Dear all,
target : imx8mp
kernel source : Linux version 5.10.72
I can't find the cause of delay. What can I do for this ?
1. Issue (kernel booting takes 30sec more than normal)
Mar 24 10:26:01 imx8mp-lpddr4-evk syslogd[679]: syslogd v2.2.2: restart.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Linux version 5.10.72-0.1.6+g548fe74af (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1.20210209) #1 SMP PREEMPT Tue Jul 19 03:38:26 UTC 2022
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: efi: UEFI not found.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Reserved memory: created CMA memory pool at 0x0000000074000000, size 512 MiB
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Reserved memory: created DMA memory pool at 0x0000000059f00000, size 1 MiB
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: OF: reserved mem: initialized node vdev0buffer@59f00000, compatible id shared-dma-pool
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NUMA: No NUMA configuration found
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NUMA: NODE_DATA [mem 0xbfc59700-0xbfc5bfff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Zone ranges:
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA [mem 0x0000000040000000-0x00000000bfffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA32 empty
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Normal empty
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Movable zone start for each node
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Early memory node ranges
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: node 0: [mem 0x0000000040000000-0x0000000055ffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: node 0: [mem 0x0000000058000000-0x0000000059ffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: node 0: [mem 0x000000005a000000-0x00000000943fffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: node 0: [mem 0x0000000094400000-0x00000000a43fffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: node 0: [mem 0x00000000a4400000-0x00000000bfffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: On node 0 totalpages: 516096
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA zone: 8192 pages used for memmap
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA zone: 0 pages reserved
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA zone: 516096 pages, LIFO batch:63
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: psci: probing for conduit method from DT.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: psci: PSCIv1.1 detected in firmware.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: psci: Using standard PSCI v0.2 function IDs
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: psci: Trusted OS migration not required
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: psci: SMC Calling Convention v1.2
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: percpu: Embedded 23 pages/cpu s56280 r8192 d29736 u94208
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pcpu-alloc: s56280 r8192 d29736 u94208 alloc=23*4096
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Detected VIPT I-cache on CPU0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU features: detected: ARM erratum 845719
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU features: detected: GIC system register CPU interface
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Built 1 zonelists, mobility grouping on. Total pages: 507904
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Policy zone: DMA
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk2p2 rootwait rw
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Memory: 1170420K/2064384K available (15808K kernel code, 1390K rwdata, 6080K rodata, 10752K init, 538K bss, 369676K reserved, 524288K cma-reserved)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: Preemptible hierarchical RCU implementation.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: RCU event tracing is enabled.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Trampoline variant of Tasks RCU enabled.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: GIC: Using split EOI/Deactivate mode
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: 160 SPIs implemented
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: 0 Extended SPIs implemented
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: Distributor has no Range Selector support
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: 16 PPIs implemented
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: ITS: No ITS available, not enabling LPIs
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: random: get_random_bytes called from start_kernel+0x320/0x4e4 with crng_init=0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: arch_timer: cp15 timer(s) running at 8.00MHz (phys).
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Console: colour dummy device 80x25
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pid_max: default: 32768 minimum: 301
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: LSM: Security Framework initializing
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: rcu: Hierarchical SRCU implementation.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: EFI services will not be available.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: smp: Bringing up secondary CPUs ...
