I have successfully loaded the driver and sent an output command(
gst-launch-1.0 -e v4l2src device=/dev/video2 ! filesink location=1.raw
) to obtain the image. This part of the image will be printed. What is the error?
Hello @lei11 ,
I hope you are doing well.
->To obtain the image please run the below command.
gst-launch v4l2src num-buffers=1 ! jpegenc ! filesink location=/tmp/test.jpg
Thanks & Regards,
Sanket Parekh
