imx8mp power consumption test
Ginzinger_sst
Hello Community,
I try to reproduce the power consumption test for VPU.
To get the same results, i need the same files for test.
Are the files used in the testcases of consumption test available?
The specific file I search for is: HEVC_1920x1080_29.97fps_AACLC_44.1Khz_2ch.mkv
Thanks in advance.
Simon
Rita_Wang
You can follow our AN in the attachment for you
Ginzinger_sst
I know this AN, but there is no information about the used video file.
Rita_Wang
Yes, you can use it, details you can follow section 4 Use cases and measurement results.
Ginzinger_sst
The AN does not work for me!
With this AN there come up some questions:
Where can i get the video file (HEVC_1920x1080_29.97fps_AACLC_44.1Khz_2ch.mkv)?video.png
Both are neither included in the image nor are there sources.