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Detected VIPT I-cache on CPU1
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Detected VIPT I-cache on CPU2
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Detected VIPT I-cache on CPU3
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: smp: Brought up 1 node, 4 CPUs
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: SMP: Total of 4 processors activated.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU features: detected: 32-bit EL0 Support
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU features: detected: CRC32 instructions
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU features: detected: 32-bit EL1 Support
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: CPU: All CPU(s) started at EL2
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: alternatives: patching kernel code
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: devtmpfs: initialized
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: KASLR disabled due to lack of seed
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pinctrl core: initialized pinctrl subsystem
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMI not present or invalid.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NET: Registered protocol family 16
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: audit: initializing netlink subsys (disabled)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: thermal_sys: Registered thermal governor 'step_wise'
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: thermal_sys: Registered thermal governor 'power_allocator'
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: cpuidle: using governor menu
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: ASID allocator initialised with 65536 entries
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Serial: AMBA PL011 UART driver
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: imx mu driver is registered.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: imx rpmsg driver is registered.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: cryptd: max_cpu_qlen set to 1000
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: ACPI: Interpreter disabled.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: iommu: Default domain type: Translated
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: SCSI subsystem initialized
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usbfs
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver hub
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: usbcore: registered new device driver usb
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: mc: Linux media interface: v0.10
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: videodev: Linux video capture interface: v2.00
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pps_core: LinuxPPS API ver. 1 registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: PTP clock support registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: EDAC MC: Ver: 3.0.0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Advanced Linux Sound Architecture Driver Initialized.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: clocksource: Switched to clocksource arch_sys_counter
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: VFS: Disk quotas dquot_6.6.0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: pnp: PnP ACPI: disabled
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NET: Registered protocol family 2
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: TCP: Hash tables configured (established 16384 bind 16384)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: RPC: Registered named UNIX socket transport module.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: RPC: Registered udp transport module.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: RPC: Registered tcp transport module.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: IPA Size Limit: 40 bits
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: GICv3: no GICV resource entry
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: disabling GICv2 emulation
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: GIC system register CPU interface enabled
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: vgic interrupt IRQ9
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: kvm [1]: Hyp mode initialized successfully
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Initialise system trusted keyrings
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: workingset: timestamp_bits=42 max_order=19 bucket_order=0
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: NFS: Registering the id_resolver key type
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Key type id_resolver registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Key type id_legacy registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: 9p: Installing v9fs 9p2000 file system support
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Key type asymmetric registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Asymmetric key parser 'x509' registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: io scheduler mq-deadline registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: io scheduler kyber registered
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: -517
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: EINJ: ACPI disabled.
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: mxs-dma 33000000.dma-apbh: initialized
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Bus freq driver module loaded
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 31, base_baud = 1500000) is a IMX
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 32, base_baud = 1500000) is a IMX
Mar 24 10:25:13 imx8mp-lpddr4-evk kernel: 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 33, base_baud = 1500000) is a IMX
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: printk: console [ttymxc1] enabled
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-hdmi-pavi 32fc4000.hdmi-pai-pvi: No pvi clock get
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: loop: module loaded
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: libphy: Fixed MDIO Bus: probed
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: tun: Universal TUN/TAP device driver, 1.6
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver r8152
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver asix
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver ax88179_178a
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver cdc_ether
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver net1080
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver cdc_subset
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver zaurus
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver cdc_ncm
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: VFIO - User Level meta-driver version: 0.3
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: dwc3 38100000.dwc3: Configuration mismatch. dr_mode forced to gadget
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: ehci-platform: EHCI generic platform driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: ohci-platform: OHCI generic platform driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver uas
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usb-storage
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usbserial_generic
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for generic
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver ftdi_sio
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for FTDI USB Serial Device
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usb_serial_simple
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for carelink
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for zio
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for funsoft
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for flashloader
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for google
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for libtransistor
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for vivopay
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for moto_modem
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for motorola_tetra
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for novatel_gps
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for hp4x
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for suunto
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbserial: USB Serial support registered for siemens_mpi
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usb_ehset_test
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:00 UTC (0)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: i2c /dev entries driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver uvcvideo
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: USB Video Class driver (1.1.1)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: EDAC MC: ECC not enabled
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: sdhci: Secure Digital Host Controller Interface driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: sdhci: Copyright(c) Pierre Ossman
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: Synopsys Designware Multimedia Card Interface Driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: sdhci-esdhc-imx 30b60000.mmc: voltage-ranges unspecified
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: ledtrig-cpu: registered to indicate activity on CPUs
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbcore: registered new interface driver usbhid
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: usbhid: USB HID core driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, using dummy regulator
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-dsp-rproc 3b6e8000.dsp: Failed to get clock dsp_clk1
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-dsp-rproc 3b6e8000.dsp: failed on imx_dsp_rproc_clk_get
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: remoteproc remoteproc0: releasing imx-dsp-rproc
[E]3<BS_LOG><BMI2XY_init><290>BMI2XY_init
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: optee: probing for conduit method.
