imx8mmini uuu
imx8mmini uuu
jieh朱
I am using imx8mmini
The programming method is uuu
I read uuu.pdf
but When I build
what should I do?
joanxie
do you want to build UUU? you can download uuu tools, then use it directly
jieh朱
Thank you, I can now burn it with uuu.exe.
But after burning, the startup will restart continuously.
joanxie
how did you burn and what bsp version did you burn
jieh朱
Thank you for your reply The restart has been resolved because type-C is connected to the PC. Power is not enough, I just switched to an adapter.
joanxie
ok, tell me how did you program the image to your board, what command do you use, and what image version do you use? because I test latest version, couldn't reproduce your issue on my imx8MM board
jieh朱
Hello, the image above I am using mfgtools-uuu_1.2.91 and visual studio 2019
I am currently using uuu.exe. I can write rootfs.sdcard to uboot, image and rootfs to emmc, but how to write uboot, image and rootfs to emmc separately. Because my git clone uboot and image source have been compiled. But don't know how to write separately
joanxie
if  you need to program uboot and kernel to EMMC, you can refer to the example_kernel_emmc.uuu which under folder named samples, put your own demo image name in the uuu file, then use the command like "uuu.exe example_kernel_emmc.uuu"
jieh朱
Thank you for your reply. I downloaded uuu.exe but double click on it to flash back.
