imx8mm can not shutdown after upgrade to lf-5.10.72-2.2.2
Search instead for
ChicLee
before upgrade, our device(hardknott-5.10.72-2.2.1) can normal shutdown after "poweroff" command.
but upgrade to lf-5.10.72-2.2.2, our device can not normal shutdown after "poweroff" command.
I found the commit from imx-atf and it makes the problem.
I want to know what is the next I should do? check schematic? or check the kernel source?