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: optee: revision 3.15 (c939619d)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: optee: dynamic shared memory is enabled
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: optee: initialized driver
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: Galcore version 6.4.3.p2.336687
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmc2: new HS400 Enhanced strobe MMC card at address 0001
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmcblk2: mmc2:0001 DG4008 7.28 GiB
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB, chardev (235:0)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: mmcblk2: p1 p2 p3
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: hantrodec 0 : module inserted. Major = 234
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: hantrodec 1 : module inserted. Major = 234
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: hantroenc: HW at base <0000000038320000> with ID <0x80006200>
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: hx280enc: module inserted. Major <511>
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: fsl-sai 30c20000.sai: failed to get bus clock: -517
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: fsl-micfil-dai 30ca0000.micfil: failed to get core clock: -517
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: fsl,imx8mp-audio-xcvr 30cc0000.xcvr: failed to get ipg clock
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: fsl-aud2htx 30cb0000.aud2htx: failed to get mem clock
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-micfil sound-micfil: snd_soc_register_card failed (-517)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: NET: Registered protocol family 26
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: NET: Registered protocol family 10
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: Segment Routing with IPv6
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: NET: Registered protocol family 17
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: 8021q: 802.1Q VLAN Support v1.8
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: lib80211: common routines for IEEE802.11 drivers
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: lib80211_crypt: registered algorithm 'NULL'
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: lib80211_crypt: registered algorithm 'WEP'
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: lib80211_crypt: registered algorithm 'CCMP'
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: lib80211_crypt: registered algorithm 'TKIP'
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: 9pnet: Installing 9P2000 support
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: tsn generic netlink module v1 init...
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: Key type dns_resolver registered
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: registered taskstats version 1
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: Loading compiled-in X.509 certificates
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: nxp-pca9450 0-0025: pca9450bc probed.
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: i2c i2c-0: IMX I2C adapter registered
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: i2c i2c-1: IMX I2C adapter registered
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu probe start
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv-mpu-iio-i2c 2-0068: supply inven,vdd_ana not found, using dummy regulator
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv-mpu-iio-i2c 2-0068: supply inven,vcc_i2c not found, using dummy regulator
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu whoami ok : 0x67
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu check whoami end
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu_probe: power on here.
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu_probe: power on.
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: whoami= 67
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: random: fast init done
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu_initialize: initialize result is 0....
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: ddrc freq set to low bus mode
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: wakeup_source is created successfully
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv-mpu-iio-i2c 2-0068: icm43600 ma-kernel-9.3.3-test2 is ready to go!
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: inv_mpu: Data read from FIFO
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: irq: type mismatch, failed to map hwirq-7 for gpio@30200000!
[D]7<BS_LOG><bmi2xy_i2c_probe><201>entrance
[I]6<BS_LOG><bmi2xy_probe><3206>function entrance
[E]3<BS_LOG><bmi2xy_probe><3231>chip_id check nok: 0x9
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: i2c i2c-2: IMX I2C adapter registered
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: -517
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: SoC: i.MX8MP revision 1.1
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: ddrc freq set to high bus mode
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: dwc3 38100000.dwc3: Configuration mismatch. dr_mode forced to gadget
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002021810010
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: irq 67, io mem 0x38200000
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: hub 1-0:1.0: USB hub found
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: hub 1-0:1.0: 1 port detected
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: hub 2-0:1.0: USB hub found
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: hub 2-0:1.0: 1 port detected
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, using dummy regulator
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: isi-capture 32e00000.isi:cap_device: deferring 32e00000.isi:cap_device device registration
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: remoteproc remoteproc0: imx-dsp-rproc is available
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: fsl-micfil-dai 30ca0000.micfil: GET IRQ: 44
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: fsl-micfil-dai 30ca0000.micfil: GET IRQ: 45
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: fsl-micfil-dai 30ca0000.micfil: GET IRQ: 46
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: fsl-micfil-dai 30ca0000.micfil: GET IRQ: 47
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: Console: switching to colour frame buffer device 480x135
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: debugfs: File 'Playback' in directory 'dapm' already present!
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: debugfs: File 'Capture' in directory 'dapm' already present!
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card3/input1
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: ALSA device list:
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: #0: imx-audio-xcvr
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: #1: imx-audio-micfil
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: #2: bt-sco-audio
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: #3: audio-hdmi
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: EXT4-fs (mmcblk2p2): recovery complete
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: devtmpfs: mounted
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: Freeing unused kernel memory: 10752K
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: Run /sbin/init as init process
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: with arguments:
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: /sbin/init
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: with environment:
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: HOME=/
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: TERM=linux
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd[1]: System time before build time, advancing clock.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd[1]: systemd 247 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd[1]: Detected architecture arm64.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd[1]: Set hostname to <imx8mp-lpddr4-evk>.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/rc.local' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/start_app.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/check_ai_test.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[195]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Queued start job for default target Graphical Interface.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: random: systemd: uninitialized urandom read (16 bytes read)
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Created slice system-getty.slice.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Created slice system-modprobe.slice.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Created slice system-serial\x2dgetty.slice.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Created slice system-systemd\x2dfsck.slice.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Created slice User and Session Slice.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Reached target Paths.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Reached target Remote File Systems.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Reached target Slices.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Reached target Swap.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on RPCbind Server Activation Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Reached target RPC Port Mapper.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on Syslog Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on initctl Compatibility Named Pipe.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on Journal Audit Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on Journal Socket (/dev/log).
