imx8mn mipi
imx8mn mipi
steven_zhang
Contributor V
how to change the MIPI display resolution from 1920X1080 to 1280x800 with a imx8mn demo board ,the
 OS is linux .
Bio_TICFSL
Hello Steven,
You need to change the dtb and the MIPI driver for that resolution, the compile the dtb and bsp
zoutao98
Can I do this by modifying environment variables?I just want to modify the resolution through a simple way.
Like ~$ set env ...
Bio_TICFSL
No, you need modify the parameter of the dtb.
