imx8m nano | problems with first bitbake
已解决
跳至解决方案
4,143 次查看
shai_b
Senior Contributor II
Dear team,
my customer has an issue while using the bitbake on the first time.
Please find attached is the log file.
Can you please advise say what is the issues?
/home/user/imx-yocto-bsp/sources/poky/meta/classes/package.bbclass:1364: DeprecationWarning: invalid escape sequence \.
  msg = "%s is listed in PACKAGES multiple times, this leads to packaging errors." % pkg
Server refused shutdown.  Remaining client fds: 1
Client pids: 1438225
Server will shut down after all clients exit.
Client pids: 1877400
Client pids: 1888775
Client pids: 1930053
Client pids: 1930879
Client pids: 1931014
1273995 14:33:48.799829 Running command ['stateShutdown']
1273995 14:33:48.800481 Command Completed
1273995 14:33:50.195094 Running command ['stateForceShutdown']
1273995 14:33:50.195396 Command Completed
1273995 14:33:52.069508 Processing Client
1273995 14:33:52.069636 Disconnecting Client
1273995 14:33:52.070210 No timeout, exiting.
1273995 14:33:52.171123 Exiting
1273995 14:33:52.197569 Original lockfile contents: ['1273995\n']
1273995 14:33:52.198171 Exiting as we could obtain the lock
sys:1: ResourceWarning: unclosed file <_io.TextIOWrapper name='/home/user/imx-yocto-bsp/EdgeMaster/bitbake-cookerdaemon.log' mode='a+' encoding='UTF-8'>
2038144 14:35:07.359021 --- Starting bitbake server pid 2038144 at 2022-04-26 14:35:07.359005
Waiting for your kind feedback, Many Thanks.
KR,
Shai
标记 (1)
1 解答
3,982 次查看
shai_b
Hi @tomsong,
You need to install the following essential Linux host packages to build Yocto, see the following command:
破坏者
$ sudo apt-get install gawk wget git-core diffstat unzip
texinfo gcc-multilib
build-essential chrpath socat cpio python python3 python3-pip
python3-pexpect
xz-utils debianutils iputils-ping python3-git python3-jinja2
libegl1-mesa libsdl1.2-dev
pylint3 xterm rsync curl zstd pzstd lz4c lz4 libssl-dev
Please use the below guide for more details (chapter 3.2 @ page 6)
https://www.nxp.com/docs/en/user-guide/IMX_YOCTO_PROJECT_USERS_GUIDE.pdf
I hope that helps you.
Kind regards,
Shai
在原帖中查看解决方案
3 回复数
4,114 次查看
Zhiming_Liu
Please let customer install host packages.
This issue should be caused by customer enviroment.
3,992 次查看
tomsong
I get similar errors. Could I know what host package is needed? Thanks!
3,983 次查看
shai_b
Hi @tomsong,
破坏者
python3-pexpect
Kind regards,
Shai