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on Journal Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on Network Service Netlink Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on udev Control Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on udev Kernel Socket.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Listening on User Database Manager Socket.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Huge Pages File System...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting POSIX Message Queue File System...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Kernel Debug File System...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Temporary Directory (/tmp)...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Create list of static device nodes for the current kernel...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Load Kernel Module configfs...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Load Kernel Module drm...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Load Kernel Module fuse...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: fuse: init (API version 7.32)
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting RPC Bind...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Journal Service...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Apply Kernel Variables...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Coldplug All udev Devices...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Started RPC Bind.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd[1]: Started Journal Service.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd-journald[208]: Received client request to flush runtime journal.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd-journald[208]: File /var/log/journal/28e2d3789c4e4380a153c62ee29d48a6/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam-snvs 30370000.caam-snvs: violation handlers armed - init state
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: job rings = 1, qi = 0
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: mx8-img-md: Registered mxc_isi.0.capture as /dev/video3
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: mx8-img-md: Can't find i2c client device for ov5640_mipi@3c
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: mx8-img-md: Unregistered all entities
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam algorithms registered in /proc/crypto
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: registering rng-caam
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: Device caam-keygen registered
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: random: crng init done
Mar 24 10:25:19 imx8mp-lpddr4-evk kernel: random: 7 urandom warning(s) missed due to ratelimiting
Mar 24 10:25:46 imx8mp-lpddr4-evk kernel: VSD_3V3: disabling
Mar 24 10:25:51 imx8mp-lpddr4-evk kernel: imx-sdma 30e10000.dma-controller: firmware found.
Mar 24 10:25:51 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: firmware found.
Mar 24 10:25:51 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: loaded firmware 4.6
Mar 24 10:25:52 imx8mp-lpddr4-evk kernel: usb 1-1: new high-speed USB device number 2 using xhci-hcd
2. normal booting time
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv-mpu-iio-i2c 2-0068: supply inven,vcc_i2c not found, using dummy regulator
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu whoami ok : 0x67
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu check whoami end
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu_probe: power on here.
Mar 24 10:25:14 imx8mp-lpddr4-evk kernel: inv_mpu: inv_mpu_probe: power on.
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: SoC: i.MX8MP revision 1.1
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
Mar 24 10:25:15 imx8mp-lpddr4-evk kernel: imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/rc.local' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:16 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/single' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/start_app.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/check_ai_test.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd-sysv-generator[153]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Huge Pages File System...
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting POSIX Message Queue File System...
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Kernel Debug File System...
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Mounting Temporary Directory (/tmp)...
Mar 24 10:25:17 imx8mp-lpddr4-evk kernel: systemd[1]: Starting Create list of static device nodes for the current kernel...
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd-journald[165]: Received client request to flush runtime journal.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: systemd-journald[165]: File /var/log/journal/28e2d3789c4e4380a153c62ee29d48a6/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: caam-snvs 30370000.caam-snvs: violation handlers armed - init state
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
Mar 24 10:25:18 imx8mp-lpddr4-evk kernel: caam 30900000.crypto: job rings = 1, qi = 0
Mar 24 10:25:20 imx8mp-lpddr4-evk kernel: imx-sdma 30e10000.dma-controller: firmware found.
Mar 24 10:25:20 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: firmware found.
Mar 24 10:25:20 imx8mp-lpddr4-evk kernel: imx-sdma 30bd0000.dma-controller: loaded firmware 4.6
Mar 24 10:25:21 imx8mp-lpddr4-evk dbus-daemon[450]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 24 10:25:21 imx8mp-lpddr4-evk avahi-daemon[485]: Found user 'avahi' (UID 998) and group 'avahi' (GID 998).
Mar 24 10:25:21 imx8mp-lpddr4-evk avahi-daemon[485]: Successfully dropped root privileges.
Mar 24 10:25:21 imx8mp-lpddr4-evk avahi-daemon[485]: avahi-daemon 0.8 starting up
