imx8mm spread spectrum Mipi DSI
michael_schweik
i have the need to enable a spread spectrum on the mipi interface. Attached to the MIPI is a MIPI to LVDS Bridge from TI. Which possibilities do i have to enable a spread spectrum on the MIPI.
Thanks Michael
JorgeCas
Hello, I hope you are doing well.
I suggest you check the next thread
Best regards.
michael_schweik
ok thanks. Is there any suggestion how to enable this behaviour
in yocto?
Thanks Michael
JorgeCas
Since there is not a reference to implement spread spectrum on MIPI DSI in our documentation I suggest you check the section 6.4.2 MIPI DSI Interface of Linux reference manual and take a look on the drivers mentioned.
Best regards.
