We were exploring QSPI for booting and load images via UUU.
1) We trying to load the whole wic image created by yocto into QSPI.
$ sudo uuu -b qspi core-image-minimal-imx8mm-lpddr4-evk-20230519111834.rootfs.wic
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.21-3-gcbff795
Success 0 Failure 0
1:8 2/ 3 [==> 9% ] SDPV: write -f core-image-minimal-imx8mm-lpddr4-evk-20230519111834.rootfs.wic -skipspl -skipfhdr
It goes upto 10% and then fails.
Success 0 Failure 1
1:8 2/ 3 [HID(W):LIBUSB_ERROR_NO_DEVICE ] SDPV: write -f core-image-minimal-imx8mm-lpddr4-evk-20230519111834.rootfs.wic -skipspl -skipfhdr
We seen for emmc, We searching to do same for QSPI.
Decompress rootfs image and burn into emmc (since 1.1.87)
uuu -b emmc_all bootloader rootfs.sdcard.bz2/*
2) We also trying to do partition the qspi via UUU. and load each image(u-boot ,kernel , dtb and FS) as separate images.
is there way to do it? Please let us know.
解決済! 解決策の投稿を見る。
I tried this solution, it works.
all(bootloader, device tree, Linux kernel, rootfs)... - NXP Community
Can you try to download only the uboot to the QSPI?
HI,
Can anyone look into it?
