imx8mp OpenGL without display
3,881 次查看
KobusGvid
Is there a way to get OpenGL to work while running in headless mode (without connecting a display)?
I'm running a imx8mp with an fsl-xwayland based image. I know PGU et-al are configured correctly in my devicetree as I can get a display working when connected. If I try to run a simple gstreamer pipeline like this:
gst-launch-1.0 videotestsrc ! video/x-raw,format=NV12,width=1920,height=1080 ! queue ! glupload ! glcolorconvert ! gldownload ! video/x-raw,format=RGB ! queue ! fakesink
I get the following error:
Got context from element 'gldownloadelement0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayWayland\)\ gldisplaywayland0";
ERROR: from element /GstPipeline:pipeline0/GstGLUploadElement:gluploadelement0: Failed to perform a wayland roundtrip
My system is set up to use remote-x server via SSH, but even then I get nothing.
Is there some XDG variable to set? or is there a way to get a fake framebuffer or something?
7 回复数
2,906 次查看
KobusGvid
So to answer my own question for anyone else coming here:
I could get the GPU working and perform gstreamer glupload/glshader etc commands by:
- Loading VKMS kernel module for a virtual display
- setting renderer=gl and disabling "g2d" in westom.ini.
With these chnages weston starts up, and I have opngl commands.
Interestingly, I was able to verify that OpenCL works fine even when weston is offline. Unfortunately the performance of anything in OpenCV using UMat's and the T-API didn't improve vs a normal matrix. It does seem to be much faster than a simple element wise multiplication for example in C, so that's probably down to the ARM-Neon acceleration in OpenCV.
3,868 次查看
Bio_TICFSL
Please try this again:
$ DISPLAY=:0 gst-launch-1.0 videotestsrc ! video/x-raw(memory:NVMM),width=1920,height=1080, 'video/x-raw,width=1920, height=1080 ! xvimagesink sync=0
3,864 次查看
KobusGvid
I get the following:
WARNING: erroneous pipeline: could not link videotestsrc0 to xvimagesink0, neither element can handle caps video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080
Am I missing a kernel config?
3,860 次查看
Bio_TICFSL
That's is not an error, your system should be running without display.
3,824 次查看
KobusGvid
so does they teach us anything? Do you have any other ideas what could be causing the issue?
标记 (1)
3,690 次查看
ugurkurt
Hi there, I encountered the same issue on my i.MX8M board. What worked for me was adding the weston, weston-init, and weston-xwayland packages to my Yocto image, which completely resolved the display errors. Additionally, I set the XDG_RUNTIME_DIR environment variable using the following command:
export XDG_RUNTIME_DIR=/run/user/$(id -u)
I hope this helps you resolve your issue as well!
3,678 次查看
KobusGvid
thanks ugurkur, but that doesn't seem to help.
If I check `echo $XDG_RUNTIME_DIR` I get "/run/user/0", so that seems fine.
And according to my manifest I have all the packages you mentioned. Still I cant get OpenGL to work.
%3CLINGO-SUB%20id%3D%22lingo-sub-2047350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8mp%20OpenGL%20%E6%97%A0%E6%98%BE%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E8%AE%A9%20OpenGL%20%E5%9C%A8%E6%97%A0%E5%A4%B4%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%EF%BC%88%E4%B8%8D%E8%BF%9E%E6%8E%A5%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%89%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%20fsl-xwayland%20%E6%98%A0%E5%83%8F%E7%9A%84%20imx8mp%E3%80%82%E6%88%91%E7%9F%A5%E9%81%93%20PGU%20%E7%AD%89%E8%AE%BE%E5%A4%87%E5%9C%A8%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%9E%E6%8E%A5%E5%90%8E%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E6%98%BE%E7%A4%BA%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E5%83%8F%E8%BF%99%E6%A0%B7%E8%BF%90%E8%A1%8C%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20gstreamer%20%E7%AE%A1%E9%81%93%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Egst-launch-1.0%20videotestsrc%20!%20video%2Fx-raw%2Cformat%3DNV12%2Cwidth%3D1920%2Cheight%3D1080%20!%20queue%20!%20glupload%20!%20glcolorconvert%20!%20gldownload%20!%20video%2Fx-raw%2Cformat%3DRGB%20!%20queue%20!%20fakesink%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%20%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EGot%20context%20from%20element%20'gldownloadelement0'%3A%20gst.gl.GLDisplay%3Dcontext%2C%20gst.gl.GLDisplay%3D(GstGLDisplay)%22%5C(GstGLDisplayWayland%5C)%5C%20gldisplaywayland0%22%3B%0AERROR%3A%20from%20element%20%2FGstPipeline%3Apipeline0%2FGstGLUploadElement%3Agluploadelement0%3A%20Failed%20to%20perform%20a%20wayland%20roundtrip%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E7%B3%BB%E7%BB%9F%E5%AE%89%E8%A3%85%E4%B8%BA%E9%80%9A%E8%BF%87%20SSH%20%E4%BD%BF%E7%94%A8%20remote-x%20%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E4%BD%86%E5%8D%B3%E4%BE%BF%E5%A6%82%E6%AD%A4%EF%BC%8C%E6%88%91%E4%B9%9F%E4%B8%80%E6%97%A0%E6%89%80%E8%8E%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