imx8mmevk : How to change the bitrate of vpuenc_h264
santhosh2
vpuenc_h264 bitrate ranges  from 10kbps to 40Mbps as per the document. How to change the bitrate of vpuenc_h264
Zhiming_Liu
It was written in i.MX_VPU_Application_Programming_Interface_Linux_Reference_Manual.pdf.
You will get it after you search keyword "bitrate" in that pdf.
Zhiming
santhosh2
Thank you
