F%3E%2319%200x0000fffff7aba7fc%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstbase-1.0.so.0%3CBR%20%2F%3E%2320%200x0000fffff78e43a8%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2321%200x0000fffff78e65bc%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2322%200x0000fffff78ee6f4%20in%20gst_pad_push%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2323%200x0000fffff4218118%20in%20%3F%3F%20()%20from%20%2Flib%2Fgstreamer-1.0%2Flibgstcoreelements.so%3CBR%20%2F%3E%2324%200x0000fffff7923390%20in%20%3F%3F%20()%20from%20%2Flib%2Flibgstreamer-1.0.so.0%3CBR%20%2F%3E%2325%200x0000fffff749e954%20in%20%3F%3F%20()%20from%20%2Flib%2Flibglib-2.0.so.0%3CBR%20%2F%3E%2326%200x0000fffff749dc68%20in%20%3F%3F%20()%20from%20%2Flib%2Flibglib-2.0.so.0%3CBR%20%2F%3E%2327%200x0000fffff72b0d14%20in%20%3F%3F%20()%20from%20%2Flib%2Flibc.so.6%3C%2FSPAN%3E%20%2328%3CSPAN%3E%200x0000fffff731364c%20in%20%3F%3F%20()%20from%20%2Flib%2Flibc.so.6%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%9F%90%E4%BA%9B%E6%AF%94%E7%89%B9%E7%8E%87%E3%80%81gop%20%E5%A4%A7%E5%B0%8F%E5%92%8C%E5%A4%8D%E6%9D%82%E6%80%A7%E7%9A%84%E7%BB%84%E5%90%88%E4%BC%BC%E4%B9%8E%E4%BC%9A%E4%BD%BF%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%8F%98%E5%BE%97%E6%9B%B4%E5%8A%A0%E4%B8%A5%E9%87%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BB%8E%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%8A%E4%BF%AE%E5%A4%8D%20segfault%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E9%9C%80%E8%A6%81%E4%BB%A5%E4%B8%8B%E5%BA%93%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3Elibhantro_vc8000e.so.1%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E4%B9%B0%E5%88%B0%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2193434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%96%91%E4%BC%BC%E8%BD%AF%E4%BB%B6%E7%BC%BA%E9%99%B7%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20vpu%20encoder%3A%20vc8000e%3A%20driver%20segmentation%20fault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%BA%90%E4%BB%A3%E7%A0%81%E6%98%AF%E4%B8%93%E6%9C%89%E7%9A%84%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%90%91%E4%B8%93%E4%B8%9A%E6%9C%8D%E5%8A%A1%E6%9C%BA%E6%9E%84%E5%92%A8%E8%AF%A2%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsupport%2Fnxp-engineering-services%2Fprofessional-support-for-processors-and-microcontrollers%3APREMIUM-SUPPORT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fsupport%2Fsupport%2Fnxp-engineering-services%2Fprofessional-support-for-processors-and-microcontrollers%3APREMIUM-SUPPORT%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