%20XDG%20%E5%8F%98%E9%87%8F%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2047350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9B%BE%E5%BD%A2%E4%B8%8E%E6%98%BE%E7%A4%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149293%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E8%A6%81%E5%9B%9E%E7%AD%94%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BE%9B%E5%85%B6%E4%BB%96%E6%9D%A5%E8%BF%99%E9%87%8C%E7%9A%84%E4%BA%BA%E5%8F%82%E8%80%83%EF%BC%9A%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E6%B3%95%E8%AE%A9%20GPU%20%E5%B7%A5%E4%BD%9C%E5%B9%B6%E6%89%A7%E8%A1%8C%20gstreamer%20glupload%2Fglshader%20%E7%AD%89%E5%91%BD%E4%BB%A4%EF%BC%9A%3CBR%20%2F%3E-%20%E4%B8%BA%E8%99%9A%E6%8B%9F%E6%98%BE%E7%A4%BA%E5%99%A8%E5%8A%A0%E8%BD%BD%20VKMS%20%E5%86%85%E6%A0%B8%E6%A8%A1%E5%9D%97%3C%2FP%3E%3CP%3E-%20%E5%9C%A8%20westom.ini%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20renderer%3Dgl%20%E5%B9%B6%E7%A6%81%E7%94%A8%22g2d%22%20%E3%80%82%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%BB%8F%E8%BF%87%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%90%8E%EF%BC%8CWESTON%20%E5%90%AF%E5%8A%A8%E4%BA%86%EF%BC%8C%E6%88%91%E4%B9%9F%E6%9C%89%E4%BA%86%20opngl%20%E5%91%BD%E4%BB%A4%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%9C%89%E8%B6%A3%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E9%AA%8C%E8%AF%81%E4%BA%86%20OpenCL%20%E5%9C%A8%20weston%20%E7%A6%BB%E7%BA%BF%E6%97%B6%E4%B9%9F%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E4%B8%8E%E6%99%AE%E9%80%9A%E7%9F%A9%E9%98%B5%E7%9B%B8%E6%AF%94%EF%BC%8COpenCV%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20UMat%20%E5%92%8C%20T-API%20%E7%9A%84%E6%80%A7%E8%83%BD%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%8F%90%E9%AB%98%E3%80%82%E5%AE%83%E4%BC%BC%E4%B9%8E%E7%A1%AE%E5%AE%9E%E6%AF%94%E7%AE%80%E5%8D%95%E7%9A%84%E9%80%90%E5%85%83%E7%B4%A0%E4%B9%98%E6%B3%95%E5%BF%AB%E5%BE%97%E5%A4%9A%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%9C%A8%20C%20%E4%B8%AD%EF%BC%8C%E6%89%80%E4%BB%A5%E8%BF%99%E5%8F%AF%E8%83%BD%E8%A6%81%E5%BD%92%E5%9B%A0%E4%BA%8E%20OpenCV%20%E4%B8%AD%E7%9A%84%20Arm-neon%20%E5%8A%A0%E9%80%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%20ugurkur%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%B2%A1%E4%BB%80%E4%B9%88%E7%94%A8%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E6%A3%80%E6%9F%A5%20%60echo%20%24XDG_RUNTIME_DIR%60%20%EF%BC%8C%E4%BC%9A%E5%BE%97%E5%88%B0%22%2Frun%2Fuser%2F0%22%20%EF%BC%8C%E6%89%80%E4%BB%A5%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E6%B8%85%E5%8D%95%EF%BC%8C%E6%88%91%E6%9C%89%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E6%89%80%E6%9C%89%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%AE%A9%20OpenGL%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20i.MX8M%20%E6%9D%BF%E4%B8%8A%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E5%AF%B9%E6%88%91%E6%9C%89%E7%94%A8%E7%9A%84%E6%98%AF%E5%B0%86%20%3CSTRONG%3Eweston%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3Eweston-init%3C%2FSTRONG%3E%20%E5%92%8C%20%3CSTRONG%3Eweston-xwayland%3C%2FSTRONG%3E%20%E4%BB%A3%E7%A0%81%E5%8C%85%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%20Yocto%20%E5%9B%BE%E5%83%8F%E4%B8%AD%EF%BC%8C%E8%BF%99%E5%AE%8C%E5%85%A8%E8%A7%A3%E5%86%B3%E4%BA%86%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%AE%BE%E7%BD%AE%E4%BA%86%3CSTRONG%3E%20XDG_RUNTIME_DIR%3C%2FSTRONG%3E%20%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%20export%3C%2FSPAN%3E%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F%24(%3CSPAN%20class%3D%22%22%3E%20id%3C%2FSPAN%3E%20-u)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%B9%9F%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%82%A8%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%AE%83%E4%BB%AC%E8%83%BD%E6%95%99%E7%BB%99%E6%88%91%E4%BB%AC%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%E6%82%A8%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E5%85%B6%E4%BB%96%E6%83%B3%E6%B3%95%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%A0%E7%9A%84%E7%B3%BB%E7%BB%9F%E5%BA%94%E8%AF%A5%E5%9C%A8%E6%97%A0%E6%98%BE%E7%A4%BA%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047490%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EWARNING%3A%20erroneous%20pipeline%3A%20could%20not%20link%20videotestsrc0%20to%20xvimagesink0%2C%20neither%20element%20can%20handle%20caps%20video%2Fx-raw(memory%3ANVMM)%2C%20width%3D(int)1920%2C%20height%3D(int)1080%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E6%BC%8F%E6%8E%89%E4%BA%86%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx8mp%20OpenGL%20without%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%24%20DISPLAY%3D%3A0%20gst-%E7%94%A8%E4%B8%8A%E5%B8%82%EF%BC%8C%E4%B8%8D%E7%94%A8%E5%8F%91%E5%B8%83-1.0videotestsrc%20%EF%BC%81video%2Fx-raw(memory%3ANVMM)%2Cwidth%3D1920%2Cheight%3D1080%2C%20'video%2Fx-raw%2Cwidth%3D1920%2Cheight%3D1080%20%EF%BC%81xvimagesink%20sync%3D0%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
