imx8mp DSI LCD color adjustment
malik_cisse
Senior Contributor I
The imx8mp DSI LCD image appears to be slightly Red and I would like to do some color adjustments to correct HUE.
Any idea how to do that in the driver?
The only promising info I found so far in the RM is pointing to LCDIF (the RM shows that color conversion ALU can be configured via CPU registers) but I am not sure how to set this.
Thank you
malik_cisse
Hi Joseph,
Interesting pointer as the questioner has exact same issue.
However the feedback proposal there does not really help unfortunately.
JosephAtNXP
Yes, I think that we can save the part that states that there is a color matrix and we can modify it by writing to the registers you pointed out CSC0_COEF [0..5].
But the register adjustment is up to you, due to you would need to perform the operation to get the value that should be assigned to the Red Value.
JosephAtNXP
This is a helpful resource that you ma want to check
IMX8MP LVDS LCD contrast and colour saturation con... - NXP Community
Thank you!
