vpuenc_h264 bitrate ranges from 10kbps to 40Mbps as per the document. How to change the bitrate of vpuenc_h264
It was written in i.MX_VPU_Application_Programming_Interface_Linux_Reference_Manual.pdf.
You will get it after you search keyword "bitrate" in that pdf.
Zhiming
Thank you
