imx8mp i2c data transfer is slow
1,385 次查看
tamo2
We are developing a product based on imx8mp processor.  It loads a program to a Lattice CrossLink FPGA via i2c bus.  The FPGA binary data size (.ied file) is 149KB and it takes about ~8.3 sec with 400 KHz i2c clock.  The loading program uses i2c's Block read/write mode.
Our existing product uses Snapdragon 820 processor, and it uses the same FPGA and loading the same binary data takes ~5.2 sec via i2c with 400 KHz clock.
Is there anything we can do to speed up the i2c data transfer?  We used yocto/hardnott and also kirkstone, and both were slow.  d
tamo2
标记 (2)
1,353 次查看
Zhiming_Liu
This is an errata of i2c spec on i.MX8MP:
1,354 次查看
Zhiming_Liu
