imx8mm camera enable MJPEG
1,749件の閲覧回数
nxf65233
Hello
sensor:ov5640
mpu:imx8mm
I check the format for camera, it only shows it supporting YUYV as below.
 root@imx8mmevk:~# v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
    [0]: 'YUYV' (YUYV 4:2:2)
            Interval: Discrete 0.033s (30.000 fps)
        Size: Discrete 1920x1080
        Size: Discrete 2592x1944
            Interval: Discrete 0.067s (15.000 fps)
 How to enable MJPEG or other formats?
タグ(1)
1,727件の閲覧回数
igorpadykov
Hi Partrick
per ov5640 datasheet mjpeg output is not supported
https://docs1.toradex.com/103996-omnivision-ov5640-datasheet.pdf
Also i.MX8M Mini vpu does not support mjpeg as described in sect.15.4. VPU H1 (VPU_H1)
i.MX 8M Mini Applications Processor Reference Manual
One can try software encoding as described on
https://variwiki.com/index.php?title=DART-MX8M_GSTREAMER
1,728件の閲覧回数
igorpadykov
Hi Partrick
